How to replace missing values with the last given Value
i have a Database with the following scheme:
| Field | Type |
| object | varchar(50) |
| attribute | int(11) |
| value | float |
| date | datetime |
| Field | Type |
| value | float |
| date | datetime |
Object = manufacturing plant
attribute = Sensor name
Value = sensor value
date = timestamp (datetime)
The Idea is to only save an attribute, when the value hase changed (triggered by change)...
In Rapidminder i am able to transform the scheme back to the traditional scheme, where every attribute/Sensor has a collumn. Only problem i have, are the missing values. If there are no values it means the haven`t changed, so i`d like to replace the missing values with the last given value. Is there a way to accomplish this ?
If it is not clear what exacty my problem is, i can try to be more precise in explaining it.
Thank you for your reply/ help
1 - 2 of
21
1 - 1 of
11
Hi @Carlito,
You can use "replace missing values (series)" operator here with previous non-missing value.
Best,
YY
Best,
YY
Best,
YY
