Hi. I'm trying to classify authors of texts. I have 4 attributes containing the most commonly used words - attribute A B C and D. Attribute A is compared against A in rest of data, B against B in rest of data, etc.
But I want to check if attribute A exists in attributes A B C and D. For example:
1) row X has A with "example" value and B with "test" value
2) row Y has A with "test" value and B with "qwerty" value
3) "test" value exists in both X and Y, so it should return true, so there is a bigger chance that author of X is the same as author of Y
How I can do that? I want to use it together with operators like Decision Tree, KNN, etc.
