<?xml version="1.0" encoding="UTF-8"?><process version="9.3.000"> <context> <input/> <output/> <macros/> </context> <operator activated="true" class="process" compatibility="9.3.000" expanded="true" name="Process"> <parameter key="logverbosity" value="init"/> <parameter key="random_seed" value="2001"/> <parameter key="send_mail" value="never"/> <parameter key="notification_email" value=""/> <parameter key="process_duration_for_mail" value="30"/> <parameter key="encoding" value="UTF-8"/> <process expanded="true"> <operator activated="true" class="utility:create_exampleset" compatibility="9.3.000" expanded="true" height="68" name="Create ExampleSet" width="90" x="45" y="34"> <parameter key="generator_type" value="comma separated text"/> <parameter key="number_of_examples" value="100"/> <parameter key="use_stepsize" value="false"/> <list key="function_descriptions"/> <parameter key="add_id_attribute" value="false"/> <list key="numeric_series_configuration"/> <list key="date_series_configuration"/> <list key="date_series_configuration (interval)"/> <parameter key="date_format" value="yyyy-MM-dd HH:mm:ss"/> <parameter key="time_zone" value="SYSTEM"/> <parameter key="input_csv_text" value="ID;Aspects 1;bed:positive,room:positive 2;room:positive,wifi:negative"/> <parameter key="column_separator" value=";"/> <parameter key="parse_all_as_nominal" value="false"/> <parameter key="decimal_point_character" value="."/> <parameter key="trim_attribute_names" value="true"/> </operator> <operator activated="true" class="split" compatibility="9.3.000" expanded="true" height="82" name="Split Aspects" width="90" x="179" y="34"> <parameter key="attribute_filter_type" value="single"/> <parameter key="attribute" value="Aspects"/> <parameter key="attributes" value=""/> <parameter key="use_except_expression" value="false"/> <parameter key="value_type" value="nominal"/> <parameter key="use_value_type_exception" value="false"/> <parameter key="except_value_type" value="file_path"/> <parameter key="block_type" value="single_value"/> <parameter key="use_block_type_exception" value="false"/> <parameter key="except_block_type" value="single_value"/> <parameter key="invert_selection" value="false"/> <parameter key="include_special_attributes" value="true"/> <parameter key="split_pattern" value=","/> <parameter key="split_mode" value="ordered_split"/> <description align="center" color="transparent" colored="false" width="126">Split each aspect first.</description> </operator> <operator activated="true" class="de_pivot" compatibility="9.3.000" expanded="true" height="82" name="De-Pivot" width="90" x="313" y="34"> <list key="attribute_name"> <parameter key="Evaluation" value="Aspects_(.*)"/> </list> <parameter key="index_attribute" value="Index"/> <parameter key="create_nominal_index" value="true"/> <parameter key="keep_missings" value="false"/> <description align="center" color="transparent" colored="false" width="126">Reorganize to have each aspect in a row.</description> </operator> <operator activated="true" class="split" compatibility="9.3.000" expanded="true" height="82" name="Split Evaluation" width="90" x="447" y="34"> <parameter key="attribute_filter_type" value="single"/> <parameter key="attribute" value="Evaluation"/> <parameter key="attributes" value=""/> <parameter key="use_except_expression" value="false"/> <parameter key="value_type" value="nominal"/> <parameter key="use_value_type_exception" value="false"/> <parameter key="except_value_type" value="file_path"/> <parameter key="block_type" value="single_value"/> <parameter key="use_block_type_exception" value="false"/> <parameter key="except_block_type" value="single_value"/> <parameter key="invert_selection" value="false"/> <parameter key="include_special_attributes" value="false"/> <parameter key="split_pattern" value=":"/> <parameter key="split_mode" value="ordered_split"/> <description align="center" color="transparent" colored="false" width="126">Split each aspect into name and value.</description> </operator> <operator activated="true" class="select_attributes" compatibility="9.3.000" expanded="true" height="82" name="Select Attributes" width="90" x="581" y="34"> <parameter key="attribute_filter_type" value="single"/> <parameter key="attribute" value="Index"/> <parameter key="attributes" value=""/> <parameter key="use_except_expression" value="false"/> <parameter key="value_type" value="attribute_value"/> <parameter key="use_value_type_exception" value="false"/> <parameter key="except_value_type" value="time"/> <parameter key="block_type" value="attribute_block"/> <parameter key="use_block_type_exception" value="false"/> <parameter key="except_block_type" value="value_matrix_row_start"/> <parameter key="invert_selection" value="true"/> <parameter key="include_special_attributes" value="true"/> <description align="center" color="transparent" colored="false" width="126">Remove the indexed values generated.</description> </operator> <operator activated="true" class="blending:pivot" compatibility="9.3.000" expanded="true" height="82" name="Pivot" width="90" x="715" y="34"> <parameter key="group_by_attributes" value="ID"/> <parameter key="column_grouping_attribute" value="Evaluation_1"/> <list key="aggregation_attributes"> <parameter key="Evaluation_2" value="first"/> </list> <parameter key="use_default_aggregation" value="false"/> <parameter key="default_aggregation_function" value="first"/> <description align="center" color="transparent" colored="false" width="126">Recompose into having the type of information you require.</description> </operator> <operator activated="true" class="rename_by_replacing" compatibility="9.3.000" expanded="true" height="82" name="Rename by Replacing" width="90" x="849" y="34"> <parameter key="attribute_filter_type" value="regular_expression"/> <parameter key="attribute" value=""/> <parameter key="attributes" value=""/> <parameter key="regular_expression" value="first\(Evaluation_2\)_(.*)"/> <parameter key="use_except_expression" value="false"/> <parameter key="value_type" value="attribute_value"/> <parameter key="use_value_type_exception" value="false"/> <parameter key="except_value_type" value="time"/> <parameter key="block_type" value="attribute_block"/> <parameter key="use_block_type_exception" value="false"/> <parameter key="except_block_type" value="value_matrix_row_start"/> <parameter key="invert_selection" value="false"/> <parameter key="include_special_attributes" value="false"/> <parameter key="replace_what" value="first\(Evaluation_2\)_(.*)"/> <parameter key="replace_by" value="$1"/> <description align="center" color="transparent" colored="false" width="126">The pivot will generate strange names. Now you can rename it by using a simple regular expression.</description> </operator> <connect from_op="Create ExampleSet" from_port="output" to_op="Split Aspects" to_port="example set input"/> <connect from_op="Split Aspects" from_port="example set output" to_op="De-Pivot" to_port="example set input"/> <connect from_op="De-Pivot" from_port="example set output" to_op="Split Evaluation" to_port="example set input"/> <connect from_op="Split Evaluation" from_port="example set output" to_op="Select Attributes" to_port="example set input"/> <connect from_op="Select Attributes" from_port="example set output" to_op="Pivot" to_port="input"/> <connect from_op="Pivot" from_port="output" to_op="Rename by Replacing" to_port="example set input"/> <connect from_op="Rename by Replacing" from_port="example set output" to_port="result 1"/> <portSpacing port="source_input 1" spacing="0"/> <portSpacing port="sink_result 1" spacing="0"/> <portSpacing port="sink_result 2" spacing="0"/> </process> </operator> </process>
