Hi !
I have applied attached stability process but I am not sure if I correctly selected log parameters for for jaccard and kuncheva indexes. Could you please help me to correct the process and advice how can I interpret the results of kucheva and jaccard index ?
<?xml version="1.0" encoding="UTF-8"?><process version="8.0.001">
<context>
<input/>
<output/>
<macros/>
</context>
<operator activated="true" class="process" compatibility="6.0.002" expanded="true" name="Process">
<process expanded="true">
<operator activated="true" class="read_excel" compatibility="8.0.001" expanded="true" height="68" name="Read Excel" width="90" x="179" y="34">
<parameter key="excel_file" value="C:\Users\AngelsChange\Desktop\SPSS-TEZ\Descriptive 2\MACRO\MACRO_KNN.xlsx"/>
<parameter key="imported_cell_range" value="A1:AQ1100"/>
<parameter key="first_row_as_names" value="false"/>
<list key="annotations">
<parameter key="0" value="Name"/>
</list>
<parameter key="0" value="ID.false.integer.attribute"/>
<parameter key="1" value="DISEASE_DURATION.true.integer.attribute"/>
<parameter key="2" value="AGE.true.integer.attribute"/>
<parameter key="3" value="WEIGHT.true.numeric.attribute"/>
<parameter key="4" value="HEIGHT.true.real.attribute"/>
<parameter key="5" value="BMI.true.real.attribute"/>
<parameter key="6" value="FBG.true.integer.attribute"/>
<parameter key="7" value="PBG.true.numeric.attribute"/>
<parameter key="8" value="HbA1c.true.numeric.attribute"/>
<parameter key="9" value="FBG_HbA1c.true.real.attribute"/>
<parameter key="10" value="PBG_HbA1c.true.numeric.attribute"/>
<parameter key="11" value="TColl.true.numeric.attribute"/>
<parameter key="12" value="TG.true.integer.attribute"/>
<parameter key="13" value="HDLK.true.numeric.attribute"/>
<parameter key="14" value="LDLK.true.numeric.attribute"/>
<parameter key="15" value="LDL_HDL.true.numeric.attribute"/>
<parameter key="16" value="TColl_HDL.true.numeric.attribute"/>
<parameter key="17" value="Cr.true.numeric.attribute"/>
<parameter key="18" value="ALB.true.numeric.attribute"/>
<parameter key="19" value="ALB_CR.true.numeric.attribute"/>
<parameter key="20" value="GFR.true.numeric.attribute"/>
<parameter key="21" value="CCI.true.integer.attribute"/>
<parameter key="22" value="CONTROL_7\.5.true.integer.attribute"/>
<parameter key="23" value="CONTROL_6.true.integer.attribute"/>
<parameter key="24" value="CONTROL_6\.5.true.integer.attribute"/>
<parameter key="25" value="CONTROL_7.true.integer.attribute"/>
<parameter key="26" value="GENDER.true.integer.attribute"/>
<parameter key="27" value="BACKGROUND_INFORMATION.true.integer.attribute"/>
<parameter key="28" value="FAMILY_HEALTH_STORY.true.integer.attribute"/>
<parameter key="29" value="INSULINE_TREATMENT.true.integer.attribute"/>
<parameter key="30" value="BMI_DEGREE.true.integer.attribute"/>
<parameter key="31" value="PATIENTS_STATUS.true.integer.attribute"/>
<parameter key="32" value="SMOKING_HABIT.true.integer.attribute"/>
<parameter key="33" value="HYPERTENSION.true.integer.attribute"/>
<parameter key="34" value="MACRO.true.binominal.label"/>
<parameter key="35" value="MICRO.true.integer.attribute"/>
<parameter key="36" value="CODISEASE.true.integer.attribute"/>
<parameter key="37" value="HBA1C_DEGREE.true.integer.attribute"/>
<parameter key="38" value="GLUCOSE_LEVEL_RISK_DEGREE.true.integer.attribute"/>
<parameter key="39" value="LIPID_PROFILE.true.integer.attribute"/>
<parameter key="40" value="CREATININE_DEGREE.true.integer.attribute"/>
<parameter key="41" value="ALBUMIN_DEGREE.true.integer.attribute"/>
<parameter key="42" value="GFR_DEGREE.true.integer.attribute"/>
</list>
<operator activated="true" class="concurrency:loop_parameters" compatibility="8.0.001" expanded="true" height="82" name="Loop Parameters (2)" width="90" x="380" y="85">
<list key="parameters">
<parameter key="MRMR-FS (2).relevance_redundancy_relation" value="quotient,difference"/>
<parameter key="Stability (2).sampling_type" value="linear sampling,shuffled sampling,stratified sampling,automatic"/>
<parameter key="MRMR-FS (2).k" value="[0.0;100.0;10;linear]"/>
</list>
<operator activated="true" class="featselext:feature_selection_stability_evaluator" compatibility="1.1.004" expanded="true" height="103" name="Stability (2)" width="90" x="112" y="136">
<parameter key="sampling_type" value="automatic"/>
<operator activated="true" class="featselext:mrmr_feature_selection" compatibility="1.1.004" expanded="true" height="82" name="MRMR-FS (2)" width="90" x="313" y="187">
<parameter key="normalize_weights" value="true"/>
<parameter key="k" value="50"/>
<parameter key="relevance_redundancy_relation" value="difference"/>
<connect from_port="exampleset" to_op="MRMR-FS (2)" to_port="example set"/>
<connect from_op="MRMR-FS (2)" from_port="weights" to_port="weights"/>
<portSpacing port="source_exampleset" spacing="0"/>
<portSpacing port="sink_weights" spacing="0"/>
</process>
<operator activated="true" class="log" compatibility="8.0.001" expanded="true" height="103" name="Log (2)" width="90" x="313" y="136">
<parameter key="filename" value="C:\Users\AngelsChange\Desktop\wer.log"/>
<list key="log">
<parameter key="jaccard" value="operator.Stability (2).value.robustness"/>
<parameter key="kuncheva" value="operator.Stability (2).value.consistency"/>
</list>
<connect from_port="input 1" to_op="Stability (2)" to_port="exampleset"/>
<connect from_op="Stability (2)" from_port="robustness" to_op="Log (2)" to_port="through 1"/>
<connect from_op="Stability (2)" from_port="kuncheva" to_op="Log (2)" to_port="through 2"/>
<connect from_op="Log (2)" from_port="through 1" to_port="performance"/>
<connect from_op="Log (2)" from_port="through 2" to_port="output 1"/>
<portSpacing port="sink_performance" spacing="0"/>
<portSpacing port="sink_output 1" spacing="0"/>
<portSpacing port="sink_output 2" spacing="0"/>
</process>
<connect from_port="input 1" to_op="Read Excel" to_port="file"/>
<connect from_op="Read Excel" from_port="output" to_op="Loop Parameters (2)" to_port="input 1"/>
<connect from_op="Loop Parameters (2)" from_port="output 1" to_port="result 2"/>
</process>
</process>
