<process version="9.4.000-BETA2"> <context> <input/> <output/> <macros/> </context> <operator activated="true" class="process" compatibility="9.4.000-BETA2" expanded="true" name="Process"> <parameter key="logverbosity" value="init"/> <parameter key="random_seed" value="2001"/> <parameter key="send_mail" value="never"/> <parameter key="notification_email" value=""/> <parameter key="process_duration_for_mail" value="30"/> <parameter key="encoding" value="SYSTEM"/> <process expanded="true"> <operator activated="true" class="utility:create_exampleset" compatibility="9.4.000-BETA2" expanded="true" height="68" name="Create ExampleSet" width="90" x="179" y="34"> <parameter key="generator_type" value="date series"/> <parameter key="number_of_examples" value="120"/> <parameter key="use_stepsize" value="true"/> <list key="function_descriptions"/> <parameter key="add_id_attribute" value="false"/> <list key="numeric_series_configuration"/> <list key="date_series_configuration"/> <list key="date_series_configuration (interval)"> <parameter key="Date" value="2019-12-23 00:00:00.1.hour"/> </list> <parameter key="date_format" value="yyyy-MM-dd HH:mm:ss"/> <parameter key="time_zone" value="SYSTEM"/> <parameter key="column_separator" value=","/> <parameter key="parse_all_as_nominal" value="false"/> <parameter key="decimal_point_character" value="."/> <parameter key="trim_attribute_names" value="true"/> </operator> <operator activated="true" class="generate_attributes" compatibility="9.4.000-BETA2" expanded="true" height="82" name="Generate Attributes" width="90" x="313" y="34"> <list key="function_descriptions"> <parameter key="Holiday" value="if(Date==date_parse_custom("2019/12/25 00:00:00","yyyy/MM/dd HH:mm:ss"),"Christmas",MISSING_NOMINAL)"/> </list> <parameter key="keep_all" value="true"/> </operator> <operator activated="true" class="time_series:process_windows" compatibility="9.4.000-SNAPSHOT" expanded="true" height="82" name="Process Windows" width="90" x="514" y="34"> <parameter key="attribute_filter_type" value="all"/> <parameter key="attribute" value=""/> <parameter key="attributes" value=""/> <parameter key="use_except_expression" value="false"/> <parameter key="value_type" value="nominal"/> <parameter key="use_value_type_exception" value="false"/> <parameter key="except_value_type" value="time"/> <parameter key="block_type" value="single_value"/> <parameter key="use_block_type_exception" value="false"/> <parameter key="except_block_type" value="value_matrix_row_start"/> <parameter key="invert_selection" value="false"/> <parameter key="include_special_attributes" value="true"/> <parameter key="has_indices" value="false"/> <parameter key="indices_attribute" value=""/> <parameter key="window_size" value="24"/> <parameter key="no_overlapping_windows" value="true"/> <parameter key="step_size" value="1"/> <parameter key="create_horizon_(labels)" value="false"/> <parameter key="horizon_attribute" value=""/> <parameter key="horizon_size" value="1"/> <parameter key="horizon_offset" value="0"/> <parameter key="add_last_index_in_window_attribute" value="false"/> <parameter key="enable_parallel_execution" value="true"/> <process expanded="true"> <operator activated="true" class="time_series:replace_missing_values" compatibility="9.4.000-SNAPSHOT" expanded="true" height="68" name="Replace Missing Values (Series)" width="90" x="447" y="34"> <parameter key="attribute_filter_type" value="single"/> <parameter key="attribute" value="Holiday"/> <parameter key="attributes" value=""/> <parameter key="use_except_expression" value="false"/> <parameter key="value_type" value="nominal"/> <parameter key="use_value_type_exception" value="false"/> <parameter key="except_value_type" value="time"/> <parameter key="block_type" value="single_value"/> <parameter key="use_block_type_exception" value="false"/> <parameter key="except_block_type" value="value_matrix_row_start"/> <parameter key="invert_selection" value="false"/> <parameter key="include_special_attributes" value="false"/> <parameter key="has_indices" value="false"/> <parameter key="indices_attribute" value=""/> <parameter key="overwrite_attributes" value="true"/> <parameter key="new_attributes_postfix" value="_cleaned"/> <parameter key="replace_type_numerical" value="previous value"/> <parameter key="replace_type_nominal" value="previous value"/> <parameter key="replace_type_date_time" value="previous value"/> <parameter key="replace_value_numerical" value="0.0"/> <parameter key="replace_value_nominal" value="unknown"/> <parameter key="skip_other_missings" value="true"/> <parameter key="replace_infinity" value="true"/> <parameter key="replace_empty_strings" value="true"/> <parameter key="ensure_finite_values" value="false"/> </operator> <connect from_port="windowed example set" to_op="Replace Missing Values (Series)" to_port="example set"/> <connect from_op="Replace Missing Values (Series)" from_port="example set" to_port="output 1"/> <portSpacing port="source_windowed example set" spacing="0"/> <portSpacing port="source_input 1" spacing="0"/> <portSpacing port="sink_output 1" spacing="0"/> <portSpacing port="sink_output 2" spacing="0"/> </process> </operator> <operator activated="true" class="append" compatibility="9.4.000-BETA2" expanded="true" height="82" name="Append" width="90" x="648" y="34"> <parameter key="datamanagement" value="double_array"/> <parameter key="data_management" value="auto"/> <parameter key="merge_type" value="all"/> </operator> <connect from_op="Create ExampleSet" from_port="output" to_op="Generate Attributes" to_port="example set input"/> <connect from_op="Generate Attributes" from_port="example set output" to_op="Process Windows" to_port="example set"/> <connect from_op="Process Windows" from_port="output 1" to_op="Append" to_port="example set 1"/> <connect from_op="Append" from_port="merged set" to_port="result 1"/> <portSpacing port="source_input 1" spacing="0"/> <portSpacing port="sink_result 1" spacing="0"/> <portSpacing port="sink_result 2" spacing="0"/> </process> </operator> </process>
