Dear Community,
my question is - how (or is this possible) to achieve parallel execution of the "Execute R" operator inside a "Loop" operator.
I have a Collection of example sets and for every example set I want to perform some calculation using the "Execute R" operator. I enable the parallel execution checkbox expecting that it will run Rscript.exe in parallel. However, it is not.
I attach an example process:
<?xml version="1.0" encoding="UTF-8"?><process version="9.2.001"><br> <context><br> <input/><br> <output/><br> <macros/><br> </context><br> <operator activated="true" class="process" compatibility="9.2.001" expanded="true" name="Process"><br> <parameter key="logverbosity" value="init"/><br> <parameter key="random_seed" value="2001"/><br> <parameter key="send_mail" value="never"/><br> <parameter key="notification_email" value=""/><br> <parameter key="process_duration_for_mail" value="30"/><br> <parameter key="encoding" value="SYSTEM"/><br> <process expanded="true"><br> <operator activated="true" class="concurrency:loop" compatibility="9.2.001" expanded="true" height="82" name="Generate Data" width="90" x="179" y="187"><br> <parameter key="number_of_iterations" value="50"/><br> <parameter key="iteration_macro" value="iteration"/><br> <parameter key="reuse_results" value="false"/><br> <parameter key="enable_parallel_execution" value="true"/><br> <process expanded="true"><br> <operator activated="true" class="utility:create_exampleset" compatibility="9.2.001" expanded="true" height="68" name="Create ExampleSet" width="90" x="112" y="85"><br> <parameter key="generator_type" value="numeric series"/><br> <parameter key="number_of_examples" value="1000"/><br> <parameter key="use_stepsize" value="true"/><br> <list key="function_descriptions"/><br> <parameter key="add_id_attribute" value="false"/><br> <list key="numeric_series_configuration"><br> <parameter key="Att1" value="linear.0\.0.1\.0"/><br> </list><br> <list key="date_series_configuration"/><br> <list key="date_series_configuration (interval)"/><br> <parameter key="date_format" value="yyyy-MM-dd HH:mm:ss"/><br> <parameter key="time_zone" value="SYSTEM"/><br> <parameter key="column_separator" value=","/><br> <parameter key="parse_all_as_nominal" value="false"/><br> <parameter key="decimal_point_character" value="."/><br> <parameter key="trim_attribute_names" value="true"/><br> </operator><br> <connect from_op="Create ExampleSet" from_port="output" to_port="output 1"/><br> <portSpacing port="source_input 1" spacing="0"/><br> <portSpacing port="sink_output 1" spacing="0"/><br> <portSpacing port="sink_output 2" spacing="0"/><br> </process><br> </operator><br> <operator activated="true" class="concurrency:loop" compatibility="9.2.001" expanded="true" height="82" name="Execute R Script" width="90" x="380" y="187"><br> <parameter key="number_of_iterations" value="50"/><br> <parameter key="iteration_macro" value="iteration"/><br> <parameter key="reuse_results" value="false"/><br> <parameter key="enable_parallel_execution" value="true"/><br> <process expanded="true"><br> <operator activated="true" class="select" compatibility="9.2.001" expanded="true" height="68" name="Select" width="90" x="179" y="85"><br> <parameter key="index" value="%{iteration}"/><br> <parameter key="unfold" value="false"/><br> </operator><br> <operator activated="true" class="r_scripting:execute_r" compatibility="9.1.000" expanded="true" height="103" name="Execute R" width="90" x="380" y="85"><br> <parameter key="script" value="# rm_main is a mandatory function, # the number of arguments has to be the number of input ports (can be none) rm_main = function(data) { 	res <- mean(data$Att1) 	library(qdapTools) 	return (list2df(res)) } "/><br> </operator><br> <connect from_port="input 1" to_op="Select" to_port="collection"/><br> <connect from_op="Select" from_port="selected" to_op="Execute R" to_port="input 1"/><br> <connect from_op="Execute R" from_port="output 1" to_port="output 1"/><br> <portSpacing port="source_input 1" spacing="0"/><br> <portSpacing port="source_input 2" spacing="0"/><br> <portSpacing port="sink_output 1" spacing="0"/><br> <portSpacing port="sink_output 2" spacing="0"/><br> </process><br> </operator><br> <connect from_op="Generate Data" from_port="output 1" to_op="Execute R Script" to_port="input 1"/><br> <connect from_op="Execute R Script" from_port="output 1" to_port="result 1"/><br> <portSpacing port="source_input 1" spacing="0"/><br> <portSpacing port="sink_result 1" spacing="0"/><br> <portSpacing port="sink_result 2" spacing="0"/><br> </process><br> </operator><br></process>Could you please help me, how to fix that?
Regards
Maciek
