Hi there, I'm new here! Not sure if I am using the right format to ask my question, so please be patient with me.
I get an output from FP Growth and Create Association Rules I struggle to interpret. When I set the support to 0.2, I get individual values in the Support column which are much lower. Also, why would it list Support for items that stand alone? Isn't the whole point of finding associations that there be more than one item?
<?xml version="1.0" encoding="UTF-8"?><process version="9.2.001">
<context>
<input/>
<output/>
<macros/>
</context>
<operator activated="true" class="process" compatibility="9.2.001" expanded="true" name="Process">
<process expanded="true">
<operator activated="true" class="retrieve" compatibility="9.2.001" expanded="true" height="68" name="Retrieve transactions_binary" width="90" x="45" y="34">
<parameter key="repository_entry" value="transactions_binary"/>
<operator activated="true" class="select_attributes" compatibility="9.2.001" expanded="true" height="82" name="Select Attributes" width="90" x="246" y="85">
<parameter key="attribute" value=""/>
<parameter key="attributes" value="Wrapping Paper|Toothpaste|Toothbrush|Soap|Shampoo|Prescription Med|Photo Processing|Perfume|Pens|Pencils|Pain Reliever|Markers|Magazine|Greeting Cards|Deodorant|Candy Bar|Bow"/>
<operator activated="true" class="numerical_to_binominal" compatibility="9.2.001" expanded="true" height="82" name="Numerical to Binominal" width="90" x="447" y="85">
<parameter key="attribute_filter_type" value="all"/>
<parameter key="value_type" value="numeric"/>
<parameter key="except_value_type" value="real"/>
<parameter key="block_type" value="value_series"/>
<parameter key="except_block_type" value="value_series_end"/>
<parameter key="min" value="0.0"/>
<parameter key="max" value="0.0"/>
<operator activated="true" class="concurrency:fp_growth" compatibility="9.2.001" expanded="true" height="82" name="FP-Growth" width="90" x="648" y="85">
<parameter key="input_format" value="items in dummy coded columns"/>
<parameter key="item_separators" value="|"/>
<parameter key="use_quotes" value="false"/>
<parameter key="quotes_character" value="""/>
<parameter key="escape_character" value="\"/>
<parameter key="trim_item_names" value="true"/>
<parameter key="min_requirement" value="support"/>
<parameter key="min_support" value="0.2"/>
<parameter key="min_frequency" value="100"/>
<parameter key="min_items_per_itemset" value="1"/>
<parameter key="max_items_per_itemset" value="6"/>
<parameter key="max_number_of_itemsets" value="1000000"/>
<parameter key="find_min_number_of_itemsets" value="true"/>
<parameter key="min_number_of_itemsets" value="100"/>
<parameter key="max_number_of_retries" value="15"/>
<parameter key="requirement_decrease_factor" value="0.9"/>
<enumeration key="must_contain_list"/>
<operator activated="true" class="create_association_rules" compatibility="9.2.001" expanded="true" height="82" name="Create Association Rules" width="90" x="849" y="136">
<parameter key="criterion" value="confidence"/>
<parameter key="min_confidence" value="0.2"/>
<parameter key="min_criterion_value" value="0.2"/>
<parameter key="gain_theta" value="2.0"/>
<parameter key="laplace_k" value="1.0"/>
<connect from_op="Retrieve transactions_binary" from_port="output" to_op="Select Attributes" to_port="example set input"/>
<connect from_op="Select Attributes" from_port="example set output" to_op="Numerical to Binominal" to_port="example set input"/>
<connect from_op="Numerical to Binominal" from_port="example set output" to_op="FP-Growth" to_port="example set"/>
<connect from_op="FP-Growth" from_port="example set" to_port="result 2"/>
<connect from_op="FP-Growth" from_port="frequent sets" to_op="Create Association Rules" to_port="item sets"/>
<connect from_op="Create Association Rules" from_port="rules" to_port="result 1"/>
<connect from_op="Create Association Rules" from_port="item sets" to_port="result 3"/>
</process>
</process>
