<?xml version="1.0" encoding="UTF-8"?><process version="9.4.000-SNAPSHOT"><br> <context><br> <input/><br> <output/><br> <macros/><br> </context><br> <operator activated="true" class="process" compatibility="9.4.000-SNAPSHOT" expanded="true" name="Process"><br> <parameter key="logverbosity" value="init"/><br> <parameter key="random_seed" value="2001"/><br> <parameter key="send_mail" value="never"/><br> <parameter key="notification_email" value=""/><br> <parameter key="process_duration_for_mail" value="30"/><br> <parameter key="encoding" value="UTF-8"/><br> <process expanded="true"><br> <operator activated="true" class="retrieve" compatibility="9.4.000-SNAPSHOT" expanded="true" height="68" name="Retrieve Iris" width="90" x="45" y="187"><br> <parameter key="repository_entry" value="//Samples/data/Iris"/><br> </operator><br> <operator activated="true" class="multiply" compatibility="9.4.000-SNAPSHOT" expanded="true" height="103" name="Multiply" width="90" x="179" y="187"/><br> <operator activated="true" class="concurrency:loop_attributes" compatibility="9.4.000-SNAPSHOT" expanded="true" height="82" name="Loop Attributes" width="90" x="313" y="34"><br> <parameter key="attribute_filter_type" value="all"/><br> <parameter key="attribute" value=""/><br> <parameter key="attributes" value=""/><br> <parameter key="use_except_expression" value="false"/><br> <parameter key="value_type" value="attribute_value"/><br> <parameter key="use_value_type_exception" value="false"/><br> <parameter key="except_value_type" value="time"/><br> <parameter key="block_type" value="attribute_block"/><br> <parameter key="use_block_type_exception" value="false"/><br> <parameter key="except_block_type" value="value_matrix_row_start"/><br> <parameter key="invert_selection" value="false"/><br> <parameter key="include_special_attributes" value="false"/><br> <parameter key="attribute_name_macro" value="loop_attribute"/><br> <parameter key="reuse_results" value="false"/><br> <parameter key="enable_parallel_execution" value="true"/><br> <process expanded="true"><br> <operator activated="true" class="select_attributes" compatibility="9.4.000-SNAPSHOT" expanded="true" height="82" name="Select Attributes" width="90" x="45" y="34"><br> <parameter key="attribute_filter_type" value="single"/><br> <parameter key="attribute" value="%{loop_attribute}"/><br> <parameter key="attributes" value=""/><br> <parameter key="use_except_expression" value="false"/><br> <parameter key="value_type" value="attribute_value"/><br> <parameter key="use_value_type_exception" value="false"/><br> <parameter key="except_value_type" value="time"/><br> <parameter key="block_type" value="attribute_block"/><br> <parameter key="use_block_type_exception" value="false"/><br> <parameter key="except_block_type" value="value_matrix_row_start"/><br> <parameter key="invert_selection" value="false"/><br> <parameter key="include_special_attributes" value="true"/><br> </operator><br> <operator activated="true" class="rename" compatibility="9.4.000-SNAPSHOT" expanded="true" height="82" name="Rename" width="90" x="179" y="34"><br> <parameter key="old_name" value="%{loop_attribute}"/><br> <parameter key="new_name" value="att"/><br> <list key="rename_additional_attributes"/><br> </operator><br> <connect from_port="input 1" to_op="Select Attributes" to_port="example set input"/><br> <connect from_op="Select Attributes" from_port="example set output" to_op="Rename" to_port="example set input"/><br> <connect from_op="Rename" from_port="example set output" to_port="output 1"/><br> <portSpacing port="source_input 1" spacing="0"/><br> <portSpacing port="source_input 2" spacing="0"/><br> <portSpacing port="sink_output 1" spacing="0"/><br> <portSpacing port="sink_output 2" spacing="0"/><br> </process><br> </operator><br> <operator activated="true" class="append" compatibility="9.4.000-SNAPSHOT" expanded="true" height="82" name="Append" width="90" x="447" y="34"><br> <parameter key="datamanagement" value="double_array"/><br> <parameter key="data_management" value="auto"/><br> <parameter key="merge_type" value="all"/><br> </operator><br> <operator activated="true" class="discretize_by_frequency" compatibility="9.4.000-SNAPSHOT" expanded="true" height="103" name="Discretize" width="90" x="581" y="34"><br> <parameter key="return_preprocessing_model" value="false"/><br> <parameter key="create_view" value="false"/><br> <parameter key="attribute_filter_type" value="single"/><br> <parameter key="attribute" value="att"/><br> <parameter key="attributes" value=""/><br> <parameter