Regression Tree Interpretation
islem_h
Hi everyone
After applying a model, I got this regression tree (see screenshot).
It is understandable, however can s.one give me an example of a clear interpretation of it?
Thank you very much!
Regression
varunm1
Hello
@islem_h
Generally, a decision tree is formed based on rules. These rules can be extracted by "Tree to rules" operator or other like the one mentioned in an earlier post.
From the image you show, these are nested if-else statements that were formed by a decision tree based on its learning from your data.
If the attribute Acrooms value is greater than 4.3 then the tree check for a value in ELwater then if this is 0 it checks Acrooms again and if the value is greater than 7.5 it gives output 16646.31. Similarly all other outputs are interpreted.
sgenzer
I would also recommend
this lesson in the RapidMiner Academy on Decision Trees
Scott
varunm1
Did you try Get Decision Tree path (need to install operator toolbox extension) as mentioned by
@yyhuang
. This gives the tree structure and description as well. It starts from top and branches out. You can see image below.
<?xml version="1.0" encoding="UTF-8"?><process version="9.2.001">
<context>
<input/>
<output/>
<macros/>
</context>
<operator activated="true" class="process" compatibility="9.2.001" expanded="true" name="Process">
<process expanded="true">
<operator activated="true" class="retrieve" compatibility="9.2.001" expanded="true" height="68" name="Retrieve Polynomial" width="90" x="112" y="34">
<parameter key="repository_entry" value="//Samples/data/Polynomial"/>
<operator activated="true" class="concurrency:parallel_decision_tree" compatibility="9.2.001" expanded="true" height="103" name="Decision Tree" width="90" x="246" y="34">
<parameter key="criterion" value="least_square"/>
<parameter key="maximal_depth" value="10"/>
<parameter key="apply_pruning" value="true"/>
<parameter key="confidence" value="0.1"/>
<parameter key="apply_prepruning" value="true"/>
<parameter key="minimal_gain" value="0.01"/>
<parameter key="minimal_leaf_size" value="2"/>
<parameter key="minimal_size_for_split" value="4"/>
<parameter key="number_of_prepruning_alternatives" value="3"/>
<operator activated="true" class="operator_toolbox:get_dectree_path" compatibility="1.8.000" expanded="true" height="82" name="Get Decision Tree Path" width="90" x="447" y="136"/>
<connect from_op="Retrieve Polynomial" from_port="output" to_op="Decision Tree" to_port="training set"/>
<connect from_op="Decision Tree" from_port="model" to_op="Get Decision Tree Path" to_port="mod"/>
<connect from_op="Decision Tree" from_port="exampleSet" to_op="Get Decision Tree Path" to_port="exa"/>
<connect from_op="Get Decision Tree Path" from_port="mod" to_port="result 1"/>
</process>
</process>
YYH
Hi
@islem_h
Have you tried the "Explain Predictions" operator and for trees we can extract the rules/path of the prediction
Best,
YY
varunm1
Hello
@islem_h
sgenzer
Scott
islem_h
Thank you for the detailed answer
@varunm1
The "tree to rules" operator doesn't support numerical variables and it is a regression task that I have at hand with numerous numerical attributes. How should I proceed in your opinion?
varunm1
@yyhuang
<context>
<input/>
<output/>
<macros/>
</context>
</process>
</process>
islem_h
Thank you very much
