<?xml version="1.0" encoding="UTF-8"?><process version="9.3.001"><br> <context><br> <input/><br> <output/><br> <macros/><br> </context><br> <operator activated="true" class="process" compatibility="9.3.001" expanded="true" name="Process"><br> <parameter key="logverbosity" value="init"/><br> <parameter key="random_seed" value="2001"/><br> <parameter key="send_mail" value="never"/><br> <parameter key="notification_email" value=""/><br> <parameter key="process_duration_for_mail" value="30"/><br> <parameter key="encoding" value="SYSTEM"/><br> <process expanded="true"><br> <operator activated="true" class="utility:create_exampleset" compatibility="9.3.001" expanded="true" height="68" name="Create ExampleSet" width="90" x="112" y="34"><br> <parameter key="generator_type" value="date series"/><br> <parameter key="number_of_examples" value="10"/><br> <parameter key="use_stepsize" value="false"/><br> <list key="function_descriptions"/><br> <parameter key="add_id_attribute" value="false"/><br> <list key="numeric_series_configuration"/><br> <list key="date_series_configuration"><br> <parameter key="Date" value="2019-07-04 10:00.2019-07-14 10:00"/><br> </list><br> <list key="date_series_configuration (interval)"/><br> <parameter key="date_format" value="yyyy-MM-dd hh:mm"/><br> <parameter key="time_zone" value="SYSTEM"/><br> <parameter key="column_separator" value=","/><br> <parameter key="parse_all_as_nominal" value="false"/><br> <parameter key="decimal_point_character" value="."/><br> <parameter key="trim_attribute_names" value="true"/><br> </operator><br> <operator activated="true" class="generate_attributes" compatibility="9.3.001" expanded="true" height="82" name="Generate Attributes" width="90" x="380" y="34"><br> <list key="function_descriptions"><br> <parameter key="Date + 1 minute" value="date_add(Date,1 ,DATE_UNIT_MINUTE)"/><br> </list><br> <parameter key="keep_all" value="true"/><br> </operator><br> <connect from_op="Create ExampleSet" from_port="output" to_op="Generate Attributes" to_port="example set input"/><br> <connect from_op="Generate Attributes" from_port="example set output" to_port="result 1"/><br> <portSpacing port="source_input 1" spacing="0"/><br> <portSpacing port="sink_result 1" spacing="0"/><br> <portSpacing port="sink_result 2" spacing="0"/><br> </process><br> </operator><br></process><br><br>
<?xml version="1.0" encoding="UTF-8"?><process version="9.3.000"> <context> <input/> <output/> <macros/> </context> <operator activated="true" class="process" compatibility="9.3.000" expanded="true" name="Process"> <parameter key="logverbosity" value="init"/> <parameter key="random_seed" value="2001"/> <parameter key="send_mail" value="never"/> <parameter key="notification_email" value=""/> <parameter key="process_duration_for_mail" value="30"/> <parameter key="encoding" value="SYSTEM"/> <process expanded="true"> <operator activated="true" class="utility:create_exampleset" compatibility="9.3.000" expanded="true" height="68" name="Create ExampleSet" width="90" x="179" y="34"> <parameter key="generator_type" value="date series"/> <parameter key="number_of_examples" value="2"/> <parameter key="use_stepsize" value="false"/> <list key="function_descriptions"/> <parameter key="add_id_attribute" value="false"/> <list key="numeric_series_configuration"/> <list key="date_series_configuration"> <parameter key="Date" value="2019-07-04 12:00:20.2019-07-05 12:00:05"/> </list> <list key="date_series_configuration (interval)"/> <parameter key="date_format" value="yyyy-MM-dd HH:mm:ss"/> <parameter key="time_zone" value="SYSTEM"/> <parameter key="column_separator" value=","/> <parameter key="parse_all_as_nominal" value="false"/> <parameter key="decimal_point_character" value="."/> <parameter key="trim_attribute_names" value="true"/> </operator> <operator activated="true" class="adjust_date" compatibility="9.3.000" expanded="true" height="82" name="Adjust Date" width="90" x="313" y="34"> <parameter key="attribute_name" value="Date"/> <list key="adjustments"> <parameter key="1" value="Hour"/> </list> <parameter key="keep_old_attribute" value="true"/> </operator> <connect from_op="Create ExampleSet" from_port="output" to_op="Adjust Date" to_port="example set input"/> <connect from_op="Adjust Date" from_port="example set output" to_port="result 1"/> <portSpacing port="source_input 1" spacing="0"/> <portSpacing port="sink_result 1" spacing="0"/> <portSpacing port="sink_result 2" spacing="0"/> </process> </operator> </process>
