<?xml version="1.0" encoding="UTF-8"?><process version="8.1.003">
<context>
<input/>
<output/>
<macros/>
</context>
<operator activated="true" class="process" compatibility="8.1.003" expanded="true" name="Process">
<process expanded="true">
<operator activated="true" class="social_media:search_twitter" compatibility="8.1.000" expanded="true" height="68" name="Search Twitter" width="90" x="45" y="34">
<parameter key="connection" value="Twitter connection 1"/>
<parameter key="query" value="hydrocarbon"/>
<parameter key="limit" value="1000"/>
<parameter key="language" value="en"/>
<operator activated="true" class="find_threshold" compatibility="8.1.003" expanded="true" height="82" name="Find Threshold" width="90" x="313" y="238"/>
<operator activated="true" class="remove_duplicates" compatibility="8.1.003" expanded="true" height="103" name="Remove Duplicates" width="90" x="179" y="34">
<operator activated="true" class="apply_threshold" compatibility="8.1.003" expanded="true" height="82" name="Apply Threshold" width="90" x="179" y="238"/>
<operator activated="true" class="write_excel" compatibility="8.1.003" expanded="true" height="82" name="Write Excel" width="90" x="313" y="34">
<parameter key="excel_file" value="C:\Users\common.AMETUNIV\Documents\twitter data.xlsx"/>
<operator activated="true" class="com.aylien.textapi.rapidminer:aylien_sentiment" compatibility="0.2.000" expanded="true" height="68" name="Analyze Sentiment" width="90" x="447" y="136">
<parameter key="connection" value="NewConnection"/>
<parameter key="input_attribute" value="Text"/>
<operator activated="true" class="apply_model" compatibility="8.1.003" expanded="true" height="82" name="Apply Model" width="90" x="246" y="340">
<connect from_op="Search Twitter" from_port="output" to_op="Remove Duplicates" to_port="example set input"/>
<connect from_op="Remove Duplicates" from_port="original" to_op="Write Excel" to_port="input"/>
<connect from_op="Write Excel" from_port="through" to_op="Analyze Sentiment" to_port="Example Set"/>
<connect from_op="Analyze Sentiment" from_port="Example Set" to_port="result 1"/>
</process>
</process>
