<context> <input/> <output/> <macros/> </context> <operator activated="true" class="process" compatibility="9.3.001" expanded="true" name="Process"> <parameter key="logverbosity" value="init"/> <parameter key="random_seed" value="2001"/> <parameter key="send_mail" value="never"/> <parameter key="notification_email" value=""/> <parameter key="process_duration_for_mail" value="30"/> <parameter key="encoding" value="SYSTEM"/> <process expanded="true"> <operator activated="true" class="retrieve" compatibility="9.3.001" expanded="true" height="68" name="Retrieve 12traff" width="90" x="45" y="34"> <parameter key="repository_entry" value="12traff"/> </operator> <operator activated="true" class="discretize_by_frequency" compatibility="9.3.001" expanded="true" height="103" name="Discretize" width="90" x="179" y="85"> <parameter key="return_preprocessing_model" value="false"/> <parameter key="create_view" value="false"/> <parameter key="attribute_filter_type" value="all"/> <parameter key="attribute" value=""/> <parameter key="attributes" value="|avgMeasuredTime|avgSpeed|vehicleCount"/> <parameter key="use_except_expression" value="false"/> <parameter key="value_type" value="numeric"/> <parameter key="use_value_type_exception" value="false"/> <parameter key="except_value_type" value="real"/> <parameter key="block_type" value="value_series"/> <parameter key="use_block_type_exception" value="false"/> <parameter key="except_block_type" value="value_series_end"/> <parameter key="invert_selection" value="false"/> <parameter key="include_special_attributes" value="false"/> <parameter key="use_sqrt_of_examples" value="false"/> <parameter key="number_of_bins" value="2"/> <parameter key="range_name_type" value="long"/> <parameter key="automatic_number_of_digits" value="true"/> <parameter key="number_of_digits" value="-1"/> </operator> <operator activated="true" class="date_to_numerical" compatibility="9.3.001" expanded="true" height="82" name="Date to Numerical" width="90" x="313" y="136"> <parameter key="attribute_name" value="TIMESTAMP"/> <parameter key="time_unit" value="millisecond"/> <parameter key="millisecond_relative_to" value="second"/> <parameter key="second_relative_to" value="minute"/> <parameter key="minute_relative_to" value="hour"/> <parameter key="hour_relative_to" value="day"/> <parameter key="day_relative_to" value="month"/> <parameter key="week_relative_to" value="year"/> <parameter key="month_relative_to" value="year"/> <parameter key="quarter_relative_to" value="year"/> <parameter key="half_year_relative_to" value="year"/> <parameter key="year_relative_to" value="era"/> <parameter key="keep_old_attribute" value="false"/> </operator> <operator activated="true" class="numerical_to_binominal" compatibility="9.3.001" expanded="true" height="82" name="Numerical to Binominal" width="90" x="447" y="136"> <parameter key="attribute_filter_type" value="all"/> <parameter key="attribute" value=""/> <parameter key="attributes" value=""/> <parameter key="use_except_expression" value="false"/> <parameter key="value_type" value="numeric"/> <parameter key="use_value_type_exception" value="false"/> <parameter key="except_value_type" value="real"/> <parameter key="block_type" value="value_series"/> <parameter key="use_block_type_exception" value="false"/> <parameter key="except_block_type" value="value_series_end"/> <parameter key="invert_selection" value="false"/> <parameter key="include_special_attributes" value="false"/> <parameter key="min" value="0.0"/> <parameter key="max" value="0.0"/> </operator> <operator activated="true" class="weka:W-Apriori" compatibility="7.3.000" expanded="true" height="68" name="W-Apriori" width="90" x="514" y="34"> <parameter key="N" value="1234567.0"/> <parameter key="T" value="0.0"/> <parameter key="C" value="0.2"/> <parameter key="D" value="0.05"/> <parameter key="U" value="1.0"/> <parameter key="M" value="0.05"/> <parameter key="S" value="-1.0"/> <parameter key="I" value="true"/> <parameter key="R" value="false"/> <parameter key="V" value="false"/> <parameter key="A" value="false"/> <parameter key="c" value="-1.0"/> </operator> <operator activated="true" class="log" compatibility="9.3.001" expanded="true" height="82" name="Log (2)" width="90" x="648" y="34"> <parameter key="filename" value="C:\Users\computer\Documents\apriori.log"/> <list key="log"> <parameter key="count" value="operator.Process.value.applycount"/> <parameter key="Memory" value="operator.Process.value.memory"/> <parameter key="process time" value="operator.Process.value.time"/> <parameter key="Apriori time" value="operator.W-Apriori.value.looptime"/> <parameter key="Support" value="operator.W-Apriori.parameter.M"/> <parameter key="Confidence" value="operator.W-Apriori.parameter.C"/> </list> <parameter key="sorting_type" value="none"/> <parameter key="sorting_k" value="100"/> <parameter key="persistent" value="false"/> </operator> <connect from_op="Retrieve 12traff" from_port="output" to_op="Discretize" to_port="example set input"/> <connect from_op="Discretize" from_port="example set output" to_op="Date to Numerical" to_port="example set input"/> <connect from_op="Date to Numerical" from_port="example set output" to_op="Numerical to Binominal" to_port="example set input"/> <connect from_op="Numerical to Binominal" from_port="example set output" to_op="W-Apriori" to_port="example set"/> <connect from_op="W-Apriori" from_port="associator" to_op="Log (2)" to_port="through 1"/> <connect from_op="Log (2)" from_port="through 1" to_port="result 1"/> <portSpacing port="source_input 1" spacing="0"/> <portSpacing port="sink_result 1" spacing="0"/> <portSpacing port="sink_result 2" spacing="0"/> </process> </operator> </process>
