Bug in
User: "Rapidminerpartner"
New Altair Community Member
Updated by Jocelyn
Hello, everyone
I found a bug in "Execute R" operator
I am using R-3.6.0
Briefly, "Execute R" cannot compute mean function of R
I did
data[1,1] <- mean(data[3:5,4])
but it didn't work and why it didn't is written in the log file I attached
I believe it will not be able to compute var function either.
I attached the process and log files.
Please fix this problem for me
Thank you and have a nice day.
Best,
1 - 1 of 11
    User: "YYH"
    Accepted Answer
    Hi @Rapidminerpartner
    It seems that R's mean does not behave well with dataframes. One workaround is to convert the data to a regular matrix before taking the mean:
    data[1,1] <- mean(data.matrix(data[3:5,4]))
    https://stackoverflow.com/questions/35485536/r-argument-is-not-numeric-or-logical-returning-na/52153758
    <?xml version="1.0" encoding="UTF-8"?><process version="9.4.000-BETA">
      <context>
        <input/>
        <output/>
        <macros/>
      </context>
      <operator activated="true" class="process" compatibility="9.4.000-BETA" expanded="true" name="Process">
        <process expanded="true">
          <operator activated="true" breakpoints="after" class="retrieve" compatibility="9.4.000-BETA" expanded="true" height="68" name="Retrieve Iris" width="90" x="112" y="34">
            <parameter key="repository_entry" value="//Samples/data/Iris"/>
          <operator activated="true" class="r_scripting:execute_r" compatibility="9.1.000" expanded="true" height="103" name="Execute R" width="90" x="313" y="34">
            <parameter key="script" value="# rm_main is a mandatory function, &#10;# the number of arguments has to be the number of input ports (can be none)&#10;rm_main = function(data)&#10;{&#10;    print('Hello, world!')&#10;    # output can be found in Log View&#10;    &#10;&#10;    data[1,1] &lt;- mean(data.matrix(data[3:5,4]))&#10;    &#10;    &#10;    # your code goes here&#10;&#10;    # for example:&#10;    data2 &lt;- as.data.table(matrix(1:16,4,4))&#10; &#10;    # connect 2 output ports to see the results&#10;    return(list(data,data2))&#10;}&#10;"/>
          <connect from_op="Retrieve Iris" from_port="output" to_op="Execute R" to_port="input 1"/>
          <connect from_op="Execute R" from_port="output 1" to_port="result 1"/>
          <connect from_op="Execute R" from_port="output 2" to_port="result 2"/>
        </process>
    </process>