key="use_except_expression" value="false"/><br> <parameter key="value_type" value="numeric"/><br> <parameter key="use_value_type_exception" value="false"/><br> <parameter key="except_value_type" value="real"/><br> <parameter key="block_type" value="value_series"/><br> <parameter key="use_block_type_exception" value="false"/><br> <parameter key="except_block_type" value="value_series_end"/><br> <parameter key="invert_selection" value="false"/><br> <parameter key="include_special_attributes" value="false"/><br> <parameter key="use_sqrt_of_examples" value="false"/><br> <parameter key="number_of_bins" value="4"/><br> <parameter key="range_name_type" value="long"/><br> <parameter key="automatic_number_of_digits" value="true"/><br> <parameter key="number_of_digits" value="-1"/><br> </operator><br> <operator activated="true" class="concurrency:loop_attributes" compatibility="9.4.000-SNAPSHOT" expanded="true" height="103" name="Loop Attributes (2)" width="90" x="715" y="187"><br> <parameter key="attribute_filter_type" value="all"/><br> <parameter key="attribute" value=""/><br> <parameter key="attributes" value=""/><br> <parameter key="use_except_expression" value="false"/><br> <parameter key="value_type" value="attribute_value"/><br> <parameter key="use_value_type_exception" value="false"/><br> <parameter key="except_value_type" value="time"/><br> <parameter key="block_type" value="attribute_block"/><br> <parameter key="use_block_type_exception" value="false"/><br> <parameter key="except_block_type" value="value_matrix_row_start"/><br> <parameter key="invert_selection" value="false"/><br> <parameter key="include_special_attributes" value="false"/><br> <parameter key="attribute_name_macro" value="loop_attribute"/><br> <parameter key="reuse_results" value="true"/><br> <parameter key="enable_parallel_execution" value="true"/><br> <process expanded="true"><br> <operator activated="true" class="rename" compatibility="9.4.000-SNAPSHOT" expanded="true" height="82" name="Rename (2)" width="90" x="45" y="85"><br> <parameter key="old_name" value="%{loop_attribute}"/><br> <parameter key="new_name" value="att"/><br> <list key="rename_additional_attributes"/><br> </operator><br> <operator activated="true" class="apply_model" compatibility="9.4.000-SNAPSHOT" expanded="true" height="82" name="Apply Model" width="90" x="179" y="34"><br> <list key="application_parameters"/><br> <parameter key="create_view" value="false"/><br> </operator><br> <operator activated="true" class="rename" compatibility="9.4.000-SNAPSHOT" expanded="true" height="82" name="Rename (3)" width="90" x="313" y="34"><br> <parameter key="old_name" value="att"/><br> <parameter key="new_name" value="%{loop_attribute}"/><br> <list key="rename_additional_attributes"/><br> </operator><br> <connect from_port="input 1" to_op="Rename (2)" to_port="example set input"/><br> <connect from_port="input 2" to_op="Apply Model" to_port="model"/><br> <connect from_op="Rename (2)" from_port="example set output" to_op="Apply Model" to_port="unlabelled data"/><br> <connect from_op="Apply Model" from_port="labelled data" to_op="Rename (3)" to_port="example set input"/><br> <connect from_op="Apply Model" from_port="model" to_port="output 2"/><br> <connect from_op="Rename (3)" from_port="example set output" to_port="output 1"/><br> <portSpacing port="source_input 1" spacing="0"/><br> <portSpacing port="source_input 2" spacing="0"/><br> <portSpacing port="source_input 3" spacing="0"/><br> <portSpacing port="sink_output 1" spacing="0"/><br> <portSpacing port="sink_output 2" spacing="0"/><br> <portSpacing port="sink_output 3" spacing="0"/><br> </process><br> </operator><br> <connect from_op="Retrieve Iris" from_port="output" to_op="Multiply" to_port="input"/><br> <connect from_op="Multiply" from_port="output 1" to_op="Loop Attributes" to_port="input 1"/><br> <connect from_op="Multiply" from_port="output 2" to_op="Loop Attributes (2)" to_port="input 1"/><br> <connect from_op="Loop Attributes" from_port="output 1" to_op="Append" to_port="example set 1"/><br> <connect from_op="Append" from_port="merged set" to_op="Discretize" to_port="example set input"/><br> <connect from_op="Discretize" from_port="preprocessing model" to_op="Loop Attributes (2)" to_port="input 2"/><br> <connect from_op="Loop Attributes (2)" from_port="output 1" to_port="result 1"/><br> <portSpacing port="source_input 1" spacing="0"/><br> <portSpacing port="sink_result 1" spacing="0"/><br> <portSpacing port="sink_result 2" spacing="0"/><br> </process><br> </operator><br></process>
