<?xml version="1.0" encoding="UTF-8"?><process version="9.3.001"><br> <context><br> <input/><br> <output/><br> <macros/><br> </context><br> <operator activated="true" class="process" compatibility="9.3.001" expanded="true" name="Process"><br> <parameter key="logverbosity" value="init"/><br> <parameter key="random_seed" value="2001"/><br> <parameter key="send_mail" value="never"/><br> <parameter key="notification_email" value=""/><br> <parameter key="process_duration_for_mail" value="30"/><br> <parameter key="encoding" value="UTF-8"/><br> <process expanded="true"><br> <operator activated="true" class="text:create_document" compatibility="9.1.000-SNAPSHOT" expanded="true" height="68" name="Create Document" width="90" x="179" y="34"><br> <parameter key="text" value="This is document 1 contains some doc 1 blablabla"/><br> <parameter key="add label" value="false"/><br> <parameter key="label_type" value="nominal"/><br> </operator><br> <operator activated="true" class="text:create_document" compatibility="9.1.000-SNAPSHOT" expanded="true" height="68" name="Create Document (2)" width="90" x="179" y="136"><br> <parameter key="text" value="This is document 2 contains some doc 2 blablabla"/><br> <parameter key="add label" value="false"/><br> <parameter key="label_type" value="nominal"/><br> </operator><br> <operator activated="true" class="text:combine_documents" compatibility="9.1.000-SNAPSHOT" expanded="true" height="103" name="Combine Documents" width="90" x="380" y="34"/><br> <operator activated="true" class="execute_script" compatibility="9.3.001" expanded="true" height="82" name="Execute Script" width="90" x="648" y="34"><br> <parameter key="script" value="import java.util.ArrayList; import java.util.List; import com.rapidminer.operator.Operator; import com.rapidminer.operator.OperatorDescription; import com.rapidminer.operator.OperatorException; import com.rapidminer.operator.ports.InputPortExtender; import com.rapidminer.operator.ports.OutputPort; import com.rapidminer.operator.text.Document; import com.rapidminer.operator.text.Token; Document d = input[0]; IOObjectCollection<Document> result = new IOObjectCollection<>(); for( Token t : d.getTokenSequence()){ 	result.add(new Document( t.getToken())); } // You can add any code here // This line returns the first input as the first output return result;"/><br> <parameter key="standard_imports" value="true"/><br> </operator><br> <operator activated="false" class="operator_toolbox:split_document_into_collection" compatibility="2.3.000-SNAPSHOT" expanded="true" height="82" name="Split Document into Collection" width="90" x="648" y="340"><br> <parameter key="split_string" value="\n"/><br> </operator><br> <connect from_op="Create Document" from_port="output" to_op="Combine Documents" to_port="documents 1"/><br> <connect from_op="Create Document (2)" from_port="output" to_op="Combine Documents" to_port="documents 2"/><br> <connect from_op="Combine Documents" from_port="document" to_op="Execute Script" to_port="input 1"/><br> <connect from_op="Execute Script" from_port="output 1" to_port="result 1"/><br> <portSpacing port="source_input 1" spacing="0"/><br> <portSpacing port="sink_result 1" spacing="0"/><br> <portSpacing port="sink_result 2" spacing="0"/><br> </process><br> </operator><br></process><br><br>
this is one text ; this is another text ; and here is yet another ;
<?xml version="1.0" encoding="UTF-8"?><process version="9.3.001"> <context> <input/> <output/> <macros/> </context> <operator activated="true" class="process" compatibility="9.3.001" expanded="true" name="Process"> <parameter key="logverbosity" value="init"/> <parameter key="random_seed" value="2001"/> <parameter key="send_mail" value="never"/> <parameter key="notification_email" value=""/> <parameter key="process_duration_for_mail" value="30"/> <parameter key="encoding" value="UTF-8"/> <process expanded="true"> <operator activated="true" class="text:create_document" compatibility="8.2.000" expanded="true" height="68" name="Create Document" width="90" x="179" y="34"> <parameter key="text" value="This is document 1 contains some doc 1 blablabla"/> <parameter key="add label" value="false"/> <parameter key="label_type" value="nominal"/> </operator> <operator