<?xml version="1.0" encoding="UTF-8"?><process version="9.2.001"> <context> <input/> <output/> <macros/> </context> <operator activated="true" class="process" compatibility="9.2.001" expanded="true" name="Process"> <parameter key="logverbosity" value="init"/> <parameter key="random_seed" value="2001"/> <parameter key="send_mail" value="never"/> <parameter key="notification_email" value=""/> <parameter key="process_duration_for_mail" value="30"/> <parameter key="encoding" value="SYSTEM"/> <process expanded="true"> <operator activated="true" class="retrieve" compatibility="9.2.001" expanded="true" height="68" name="Retrieve Titanic Training" width="90" x="179" y="34"> <parameter key="repository_entry" value="//Samples/data/Titanic Training"/> </operator> <operator activated="true" class="h2o:logistic_regression" compatibility="9.2.000" expanded="true" height="124" name="Logistic Regression" width="90" x="380" y="85"> <parameter key="solver" value="AUTO"/> <parameter key="reproducible" value="false"/> <parameter key="maximum_number_of_threads" value="4"/> <parameter key="use_regularization" value="false"/> <parameter key="lambda_search" value="false"/> <parameter key="number_of_lambdas" value="0"/> <parameter key="lambda_min_ratio" value="0.0"/> <parameter key="early_stopping" value="true"/> <parameter key="stopping_rounds" value="3"/> <parameter key="stopping_tolerance" value="0.001"/> <parameter key="standardize" value="true"/> <parameter key="non-negative_coefficients" value="false"/> <parameter key="add_intercept" value="true"/> <parameter key="compute_p-values" value="true"/> <parameter key="remove_collinear_columns" value="true"/> <parameter key="missing_values_handling" value="MeanImputation"/> <parameter key="max_iterations" value="0"/> <parameter key="max_runtime_seconds" value="0"/> </operator> <operator activated="true" class="converters:h2o_logreg_2_example_set" compatibility="0.5.000" expanded="true" height="82" name="Logistic Regression to ExampleSet" width="90" x="514" y="136"/> <operator activated="true" class="generate_attributes" compatibility="9.2.001" expanded="true" height="82" name="Generate Attributes" width="90" x="648" y="136"> <list key="function_descriptions"> <parameter key="test" value="[Std. Coefficient]"/> </list> <parameter key="keep_all" value="true"/> </operator> <connect from_op="Retrieve Titanic Training" from_port="output" to_op="Logistic Regression" to_port="training set"/> <connect from_op="Logistic Regression" from_port="model" to_op="Logistic Regression to ExampleSet" to_port="mod"/> <connect from_op="Logistic Regression to ExampleSet" from_port="exa" to_op="Generate Attributes" to_port="example set input"/> <connect from_op="Generate Attributes" from_port="example set output" to_port="result 1"/> <portSpacing port="source_input 1" spacing="0"/> <portSpacing port="sink_result 1" spacing="0"/> <portSpacing port="sink_result 2" spacing="0"/> </process> </operator> </process>
