Exception: java.lang.IllegalStateException Message: Duplicate key E:\Anaconda3\python.exe
User: "zhaiyh"
New Altair Community Member
Updated by Jocelyn
I encountered a problem when configuring Python in RapidMiner in Win10.
I have installed Anaconda 3 in E:\anaconda3 and wanted to configure Python in RapidMiner. I opened the Preferences dialog and in the Python Scripting tab, when I was clicking the  droplist of Conda Environment, I encountered the following error. I do not know what I should do next.
Stack trace:
java.util.stream.Collectors.lambda$throwingMerger$0(Collectors.java:133)
java.util.HashMap.merge(HashMap.java:1254)
java.util.stream.Collectors.lambda$toMap$58(Collectors.java:1320)
java.util.stream.ReduceOps$3ReducingSink.accept(ReduceOps.java:169)
java.util.stream.ReferencePipeline$3$1.accept(ReferencePipeline.java:193)
java.util.ArrayList$Itr.forEachRemaining(ArrayList.java:899)
java.util.Spliterators$IteratorSpliterator.forEachRemaining(Spliterators.java:1801)
java.util.stream.AbstractPipeline.copyInto(AbstractPipeline.java:481)
java.util.stream.AbstractPipeline.wrapAndCopyInto(AbstractPipeline.java:471)
java.util.stream.ReduceOps$ReduceOp.evaluateSequential(ReduceOps.java:708)
java.util.stream.AbstractPipeline.evaluate(AbstractPipeline.java:234)
java.util.stream.ReferencePipeline.collect(ReferencePipeline.java:499)
com.rapidminer.extension.pythonscripting.operator.scripting.python.PythonSetupTester.forceRefreshCondaEnvironments(PythonSetupTester.java:913)
com.rapidminer.extension.pythonscripting.operator.scripting.python.PythonSetupTester.listCondaEnvironments(PythonSetupTester.java:837)
com.rapidminer.extension.pythonscripting.operator.scripting.python.PythonSetupTester.listCondaEnvironments(PythonSetupTester.java:819)
com.rapidminer.extension.pythonscripting.parameter.CondaEnvironmentSuggestionProvider.getSuggestions(CondaEnvironmentSuggestionProvider.java:27)
com.rapidminer.extension.pythonscripting.gui.properties.celleditors.value.PythonEnvironmentCellEditor.getSuggestions(PythonEnvironmentCellEditor.java:203)
com.rapidminer.gui.properties.celleditors.value.AbstractSuggestionBoxValueCellEditor$SuggestionComboBoxModel$1.run(AbstractSuggestionBoxValueCellEditor.java:263)
com.rapidminer.gui.tools.ProgressThread$3.run(ProgressThread.java:586)
java.util.concurrent.ThreadPoolExecutor.runWorker(ThreadPoolExecutor.java:1149)
java.util.concurrent.ThreadPoolExecutor$Worker.run(ThreadPoolExecutor.java:624)
java.lang.Thread.run(Thread.java:748)
1 - 1 of 11
    User: "varunm1"
    Accepted Answer
    @zhaiyh better do it and also do a complete uninstall, by this I mean to remove all folders as well after uninstall because anaconda doesn't remove some folders even after uninstall, we need to remove manually. Also, be careful with the paths as well, see if you have old paths in environment variables and try to remove them so that it doesn't conflict once you install the new version.
    I saw the following issue with blank environment names in other forums as well and people mostly use the command I provided but if it removes all then better try installing it freshly. Make sure the paths are clear and also once done installing check your environments. Don't forget Rapidminer needs pandas (package) data frame in anaconda.
