How to create a map?
User: "Caravani"
New Altair Community Member
Updated by Jocelyn
Hello Rapid-Miner Community!
I am a complete newbie to rapid miner and started learning to use the plattform in university for a business case.
I have a big excel sheet with 2 columns - Colum A longitude - Column B latitude. Now I have to create a map of europe/germany and to create dots with the geographical position of each row. The aim is to see then, where the most dots are cause this gives me the information I need later :smile:
I already searched for solutions online, but if I understand it correctly this is not an easy task...
Do you have any ideas?
Thanks in advance!
- Cara
1 - 1 of 11
    User: "Marco_Boeck"
    Accepted Answer
    Updated by Marco_Boeck
    The data is expected to be in a numerical column each, so one numerical column for longitude, and another one for latitude. 53.344813 is a perfectly fine numerical value for lat/lon and you should see them appear if you choose a map that actually is in that range (you could try a worldmap first).
    If you have them in nominal columns, you can use a Parse Numbers operator to convert them before using the visualizations.
    Marco