activated="true" class="text:create_document" compatibility="8.2.000" expanded="true" height="68" name="Create Document (2)" width="90" x="179" y="136"> <parameter key="text" value="This is document 2 contains some doc 2 blablabla"/> <parameter key="add label" value="false"/> <parameter key="label_type" value="nominal"/> </operator> <operator activated="true" class="text:combine_documents" compatibility="8.2.000" expanded="true" height="103" name="Combine Documents" width="90" x="380" y="34"/> <operator activated="true" class="operator_toolbox:split_document_into_collection" compatibility="2.1.000" expanded="true" height="82" name="Split Document into Collection" width="90" x="514" y="34"> <parameter key="split_string" value="\n"/> </operator> <connect from_op="Create Document" from_port="output" to_op="Combine Documents" to_port="documents 1"/> <connect from_op="Create Document (2)" from_port="output" to_op="Combine Documents" to_port="documents 2"/> <connect from_op="Combine Documents" from_port="document" to_op="Split Document into Collection" to_port="document"/> <connect from_op="Split Document into Collection" from_port="collection" to_port="result 1"/> <portSpacing port="source_input 1" spacing="0"/> <portSpacing port="sink_result 1" spacing="0"/> <portSpacing port="sink_result 2" spacing="0"/> </process> </operator> </process>
<?xml version="1.0" encoding="UTF-8"?><process version="9.3.001"> <context> <input/> <output/> <macros/> </context> <operator activated="true" class="process" compatibility="9.3.001" expanded="true" name="Process"> <parameter key="logverbosity" value="init"/> <parameter key="random_seed" value="2001"/> <parameter key="send_mail" value="never"/> <parameter key="notification_email" value=""/> <parameter key="process_duration_for_mail" value="30"/> <parameter key="encoding" value="UTF-8"/> <process expanded="true"> <operator activated="true" class="concurrency:loop_files" compatibility="9.3.001" expanded="true" height="82" name="Loop Files" width="90" x="112" y="85"> <parameter key="directory" value="/Users/genzerconsulting/Desktop/documents"/> <parameter key="filter_type" value="regex"/> <parameter key="filter_by_regex" value=".*.txt"/> <parameter key="recursive" value="false"/> <parameter key="enable_macros" value="false"/> <parameter key="macro_for_file_name" value="file_name"/> <parameter key="macro_for_file_type" value="file_type"/> <parameter key="macro_for_folder_name" value="folder_name"/> <parameter key="reuse_results" value="false"/> <parameter key="enable_parallel_execution" value="true"/> <process expanded="true"> <operator activated="true" class="text:read_document" compatibility="8.2.000" expanded="true" height="68" name="Read Document" width="90" x="112" y="34"> <parameter key="extract_text_only" value="true"/> <parameter key="use_file_extension_as_type" value="true"/> <parameter key="content_type" value="txt"/> <parameter key="encoding" value="SYSTEM"/> </operator> <connect from_port="file object" to_op="Read Document" to_port="file"/> <connect from_op="Read Document" from_port="output" to_port="output 1"/> <portSpacing port="source_file object" spacing="0"/> <portSpacing port="source_input 1" spacing="0"/> <portSpacing port="sink_output 1" spacing="0"/> <portSpacing port="sink_output 2" spacing="0"/> </process> </operator> <operator activated="true" class="text:combine_documents" compatibility="8.2.000" expanded="true" height="82" name="Combine Documents" width="90" x="246" y="85"/> <operator activated="true" class="operator_toolbox:split_document_into_collection" compatibility="2.1.000" expanded="true" height="82" name="Split Document into Collection" width="90" x="380" y="85"> <parameter key="split_string" value="\n\s"/> </operator> <connect from_op="Loop Files" from_port="output 1" to_op="Combine Documents" to_port="documents 1"/> <connect from_op="Combine Documents" from_port="document" to_op="Split Document into Collection" to_port="document"/> <connect from_op="Split Document into Collection" from_port="collection" to_port="result 1"/> <portSpacing port="source_input 1" spacing="0"/> <portSpacing port="sink_result 1" spacing="0"/> <portSpacing port="sink_result 2" spacing="0"/> </process> </operator> </process>
