localhost refused to connect".
rm.server.java.home=/Library/Java/JavaVirtualMachines/jdk1.8.0_211.jdk/Contents/Home
JAVA_HOME="/Library/Java/JavaVirtualMachines/jdk1.8.0_211.jdk/Contents/Home"
set "JAVA_HOME=/Library/Java/JavaVirtualMachines/jdk1.8.0_211.jdk/Contents/Home"<br>
localhost refused to connect.
java.home = C:\Program Files\Java\jdk-12.0.1 java.io.tmpdir = C:\Windows\TEMP\ java.library.path = C:\Program Files\Java\jdk-12.0.1\bin;C:\Windows\Sun\Java\bin;C:\Windows\system32;C:\Windows;C:\Windows\System32;C:\Program Files (x86)\Common Files\Oracle\Java\javapath;C:\Users\SK\AppData\Local\Microsoft\WindowsApps;C:\Users\SK\.dotnet\tools;. java.net.preferIPv4Stack = true java.runtime.name = Java(TM) SE Runtime Environment java.runtime.version = 12.0.1+12 java.specification.name = Java Platform API Specification java.specification.vendor = Oracle Corporation java.specification.version = 12 java.util.logging.manager = org.jboss.logmanager.LogManager java.vendor = Oracle Corporation java.vendor.url = https://java.oracle.com/ java.vendor.url.bug = https://bugreport.java.com/bugreport/ java.version = 12.0.1 java.version.date = 2019-04-16
SEVERE: Error trying to connect to the database! java.sql.SQLException: Access denied for user 'root'@'localhost' (using password: YES) at
