<?xml version="1.0" encoding="UTF-8"?><process version="9.2.001"> <context> <input/> <output/> <macros/> </context> <operator activated="true" class="process" compatibility="9.2.001" expanded="true" name="Process"> <parameter key="logverbosity" value="init"/> <parameter key="random_seed" value="2001"/> <parameter key="send_mail" value="never"/> <parameter key="notification_email" value=""/> <parameter key="process_duration_for_mail" value="30"/> <parameter key="encoding" value="SYSTEM"/> <process expanded="true"> <operator activated="true" class="utility:create_exampleset" compatibility="9.2.001" expanded="true" height="68" name="Create ExampleSet" width="90" x="112" y="85"> <parameter key="generator_type" value="comma separated text"/> <parameter key="number_of_examples" value="100"/> <parameter key="use_stepsize" value="false"/> <list key="function_descriptions"/> <parameter key="add_id_attribute" value="false"/> <list key="numeric_series_configuration"/> <list key="date_series_configuration"/> <list key="date_series_configuration (interval)"/> <parameter key="date_format" value="yyyy-MM-dd HH:mm:ss"/> <parameter key="time_zone" value="SYSTEM"/> <parameter key="input_csv_text" value="X1,average-std,average+std 1,1.4,3.434 2,1.4,3.434 3.5,1.4,3.434"/> <parameter key="column_separator" value=","/> <parameter key="parse_all_as_nominal" value="false"/> <parameter key="decimal_point_character" value="."/> <parameter key="trim_attribute_names" value="true"/> </operator> <operator activated="true" class="generate_attributes" compatibility="9.2.001" expanded="true" height="82" name="Generate Attributes" width="90" x="246" y="85"> <list key="function_descriptions"> <parameter key="generated_attribute" value="if(X1<[average-std],1,if(X1>[average+std],3,2))"/> </list> <parameter key="keep_all" value="true"/> </operator> <connect from_op="Create ExampleSet" from_port="output" to_op="Generate Attributes" to_port="example set input"/> <connect from_op="Generate Attributes" from_port="example set output" to_port="result 1"/> <portSpacing port="source_input 1" spacing="0"/> <portSpacing port="sink_result 1" spacing="0"/> <portSpacing port="sink_result 2" spacing="0"/> </process> </operator> </process>
<?xml version="1.0" encoding="UTF-8"?><process version="9.2.001"><br> <context><br> <input/><br> <output/><br> <macros/><br> </context><br> <operator activated="true" class="process" compatibility="9.2.001" expanded="true" name="Process"><br> <parameter key="logverbosity" value="init"/><br> <parameter key="random_seed" value="2001"/><br> <parameter key="send_mail" value="never"/><br> <parameter key="notification_email" value=""/><br> <parameter key="process_duration_for_mail" value="30"/><br> <parameter key="encoding" value="UTF-8"/><br> <process expanded="true"><br> <operator activated="true" class="retrieve" compatibility="9.2.001" expanded="true" height="68" name="Retrieve Iris" width="90" x="45" y="34"><br> <parameter key="repository_entry" value="//Samples/data/Iris"/><br> </operator><br> <operator activated="true" class="extract_macro" compatibility="9.2.001" expanded="true" height="68" name="Extract Avg" width="90" x="179" y="34"><br> <parameter key="macro" value="a1_avg"/><br> <parameter key="macro_type" value="statistics"/><br> <parameter key="statistics" value="average"/><br> <parameter key="attribute_name" value="a1"/><br> <list key="additional_macros"/><br> </operator><br> <operator activated="true" class="extract_macro" compatibility="9.2.001" expanded="true" height="68" name="Extract SD" width="90" x="313" y="34"><br> <parameter key="macro" value="a1_std_dev"/><br> <parameter key="macro_type" value="statistics"/><br> <parameter key="statistics" value="deviation"/><br> <parameter key="attribute_name" value="a1"/><br> <list key="additional_macros"/><br> </operator><br> <operator activated="true" class="generate_attributes" compatibility="9.2.001" expanded="true" height="82" name="Generate Attributes" width="90" x="447" y="34"><br> <list key="function_descriptions"><br> <parameter key="a1_new" value="if(a1<eval(%{a1_avg})-eval(%{a1_std_dev}),1,if(a1>eval(%{a1_avg})+eval(%{a1_std_dev}),3,2))"/><br> </list><br> <parameter key="keep_all" value="true"/><br> </operator><br> <connect from_op="Retrieve Iris" from_port="output" to_op="Extract Avg" to_port="example set"/><br> <connect from_op="Extract Avg" from_port="example set" to_op="Extract SD" to_port="example set"/><br> <connect from_op="Extract SD" from_port="example set" to_op="Generate Attributes" to_port="example set input"/><br> <connect from_op="Generate Attributes" from_port="example set output" to_port="result 1"/><br> <portSpacing port="source_input 1" spacing="0"/><br> <portSpacing port="sink_result 1" spacing="0"/><br> <portSpacing port="sink_result 2" spacing="0"/><br> </process><br> </operator><br></process>
