LOF on Text Data
User: "tamberge"
New Altair Community Member
Updated by Jocelyn
Hello Team,
I am fairly new to RM and currently conducting some research on online text.
In particular I am trying to detect outliers from an set of documents by using the LOF operator.
Now I have some troubles, since the LOF for each document is very close to 1, no matter how I set the MinPtsUB and MinPtsLB.
Basically I have represented the each document as vector of term frequency and TF-IDF, before applying the LOF operator.
So I have two ExampleSets representing the corpus as, a matrix of TF values and a matrix of TF-IDF values, to check the differences.
However, for both matrices I get LOF values that are equal or very close to one, which does not make any sence to me.
Could you tell me, if and what I am doing wrong?
Best
Please find my XML enclosed:
  <?xml version="1.0" encoding="UTF-8" ?>
- <process version="9.2.000">
- <context>
  <input />
  <output />
  <macros />
  </context>
- <operator activated="true" class="process" compatibility="9.2.000" expanded="true" name="Process">
  <parameter key="logverbosity" value="init" />
  <parameter key="random_seed" value="2001" />
  <parameter key="send_mail" value="never" />
  <parameter key="notification_email" value="" />
  <parameter key="process_duration_for_mail" value="30" />
  <parameter key="encoding" value="SYSTEM" />
- <process expanded="true">
- <operator activated="true" class="retrieve" compatibility="9.2.000" expanded="true" height="68" name="Retrieve PreppedTestData" width="90" x="112" y="34">
  <parameter key="repository_entry" value="../Data/PreppedDatabase_TF" />
- <operator activated="true" class="select_attributes" compatibility="9.2.000" expanded="true" height="82" name="Select Attributes" width="90" x="246" y="34">
  <parameter key="attribute_filter_type" value="value_type" />
  <parameter key="attribute" value="" />
  <parameter key="attributes" value="Date" />
  <parameter key="use_except_expression" value="false" />
  <parameter key="value_type" value="real" />
  <parameter key="use_value_type_exception" value="false" />
  <parameter key="except_value_type" value="time" />
  <parameter key="block_type" value="attribute_block" />
  <parameter key="use_block_type_exception" value="false" />
  <parameter key="except_block_type" value="value_matrix_row_start" />
  <parameter key="invert_selection" value="false" />
  <parameter key="include_special_attributes" value="true" />
- <operator activated="true" class="detect_outlier_lof" compatibility="9.2.000" expanded="true" height="82" name="Detect Outlier (LOF)" width="90" x="447" y="34">
  <parameter key="minimal_points_lower_bound" value="1" />
  <parameter key="minimal_points_upper_bound" value="3" />
  <parameter key="distance_function" value="euclidian distance" />
- <operator activated="false" class="anomalydetection:Local Outlier Factor (LOF)" compatibility="2.4.001" expanded="true" height="103" name="Local Outlier Factor (LOF)" width="90" x="380" y="340">
  <parameter key="k_min (MinPtsLB)" value="1" />
  <parameter key="k_max (MinPtsUB)" value="10" />
  <parameter key="measure_types" value="MixedMeasures" />
  <parameter key="mixed_measure" value="MixedEuclideanDistance" />
  <parameter key="nominal_measure" value="NominalDistance" />
  <parameter key="numerical_measure" value="EuclideanDistance" />
  <parameter key="divergence" value="GeneralizedIDivergence" />
  <parameter key="kernel_type" value="radial" />
  <parameter key="kernel_gamma" value="1.0" />
  <parameter key="kernel_sigma1" value="1.0" />
  <parameter key="kernel_sigma2" value="0.0" />
  <parameter key="kernel_sigma3" value="2.0" />
  <parameter key="kernel_degree" value="3.0" />
  <parameter key="kernel_shift" value="1.0" />
  <parameter key="kernel_a" value="1.0" />
  <parameter key="kernel_b" value="0.0" />
