Hierarchical Classification
mattia_fumagall
New Altair Community Member
Dear All,
The following process performs a hierarchical classification on Iris.
<process version="5.3.008">
<context>
<input/>
<output/>
<macros/>
</context>
<operator activated="true" class="process" compatibility="5.3.008" expanded="true" name="Process">
<process expanded="true">
<operator activated="true" class="retrieve" compatibility="5.3.008" expanded="true" height="60" name="Retrieve Iris" width="90" x="45" y="30">
<parameter key="repository_entry" value="//Samples/data/Iris"/>
<operator activated="true" class="hierarchical_multi_class_classification" compatibility="5.3.008" expanded="true" height="76" name="Hierarchical Classification" width="90" x="179" y="30">
<list key="hierarchy">
<parameter key="versicolor_virginica" value="Iris-versicolor"/>
<parameter key="versicolor_virginica" value="Iris-virginica"/>
<parameter key="root" value="Iris-setosa"/>
<parameter key="root" value="versicolor_virginica"/>
</list>
<operator activated="true" class="support_vector_machine" compatibility="5.3.008" expanded="true" height="112" name="SVM" width="90" x="179" y="30"/>
<connect from_port="training set" to_op="SVM" to_port="training set"/>
<connect from_op="SVM" from_port="model" to_port="model"/>
<portSpacing port="source_training set" spacing="0"/>
</process>
<connect from_op="Retrieve Iris" from_port="output" to_op="Hierarchical Classification" to_port="training set"/>
<connect from_op="Hierarchical Classification" from_port="model" to_port="result 2"/>
<connect from_op="Hierarchical Classification" from_port="example set" to_port="result 1"/>
</process>
</process>
It works fine but if I apply the model to an exampleset, the
result is not showing the hierarchical labels --just the original labels
(iris-*). Is there a way to make the prediction use the parent labels
too --like another column?
I found an old solved topic in the fourm (https://community.rapidminer.com/discussion/47784/solved-hierarchical-classification-operator) where it is said that:
unfortunately that is not possible with a single operator. It is
possible to build a custom process that creates hierarchical labels, but
that is way more complex.
Please, have you any suggestion on how to to set up the custom process?Thank you in advance for your help!
Best regards,
Mattia
2
Best Answer
One approach would be to build separate models for each level. So start by building a first model for the highest level category, then apply the model and get your predictions for that level. Then filter for each value in that label, and build another model for the next level classification and apply that model to it. You would need to loop through all the values of the first model to do that, and so on for as many different levels of the hierarchy that you had. This is pretty straightforward conceptually, but would require a bit of a complex setup in RapidMiner (loops within loops, depending on how many levels you have).2
Thanks Brian, I see and I guess that with my current RapidMiner skills it would be a little bit difficult to set up... :-/ I checked around and I did not find any example process to start from... If you have any sample file suggestion from which I can start It would be super...BTW, thanks in advance,Best,Mattia0
Hello guys! I made some modifications in your process. I added a Cross-Validation operator and a testing dataset, splitting original data in 70% / 30%. Then it works, but I don't understand the Performance Operators. Because when you see the Model results, it seems like a binary classification for each node, but when you see the Performance the confusion matrix shows the three classes. Could you explain me which one is the "testing" results?
PD: This is the modified XML.0
