Process 1 file out of multiple in Email
User: "mtran"
New Altair Community Member
Updated by Jocelyn
  I'll start off that I don't have any issues running my process when there is only 1 attachment to the email received.  The issue I am running into is when there is more than 1 attachment in the email.  I only want to process 1/2 of the files attached.  I tried to put in the file name into the 'attachment file pattern' field not sure if I have it entered incorrectly.
Attachment File Pattern: 'test.xlsx'
Any help would be greatly appreciated and thanks in advance.  I've posted my XML below
<?xml version="1.0" encoding="UTF-8"?><process version="9.1.000">
  <context>
    <input/>
    <output/>
    <macros/>
  </context>
  <operator activated="true" class="process" compatibility="9.1.000" expanded="true" name="Process">
    <process expanded="true">
      <operator activated="true" class="handle_exception" compatibility="9.1.000" expanded="true" height="82" name="Handle Exception" width="90" x="246" y="34">
          <operator activated="true" class="text:process_mail_documents" compatibility="8.1.000" expanded="true" height="82" name="Process Documents from Mail Store (2)" width="90" x="179" y="136">
            <parameter key="create_word_vector" value="false"/>
            <parameter key="vector_creation" value="TF-IDF"/>
            <parameter key="add_meta_information" value="false"/>
            <parameter key="keep_text" value="true"/>
            <parameter key="prune_method" value="none"/>
            <parameter key="prune_below_percent" value="3.0"/>
            <parameter key="prune_above_percent" value="30.0"/>
            <parameter key="prune_below_rank" value="0.05"/>
            <parameter key="prune_above_rank" value="0.95"/>
            <parameter key="datamanagement" value="double_sparse_array"/>
            <parameter key="data_management" value="auto"/>
            <parameter key="define_store" value="explicit"/>
            <parameter key="jndi_name" value="java:/Mail"/>
            <list key="connection_properties"/>
            <parameter key="protocol" value="imap"/>
            <parameter key="break_on_invalid_emails" value="false"/>
            <parameter key="only_unseen" value="true"/>
            <parameter key="mark_seen" value="true"/>
            <parameter key="delete_messages" value="false"/>
            <parameter key="recursive" value="false"/>
            <parameter key="folder" value="INBOX"/>
            <parameter key="download attachments" value="true"/>
            <parameter key="attachment file-pattern" value="test.xlsx"/>
            <parameter key="attachment MIME-type" value=""/>
              <operator activated="true" class="select" compatibility="9.1.000" expanded="true" height="68" name="Select (2)" width="90" x="112" y="85">
                <parameter key="index" value="1"/>
                <parameter key="unfold" value="false"/>
              <operator activated="true" class="read_excel" compatibility="8.1.000" expanded="true" height="68" name="Read Excel (2)" width="90" x="246" y="85">
                <parameter key="sheet_selection" value="sheet name"/>
                <parameter key="sheet_name" value="Test 2"/>
                <parameter key="sheet_number" value="1"/>
                <parameter key="imported_cell_range" value="A1"/>
                <parameter key="first_row_as_names" value="false"/>
                <list key="annotations"/>
                <parameter key="date_format" value=""/>
                <parameter key="time_zone" value="SYSTEM"/>
                <parameter key="locale" value="English (United States)"/>
                <parameter key="read_all_values_as_polynominal" value="false"/>
                <list key="data_set_meta_data_information"/>
                <parameter key="read_not_matching_values_as_missings" value="true"/>
                <parameter key="datamanagement" value="double_array"/>
              <operator activated="false" class="store" compatibility="9.1.000" expanded="true" height="68" name="Store (2)" width="90" x="581" y="340">
                <parameter key="repository_entry" value="//Local Repository/MailTest"/>
              <operator activated="false" class="text:data_to_documents" compatibility="8.1.000" expanded="true" height="68" name="Data to Documents (2)" width="90" x="447" y="340">
                <parameter key="select_attributes_and_weights" value="false"/>
                <list key="specify_weights"/>
              <connect from_port="document" to_port="document 1"/>
              <connect from_port="attachments" to_op="Select (2)" to_port="collection"/>
              <connect from_op="Select (2)" from_port="selected" to_op="Read Excel (2)" to_port="file"/>
              <connect from_op="Read Excel (2)" from_port="output" to_port="document 2"/>
              <portSpacing port="source_attachments" spacing="0"/>
              <portSpacing port="sink_document 3" spacing="0"/>
            </process>
          <connect from_op="Process Documents from Mail Store (2)" from_port="example set" to_port="out 1"/>
        </process>
          <operator activated="true" class="text:process_mail_documents" compatibility="8.1.000" expanded="true" height="82" name="Process Documents from Mail Store (3)" width="90" x="179" y="187">
              <operator activated="true" class="select" compatibility="9.1.000" expanded="true" height="68" name="Select (3)" width="90" x="112" y="85">
              <operator activated="true" class="read_excel" compatibility="8.1.000" expanded="true" height="68" name="Read Excel (3)" width="90" x="246" y="85">
              <operator activated="false" class="store" compatibility="9.1.000" expanded="true" height="68" name="Store (3)" width="90" x="581" y="340">
              <operator activated="false" class="text:data_to_documents" compatibility="8.1.000" expanded="true" height="68" name="Data to Documents (3)" width="90" x="447" y="340">
              <connect from_port="attachments" to_op="Select (3)" to_port="collection"/>
              <connect from_op="Select (3)" from_port="selected" to_op="Read Excel (3)" to_port="file"/>
              <connect from_op="Read Excel (3)" from_port="output" to_port="document 2"/>
            </process>
          <connect from_op="Process Documents from Mail Store (3)" from_port="example set" to_port="out 1"/>
        </process>
      <connect from_op="Handle Exception" from_port="out 1" to_port="result 1"/>
    </process>
</process>
1 - 1 of 11
    User: "Edin_Klapic"
    Accepted Answer
    Hi @mtran,
    the parameter setting looks good.
