Flexible Visualization
Hi there,
I am new to RapidMiner (using Studio version 9.3) and I am struggeling with the visualization capabilities. What I want to achieve as a result is a scatter plot of predicted values vs. real values, which is easily done. Further, I would like to have the same value range for both axes so that the identity line (real values vs. real values) should be 45 degrees. With some manual adjustments I can achieve an acceptable result for that, too. My problem is that I would like to get that kind of resulting chart for each example set within an IOObjectCollection and I don't want to manually adjust the axes and the titel of the chart for each example set. The question is if there is any possibility to work with macros within visualizations, for example to pass a titel based on the selected example set and to pass minimum and maximum values of an attribute based on the selected example set to the axes so that the charts adjust themselves with respect to the input data and do all have the same appearance? I know I could solve this problem using R so I guess it should not be a problem for RapidMiner as well, but I have not found any tutorial or discussion so far which is covering this topic.
In my opinion, with my experience with RM so far, I would find it helpful to have operators creating charts within processes where you can adjust the parameters as you like, use it within loops and export them automatically using export operators.
Thx for your help.
Best regards,
Sven
