<?xml version="1.0" encoding="UTF-8"?><process version="9.2.001"> <context> <input/> <output/> <macros/> </context> <operator activated="true" class="process" compatibility="9.2.001" expanded="true" name="Process" origin="GENERATED_TUTORIAL"> <parameter key="logverbosity" value="init"/> <parameter key="random_seed" value="2001"/> <parameter key="send_mail" value="never"/> <parameter key="notification_email" value=""/> <parameter key="process_duration_for_mail" value="30"/> <parameter key="encoding" value="SYSTEM"/> <process expanded="true"> <operator activated="true" class="retrieve" compatibility="9.2.001" expanded="true" height="68" name="Weighting" origin="GENERATED_TUTORIAL" width="90" x="112" y="30"> <parameter key="repository_entry" value="//Samples/data/Weighting"/> </operator> <operator activated="true" class="concurrency:optimize_parameters_grid" compatibility="8.2.000" expanded="true" height="124" name="Optimize Parameters (Grid)" origin="GENERATED_TUTORIAL" width="90" x="447" y="34"> <list key="parameters"> <parameter key="SVM.C" value="[0.001;100000;10;logarithmic]"/> <parameter key="SVM.gamma" value="[0.001;1.5;10;logarithmic]"/> </list> <parameter key="error_handling" value="fail on error"/> <parameter key="log_performance" value="true"/> <parameter key="log_all_criteria" value="true"/> <parameter key="synchronize" value="false"/> <parameter key="enable_parallel_execution" value="true"/> <process expanded="true"> <operator activated="true" class="split_data" compatibility="9.2.001" expanded="true" height="103" name="Split Data" origin="GENERATED_TUTORIAL" width="90" x="45" y="30"> <enumeration key="partitions"> <parameter key="ratio" value="0.5"/> <parameter key="ratio" value="0.5"/> </enumeration> <parameter key="sampling_type" value="automatic"/> <parameter key="use_local_random_seed" value="true"/> <parameter key="local_random_seed" value="1992"/> </operator> <operator activated="true" class="support_vector_machine_libsvm" compatibility="9.2.001" expanded="true" height="82" name="SVM" origin="GENERATED_TUTORIAL" width="90" x="179" y="85"> <parameter key="svm_type" value="C-SVC"/> <parameter key="kernel_type" value="rbf"/> <parameter key="degree" value="3"/> <parameter key="gamma" value="1.5"/> <parameter key="coef0" value="0.0"/> <parameter key="C" value="100000.0"/> <parameter key="nu" value="0.5"/> <parameter key="cache_size" value="80"/> <parameter key="epsilon" value="0.001"/> <parameter key="p" value="0.1"/> <list key="class_weights"/> <parameter key="shrinking" value="true"/> <parameter key="calculate_confidences" value="false"/> <parameter key="confidence_for_multiclass" value="true"/> </operator> <operator activated="true" class="apply_model" compatibility="9.2.001" expanded="true" height="82" name="Apply Model" origin="GENERATED_TUTORIAL" width="90" x="447" y="30"> <list key="application_parameters"/> <parameter key="create_view" value="false"/> </operator> <operator activated="true" class="performance_binominal_classification" compatibility="9.2.001" expanded="true" height="82" name="Performance (2)" width="90" x="782" y="34"> <parameter key="main_criterion" value="f_measure"/> <parameter key="accuracy" value="true"/> <parameter key="classification_error" value="false"/> <parameter key="kappa" value="false"/> <parameter key="AUC (optimistic)" value="false"/> <parameter key="AUC" value="false"/> <parameter key="AUC (pessimistic)" value="false"/> <parameter key="precision" value="false"/> <parameter key="recall" value="false"/> <parameter key="lift" value="false"/> <parameter key="fallout" value="false"/> <parameter key="f_measure" value="true"/> <parameter key="false_positive" value="false"/> <parameter key="false_negative" value="false"/> <parameter key="true_positive" value="false"/> <parameter key="true_negative" value="false"/> <parameter key="sensitivity" value="true"/> <parameter key="specificity" value="false"/> <parameter key="youden" value="false"/> <parameter key="positive_predictive_value" value="false"/> <parameter key="negative_predictive_value" value="false"/> <parameter key="psep" value="false"/> <parameter key="skip_undefined_labels" value="true"/> <parameter key="use_example_weights" value="true"/> </operator> <connect from_port="input 1" to_op="Split Data" to_port="example set"/> <connect from_op="Split Data" from_port="partition 1" to_op="Apply Model" to_port="unlabelled data"/> <connect from_op="Split Data" from_port="partition 2" to_op="SVM" to_port="training set"/> <connect from_op="SVM" from_port="model" to_op="Apply Model" to_port="model"/> <connect from_op="Apply Model" from_port="labelled data" to_op="Performance (2)" to_port="labelled data"/> <connect from_op="Performance (2)" from_port="performance" to_port="performance"/> <portSpacing port="source_input 1" spacing="0"/> <portSpacing port="source_input 2" spacing="0"/> <portSpacing port="sink_performance" spacing="0"/> <portSpacing port="sink_model" spacing="0"/> <portSpacing port="sink_output 1" spacing="0"/> </process> </operator> <connect from_op="Weighting" from_port="output" to_op="Optimize Parameters (Grid)" to_port="input 1"/> <connect from_op="Optimize Parameters (Grid)" from_port="performance" to_port="result 1"/> <connect from_op="Optimize Parameters (Grid)" from_port="parameter set" to_port="result 2"/> <portSpacing port="source_input 1" spacing="0"/> <portSpacing port="sink_result 1" spacing="0"/> <portSpacing port="sink_result 2" spacing="18"/> <portSpacing port="sink_result 3" spacing="0"/> </process> </operator> </process>