  <parameter key="parallelize evaluation process" value="false" />
  <parameter key="number of threads" value="4" />
- <operator activated="true" class="store" compatibility="9.2.000" expanded="true" height="68" name="Store" width="90" x="648" y="34">
  <parameter key="repository_entry" value="../Results/LOF_TF" />
- <operator activated="false" class="write_excel" compatibility="9.2.000" expanded="true" height="82" name="Write Excel" width="90" x="581" y="442">
  <parameter key="excel_file" value="\\ads.dlh.de\lhuser$\LHT\HAM99\U801591\Documents\000_Masterarbeit\05_Praxis\04_LOF - Outlier Detection\042_Results\LOF_TF.xlsx" />
  <parameter key="file_format" value="xlsx" />
  <parameter key="sheet_name" value="LOF_TF" />
  <parameter key="date_format" value="yyyy-MM-dd HH:mm:ss" />
  <parameter key="number_format" value="#.0" />
- <operator activated="true" class="retrieve" compatibility="9.2.000" expanded="true" height="68" name="Retrieve PreppedTestData (2)" width="90" x="112" y="187">
  <parameter key="repository_entry" value="../Data/PreppedDatabase_TF-IDF" />
- <operator activated="true" class="select_attributes" compatibility="9.2.000" expanded="true" height="82" name="Select Attributes (2)" width="90" x="246" y="187">
- <operator activated="true" class="detect_outlier_lof" compatibility="9.2.000" expanded="true" height="82" name="Detect Outlier (2)" width="90" x="447" y="187">
- <operator activated="false" class="anomalydetection:Local Outlier Factor (LOF)" compatibility="2.4.001" expanded="true" height="103" name="Local Outlier Factor (2)" width="90" x="380" y="493">
- <operator activated="true" class="store" compatibility="9.2.000" expanded="true" height="68" name="Store (2)" width="90" x="648" y="187">
  <parameter key="repository_entry" value="../Results/LOF_TF-IDF" />
- <operator activated="false" class="write_excel" compatibility="9.2.000" expanded="true" height="82" name="Write Excel (2)" width="90" x="648" y="595">
  <parameter key="excel_file" value="\\ads.dlh.de\lhuser$\LHT\HAM99\U801591\Documents\000_Masterarbeit\05_Praxis\04_LOF - Outlier Detection\042_Results\LOF_TF-IDF.xlsx" />
  <parameter key="sheet_name" value="LOF_TF-IDF" />
  <connect from_op="Retrieve PreppedTestData" from_port="output" to_op="Select Attributes" to_port="example set input" />
  <connect from_op="Select Attributes" from_port="example set output" to_op="Detect Outlier (LOF)" to_port="example set input" />
  <connect from_op="Detect Outlier (LOF)" from_port="example set output" to_op="Store" to_port="input" />
  <connect from_op="Store" from_port="through" to_port="result 1" />
  <connect from_op="Retrieve PreppedTestData (2)" from_port="output" to_op="Select Attributes (2)" to_port="example set input" />
  <connect from_op="Select Attributes (2)" from_port="example set output" to_op="Detect Outlier (2)" to_port="example set input" />
  <connect from_op="Detect Outlier (2)" from_port="example set output" to_op="Store (2)" to_port="input" />
  <connect from_op="Store (2)" from_port="through" to_port="result 2" />
  <portSpacing port="source_input 1" spacing="0" />
  <portSpacing port="sink_result 1" spacing="0" />
  <portSpacing port="sink_result 2" spacing="0" />
  <portSpacing port="sink_result 3" spacing="0" />
  </process>
  </process>
1 - 1 of 11
    User: "tamberge"
    OP
    Accepted Answer
    So I have been trying different methods in all possible combinations for a test set of 26 examples:
    changing MinPts UB and LB, (1-2, 2-3, 5-10)
    choosing different vectors (TF,TF-IDC, Term Occurence, Binary Term Occurence),
    pruning (filtering frequent words, and filtering unfrequent words)
    However, I was not able to get values that are LOF >> 1.
    So does anyone have a theory, where this is coming from?
    I can also share the data, if you want.
