idk why is that happening,plz help
here is the xml:
<?xml version="1.0" encoding="UTF-8"?><process version="9.2.000">
<context>
<input/>
<output/>
<macros/>
</context>
<operator activated="true" class="process" compatibility="9.2.000" expanded="true" name="Process">
<process expanded="true">
<operator activated="true" class="jdbc_connectors:read_database" compatibility="9.2.000" expanded="true" height="68" name="Read Database" width="90" x="45" y="34">
<parameter key="define_connection" value="predefined"/>
<parameter key="connection" value="SQL Server Connection"/>
<parameter key="database_system" value="MySQL"/>
<parameter key="define_query" value="table name"/>
<parameter key="use_default_schema" value="true"/>
<parameter key="table_name" value="diabetes_dataset"/>
<parameter key="prepare_statement" value="false"/>
<enumeration key="parameters"/>
<parameter key="datamanagement" value="double_array"/>
<parameter key="data_management" value="auto"/>
<operator activated="true" class="set_role" compatibility="9.2.000" expanded="true" height="82" name="Set Role" width="90" x="179" y="34">
<parameter key="attribute_name" value="Outcome"/>
<operator activated="true" class="select_attributes" compatibility="9.2.000" expanded="true" height="82" name="Select Attributes" width="90" x="313" y="34">
<parameter key="attribute" value="CNIC"/>
<operator activated="true" class="neural_net" compatibility="9.2.000" expanded="true" height="82" name="Neural Net" width="90" x="514" y="85">
<list key="hidden_layers"/>
<parameter key="training_cycles" value="200"/>
<parameter key="learning_rate" value="0.01"/>
<parameter key="momentum" value="0.9"/>
<parameter key="decay" value="false"/>
<parameter key="shuffle" value="true"/>
<parameter key="normalize" value="true"/>
<parameter key="error_epsilon" value="1.0E-4"/>
<parameter key="use_local_random_seed" value="false"/>
<parameter key="local_random_seed" value="1992"/>
<operator activated="true" class="jdbc_connectors:read_database" compatibility="9.2.000" expanded="true" height="68" name="Read Database (2)" width="90" x="45" y="187">
<parameter key="table_name" value="testing_dataset"/>
<operator activated="true" class="select_attributes" compatibility="9.2.000" expanded="true" height="82" name="Select Attributes (2)" width="90" x="246" y="187">
<operator activated="true" class="apply_model" compatibility="9.2.000" expanded="true" height="82" name="Apply Model" width="90" x="648" y="187">
<parameter key="create_view" value="false"/>
<operator activated="true" class="jdbc_connectors:write_database" compatibility="9.2.000" expanded="true" height="68" name="Write Database" width="90" x="782" y="34">
<parameter key="table_name" value="Prediction_Results"/>
<parameter key="overwrite_mode" value="overwrite"/>
<parameter key="set_default_varchar_length" value="false"/>
<parameter key="default_varchar_length" value="128"/>
<parameter key="add_generated_primary_keys" value="false"/>
<parameter key="db_key_attribute_name" value="generated_primary_key"/>
<parameter key="batch_size" value="1"/>
<connect from_op="Read Database" from_port="output" to_op="Set Role" to_port="example set input"/>
<connect from_op="Set Role" from_port="example set output" to_op="Select Attributes" to_port="example set input"/>
<connect from_op="Select Attributes" from_port="example set output" to_op="Neural Net" to_port="training set"/>
<connect from_op="Neural Net" from_port="model" to_op="Apply Model" to_port="model"/>
<connect from_op="Read Database (2)" from_port="output" to_op="Select Attributes (2)" to_port="example set input"/>
<connect from_op="Select Attributes (2)" from_port="example set output" to_op="Apply Model" to_port="unlabelled data"/>
<connect from_op="Apply Model" from_port="labelled data" to_op="Write Database" to_port="input"/>
<connect from_op="Write Database" from_port="through" to_port="result 1"/>
</process>
</process>
and here is the command im running from cmd:
C:\Users\Rapidminer\RapidMiner Studio\scripts>Rapidminer-batch.bat "//FYP Repository/Process/fyp_prediction_neuralnetwork"
