how to get length of numbers in column
halaalrobassy
i have column that has student number and i want first to get the length of column for example : student with 11 numbers digits and others with 12 number digits . then i want to extract students with 11 length digits from this dataset. second split this numbers into three divisions..
can you tell me which processes can do this
thank you
MartinLiebig
maybe generate attributes with
length(str([attribute]))
Best,
Martin
rfuentealba
Hello
@halaalrobassy
Please find attached the process. It's pretty simple:
You need to make sure your numbers are polynominal. Then with the
Generate Attributes
operator you can create an attribute named
Length of ID
, which is almost the same thing that Herr
@mschmitz
suggested (but I prefer to make it easier).
All the best,
Rod.
number_length.rmp
Edin_Klapic
Hi
@halaalrobassy
The shortest way is to use Generate Attributes with the function cut().
The syntax is explained within the Operator (see attached screenshot).
Of course you can also achieve this in other ways as well (e.g. copy the Attribute and use Replace to only keep the relevant numbers of each "divisions" using a regular expression.
Happy Mining,
Edin
MartinLiebig
Best,
Martin
rfuentealba
Hello
@halaalrobassy
Generate Attributes
Length of ID
@mschmitz
All the best,
Rod.
number_length.rmp
halaalrobassy
thank you ,i implemented this process ,
know i want to divid this ID into three divisions, the first two numbers one division , the second four number is another division. can you tell me how
Edin_Klapic
Hi
@halaalrobassy
Happy Mining,
Edin
halaalrobassy
thank you,
this was helpful and i get want i want
