join object from different collection
Dear all, i made a process whiwh split two documents (in fonction on his column), the results is 2 collections in which I have a number of object (this number = the number of column), now I want to join two objects, one from the first collection and the other one from the other, I really need your help to do this.
Thank's !
here the code :
Thank's !
here the code :
<?xml version="1.0" encoding="UTF-8"?><process version="8.2.000">
<context>
<input/>
<output/>
<macros/>
</context>
<operator activated="true" class="process" compatibility="8.2.000" expanded="true" name="Process">
<process expanded="true">
<operator activated="true" class="retrieve" compatibility="8.2.000" expanded="true" height="68" name="Retrieve EEX Data" width="90" x="45" y="34">
<parameter key="repository_entry" value="//Local Repository/Alarm 11 data"/>
<operator activated="true" class="concurrency:loop_attributes" compatibility="8.2.000" expanded="true" height="82" name="Loop Attributes" width="90" x="313" y="34">
<parameter key="attributes" value="RT_3037_A - (DS 2215) Probe: Temperature - Supply [°C]|RT_3124_I - (DS 2332) Sensor: Air flow [Pa]|RT_3357_I - (DS ----) Alarm Codes []"/>
<parameter key="regular_expression" value="[a-zA-Z0-9\s]"/>
<operator activated="true" class="select_attributes" compatibility="8.2.000" expanded="true" height="82" name="Select Attributes" width="90" x="179" y="34">
<parameter key="attribute" value="F1BQ012018"/>
<parameter key="attributes" value="A|%{loop_attribute}"/>
<parameter key="regular_expression" value="F1BM"/>
<operator activated="true" class="store" compatibility="8.2.000" expanded="true" height="68" name="Store" width="90" x="514" y="34">
<parameter key="repository_entry" value="Alarm 11 data."/>
<connect from_port="input 1" to_op="Select Attributes" to_port="example set input"/>
<connect from_op="Select Attributes" from_port="example set output" to_op="Store" to_port="input"/>
<connect from_op="Store" from_port="through" to_port="output 1"/>
<portSpacing port="sink_output 1" spacing="0"/>
<portSpacing port="sink_output 2" spacing="0"/>
</process>
<operator activated="true" class="retrieve" compatibility="8.2.000" expanded="true" height="68" name="Retrieve" width="90" x="45" y="187">
<parameter key="repository_entry" value="//Local Repository/format_alarme_11"/>
<operator activated="true" class="transpose" compatibility="8.2.000" expanded="true" height="82" name="Transpose" width="90" x="246" y="187"/>
<operator activated="true" class="concurrency:loop_attributes" compatibility="8.2.000" expanded="true" height="82" name="Loop Attributes (2)" width="90" x="380" y="187">
<parameter key="attributes" value="att_3|att_2|att_1"/>
<parameter key="attribute_name_macro" value="loop_attribute2"/>
<operator activated="true" class="select_attributes" compatibility="8.2.000" expanded="true" height="82" name="Select Attributes (2)" width="90" x="112" y="34">
<parameter key="attributes" value="id|%{loop_attribute2}"/>
<connect from_port="input 1" to_op="Select Attributes (2)" to_port="example set input"/>
<connect from_op="Select Attributes (2)" from_port="example set output" to_port="output 1"/>
</process>
<connect from_op="Retrieve EEX Data" from_port="output" to_op="Loop Attributes" to_port="input 1"/>
<connect from_op="Loop Attributes" from_port="output 1" to_port="result 1"/>
<connect from_op="Retrieve" from_port="output" to_op="Transpose" to_port="example set input"/>
<connect from_op="Transpose" from_port="example set output" to_op="Loop Attributes (2)" to_port="input 1"/>
<connect from_op="Loop Attributes (2)" from_port="output 1" to_port="result 2"/>
</process>
</process>
1 - 2 of
21
Scott