    Some remarks:
    - If you only want to process 1 file and you know the name, there is no need for the Select Operator. You can enter the file name in the Parameter
    - If the file names always differ, maybe there is a pattern which you can use as input together with placeholders (* ?)
    - Just to be sure: You wrote: "I only want to process 1/2 of the files attached". I assume you meant only 1 of 2 files (and not half of the files), right?
    Please find attached my XML which worked fine.
    Happy Mining,
    Edin
    <?xml version="1.0" encoding="UTF-8"?><process version="9.0.003"><br>  <context><br>    <input/><br>    <output/><br>    <macros/><br>  </context><br>  <operator activated="true" class="process" compatibility="9.0.003" expanded="true" name="Process"><br>    <process expanded="true"><br>      <operator activated="true" class="text:process_mail_documents" compatibility="8.1.000" expanded="true" height="82" name="Process Documents from Mail Store (4)" width="90" x="246" y="34"><br>        <parameter key="create_word_vector" value="false"/><br>        <parameter key="add_meta_information" value="false"/><br>        <parameter key="keep_text" value="true"/><br>        <parameter key="host" value=""/><br>        <parameter key="user" value=""/><br>        <parameter key="password" value=""/><br>        <list key="connection_properties">       <br>        </list><br>        <parameter key="protocol" value="imap"/><br>        <parameter key="mark_seen" value="false"/><br>        <parameter key="download attachments" value="true"/><br>        <parameter key="attachment file-pattern" value="*2.xlsx"/><br>        <process expanded="true"><br>          <operator activated="true" class="handle_exception" compatibility="9.0.003" expanded="true" height="82" name="Handle Exception (2)" width="90" x="380" y="85"><br>            <process expanded="true"><br>              <operator activated="true" class="select" compatibility="9.0.003" expanded="true" height="68" name="Select (4)" width="90" x="45" y="34"/><br>              <operator activated="true" class="read_excel" compatibility="8.1.000" expanded="true" height="68" name="Read Excel (4)" width="90" x="179" y="34"><br>                <parameter key="sheet_selection" value="sheet name"/><br>                <parameter key="sheet_name" value="Test2"/><br>                <parameter key="imported_cell_range" value="A1:B5"/><br>                <list key="annotations"/><br>                <parameter key="read_all_values_as_polynominal" value="true"/><br>                <list key="data_set_meta_data_information"/><br>              </operator><br>              <operator activated="true" class="store" compatibility="9.0.003" expanded="true" height="68" name="Store" width="90" x="313" y="34"><br>                <parameter key="repository_entry" value="testfile"/><br>              </operator><br>              <connect from_port="in 1" to_op="Select (4)" to_port="collection"/><br>              <connect from_op="Select (4)" from_port="selected" to_op="Read Excel (4)" to_port="file"/><br>              <connect from_op="Read Excel (4)" from_port="output" to_op="Store" to_port="input"/><br>              <connect from_op="Store" from_port="through" to_port="out 1"/><br>              <portSpacing port="source_in 1" spacing="0"/><br>              <portSpacing port="source_in 2" spacing="0"/><br>              <portSpacing port="sink_out 1" spacing="0"/><br>              <portSpacing port="sink_out 2" spacing="0"/><br>            </process><br>            <process expanded="true"><br>              <portSpacing port="source_in 1" spacing="0"/><br>              <portSpacing port="source_in 2" spacing="0"/><br>              <portSpacing port="sink_out 1" spacing="0"/><br>              <portSpacing port="sink_out 2" spacing="0"/><br>            </process><br>          </operator><br>          <connect from_port="document" to_port="document 1"/><br>          <connect from_port="attachments" to_op="Handle Exception (2)" to_port="in 1"/><br>          <connect from_op="Handle Exception (2)" from_port="out 1" to_port="document 2"/><br>          <portSpacing port="source_document" spacing="0"/><br>          <portSpacing port="source_attachments" spacing="0"/><br>          <portSpacing port="sink_document 1" spacing="0"/><br>          <portSpacing port="sink_document 2" spacing="0"/><br>          <portSpacing port="sink_document 3" spacing="0"/><br>        </process><br>      </operator><br>      <connect from_op="Process Documents from Mail Store (4)" from_port="example set" to_port="result 1"/><br>      <connect from_op="Process Documents from Mail Store (4)" from_port="word list" to_port="result 2"/><br>      <portSpacing port="source_input 1" spacing="0"/><br>      <portSpacing port="sink_result 1" spacing="0"/><br>      <portSpacing port="sink_result 2" spacing="0"/><br>      <portSpacing port="sink_result 3" spacing="0"/><br>    </process><br>  </operator><br></process><br><br>
