<div><?xml version="1.0" encoding="UTF-8"?><process version="9.3.000"></div><div> <context></div><div> <input/></div><div> <output/></div><div> <macros/></div><div> </context></div><div> <operator activated="true" class="process" compatibility="9.3.000" expanded="true" name="Process"></div><div> <parameter key="logverbosity" value="init"/></div><div> <parameter key="random_seed" value="2001"/></div><div> <parameter key="send_mail" value="never"/></div><div> <parameter key="notification_email" value=""/></div><div> <parameter key="process_duration_for_mail" value="30"/></div><div> <parameter key="encoding" value="SYSTEM"/></div><div> <process expanded="true"></div><div> <operator activated="true" class="concurrency:loop" compatibility="9.3.000" expanded="true" height="82" name="Loop" width="90" x="179" y="85"></div><div> <parameter key="number_of_iterations" value="2"/></div><div> <parameter key="iteration_macro" value="iteration"/></div><div> <parameter key="reuse_results" value="false"/></div><div> <parameter key="enable_parallel_execution" value="true"/></div><div> <process expanded="true"></div><div> <operator activated="true" class="set_macros" compatibility="9.3.000" expanded="true" height="82" name="Set Macros" width="90" x="246" y="136"></div><div> <list key="macros"></div><div> <parameter key="Macro_1" value=""Coke""/></div><div> <parameter key="Macro_2" value=""Pepsi""/></div><div> </list></div><div> </operator></div><div> <operator activated="true" class="filter_examples" compatibility="9.3.000" expanded="true" height="103" name="Filter Examples" width="90" x="380" y="136"></div><div> <parameter key="parameter_expression" value=""/></div><div> <parameter key="condition_class" value="custom_filters"/></div><div> <parameter key="invert_filter" value="false"/></div><div> <list key="filters_list"></div><div> <parameter key="filters_entry_key" value="Model.equals.Macro_%{execution_count}"/></div><div> </list></div><div> <parameter key="filters_logic_and" value="true"/></div><div> <parameter key="filters_check_metadata" value="true"/></div><div> </operator></div><div> <connect from_op="Set Macros" from_port="through 1" to_op="Filter Examples" to_port="example set input"/></div><div> <connect from_op="Filter Examples" from_port="example set output" to_port="output 1"/></div><div> <portSpacing port="source_input 1" spacing="0"/></div><div> <portSpacing port="sink_output 1" spacing="0"/></div><div> <portSpacing port="sink_output 2" spacing="0"/></div><div> </process></div><div> </operator></div><div> <connect from_op="Loop" from_port="output 1" to_port="result 1"/></div><div> <portSpacing port="source_input 1" spacing="0"/></div><div> <portSpacing port="sink_result 1" spacing="0"/></div><div> <portSpacing port="sink_result 2" spacing="0"/></div><div> </process></div><div> </operator></div><div></process></div>
