Hi there - first time asking a question, and new to rapidminer.
I have an excel file with around a text field and 740 rows of data. Each cell contains a few paragraphs of text. I ran the operator toolbox extract topics from data (LDA) on it, and it works very well in topic discovery. But it doesn't remove the stopwords, so I end up with a large group of topics clustered around stopwords.
I've tried a few different ways of removing the stopwords (and then still be able to run the LDA operator on it (it can take documents or a text field in a dataset).
Can anyone assist in removing the stopwords?
Below is my XML code. Thanks a lot!
<?xml version="1.0" encoding="UTF-8"?><process version="9.3.001">
<context>
<input/>
<output/>
<macros/>
</context>
<operator activated="true" class="process" compatibility="9.3.001" expanded="true" name="Process">
<process expanded="true">
<operator activated="true" class="read_excel" compatibility="9.3.001" expanded="true" height="68" name="Read Excel" width="90" x="45" y="85">
<parameter key="excel_file" value="C:\Users\vande\Google Drive (jorisv@clearoutcomes.net)\IPDET Course Text Analytics\Demonstrations - Practical exercises\Exercise 5 Topic Modelling\PovertyActionLab.xlsx"/>
<parameter key="sheet_selection" value="sheet number"/>
<parameter key="sheet_number" value="1"/>
<parameter key="imported_cell_range" value="A1"/>
<parameter key="first_row_as_names" value="true"/>
<list key="annotations"/>
<parameter key="date_format" value=""/>
<parameter key="time_zone" value="SYSTEM"/>
<parameter key="locale" value="English (United States)"/>
<parameter key="read_all_values_as_polynominal" value="false"/>
<list key="data_set_meta_data_information"/>
<parameter key="read_not_matching_values_as_missings" value="true"/>
<parameter key="datamanagement" value="double_array"/>
<parameter key="data_management" value="auto"/>
<operator activated="true" class="nominal_to_text" compatibility="9.3.001" expanded="true" height="82" name="Nominal to Text" width="90" x="179" y="85">
<parameter key="attribute" value="PolicyIssues"/>
<parameter key="value_type" value="nominal"/>
<parameter key="except_value_type" value="file_path"/>
<parameter key="block_type" value="single_value"/>
<parameter key="except_block_type" value="single_value"/>
<operator activated="true" class="operator_toolbox:lda_exampleset" compatibility="2.1.000" expanded="true" height="124" name="Extract Topics from Data (LDA)" width="90" x="380" y="136">
<parameter key="text_attribute" value="PolicyIssues"/>
<parameter key="number_of_topics" value="6"/>
<parameter key="use_alpha_heuristics" value="true"/>
<parameter key="alpha_sum" value="0.1"/>
<parameter key="use_beta_heuristics" value="true"/>
<parameter key="beta" value="0.01"/>
<parameter key="optimize_hyperparameters" value="true"/>
<parameter key="optimize_interval_for_hyperparameters" value="10"/>
<parameter key="top_words_per_topic" value="10"/>
<parameter key="iterations" value="1000"/>
<parameter key="reproducible" value="true"/>
<parameter key="enable_logging" value="false"/>
<parameter key="use_local_random_seed" value="false"/>
<parameter key="local_random_seed" value="1992"/>
<connect from_op="Read Excel" from_port="output" to_op="Nominal to Text" to_port="example set input"/>
<connect from_op="Nominal to Text" from_port="example set output" to_op="Extract Topics from Data (LDA)" to_port="exa"/>
<connect from_op="Extract Topics from Data (LDA)" from_port="exa" to_port="result 1"/>
<connect from_op="Extract Topics from Data (LDA)" from_port="top" to_port="result 2"/>
</process>
</process>
