Is there a dynamic way to split a document ?
Hi, I'm currently spliting an excel sheet with the operator 'Split Data' , I split the document in 3 because he has 3 column.
I would like that regardless the document I have in input (always an Excel file), this one is split in fonction of his number of column. And so i don'd have to create manually the number of output that i want.
Is this possible ?
I hope to have be clear.
Thank's
Is this possible ?
Thank's
1 - 2 of
21
MartinLiebig
Hi @nic__o ,
so you want one example set per attribute? I guess Loop attribute + Select Attributes should do the trick in some way..
BR,
Martin
