<?xml version="1.0" encoding="UTF-8"?><process version="9.3.001"> <context> <input/> <output/> <macros/> </context> <operator activated="true" class="process" compatibility="9.3.001" expanded="true" name="Process"> <parameter key="logverbosity" value="init"/> <parameter key="random_seed" value="2001"/> <parameter key="send_mail" value="never"/> <parameter key="notification_email" value=""/> <parameter key="process_duration_for_mail" value="30"/> <parameter key="encoding" value="UTF-8"/> <process expanded="true"> <operator activated="true" class="generate_macro" compatibility="9.3.001" expanded="true" height="82" name="Generate Macro" width="90" x="313" y="34"> <list key="function_descriptions"> <parameter key="MonthNow" value="date_get(date_now(),DATE_UNIT_MONTH)+1"/> <parameter key="MonthOld" value="date_get(date_add(date_now(),-50,DATE_UNIT_DAY),DATE_UNIT_MONTH)+1"/> </list> </operator> <connect from_port="input 1" to_op="Generate Macro" to_port="through 1"/> <connect from_op="Generate Macro" from_port="through 1" to_port="result 1"/> <portSpacing port="source_input 1" spacing="0"/> <portSpacing port="source_input 2" spacing="0"/> <portSpacing port="sink_result 1" spacing="0"/> <portSpacing port="sink_result 2" spacing="0"/> <description align="center" color="yellow" colored="false" height="50" resized="true" width="177" x="268" y="134">January = month 0</description> </process> </operator> </process>
