Hey,
I am currently building a process for TextMining. I used the TF-IDF as a solution. Briefly and concisely, it's about extracting important information from news. I filter the messages by topic and date so that I can assign the information to the message.
A friend recommended the operator Select by Weights to me. However, I always get an error message with the code:
<?xml version="1.0" encoding="UTF-8"?><process version="9.2.001">
<context>
<input/>
<output/>
<macros/>
</context>
<operator activated="true" class="process" compatibility="9.2.001" expanded="true" name="Process">
<parameter key="encoding" value="UTF-8"/>
<process expanded="true">
<operator activated="true" class="retrieve" compatibility="9.2.001" expanded="true" height="68" name="Retrieve reut2-000" width="90" x="45" y="85">
<parameter key="repository_entry" value="reut2-000"/>
<operator activated="true" class="select_attributes" compatibility="9.2.001" expanded="true" height="82" name="Select Attributes" width="90" x="179" y="85">
<parameter key="attribute" value=""/>
<parameter key="attributes" value="|exchanges|orgs|people|text_orig|title|topics|zahlen"/>
<operator activated="true" class="generate_id" compatibility="9.2.001" expanded="true" height="82" name="Generate ID" width="90" x="313" y="85">
<parameter key="create_nominal_ids" value="false"/>
<parameter key="offset" value="0"/>
<operator activated="true" breakpoints="after" class="filter_examples" compatibility="9.2.001" expanded="true" height="103" name="Filter Examples" width="90" x="45" y="187">
<parameter key="parameter_expression" value=""/>
<parameter key="condition_class" value="custom_filters"/>
<parameter key="invert_filter" value="false"/>
<list key="filters_list">
<parameter key="filters_entry_key" value="places.does_not_equal.?"/>
</list>
<parameter key="filters_logic_and" value="true"/>
<parameter key="filters_check_metadata" value="true"/>
<operator activated="true" class="set_role" compatibility="9.2.001" expanded="true" height="82" name="Set Role" width="90" x="179" y="187">
<parameter key="attribute_name" value="places"/>
<operator activated="true" breakpoints="after" class="remove_correlated_attributes" compatibility="9.2.001" expanded="true" height="82" name="Remove Correlated Attributes" width="90" x="380" y="187">
<parameter key="correlation" value="0.8"/>
<parameter key="filter_relation" value="greater"/>
<parameter key="attribute_order" value="random"/>
<parameter key="use_absolute_correlation" value="true"/>
<parameter key="use_local_random_seed" value="false"/>
<parameter key="local_random_seed" value="1992"/>
<operator activated="true" class="subprocess" compatibility="9.2.001" expanded="true" height="124" name="Feature Engineering" width="90" x="581" y="85">
<operator activated="true" class="multiply" compatibility="9.2.001" expanded="true" height="124" name="Multiply (2)" width="90" x="112" y="187"/>
<operator activated="true" class="weight_by_chi_squared_statistic" compatibility="9.2.001" expanded="true" height="82" name="Weight by Chi Squared Statistic" width="90" x="313" y="34">
<parameter key="normalize_weights" value="false"/>
<parameter key="sort_weights" value="true"/>
<parameter key="sort_direction" value="descending"/>
<parameter key="number_of_bins" value="10"/>
<operator activated="true" breakpoints="after" class="select_by_weights" compatibility="9.2.001" expanded="true" height="103" name="Select by Weights (ChiSq)" width="90" x="514" y="34">
<parameter key="weight_relation" value="top k"/>
<parameter key="weight" value="10.0"/>
<parameter key="k" value="50"/>
<parameter key="p" value="0.1"/>
<parameter key="deselect_unknown" value="true"/>
<parameter key="use_absolute_weights" value="false"/>
<operator activated="true" class="store" compatibility="9.2.001" expanded="true" height="68" name="Store" width="90" x="715" y="34">
<operator activated="true" class="principal_component_analysis" compatibility="9.2.001" expanded="true" height="103" name="PCA" width="90" x="313" y="187">
<parameter key="dimensionality_reduction" value="keep variance"/>
<parameter key="variance_threshold" value="0.8"/>
<parameter key="number_of_components" value="1"/>
<operator activated="true" class="weight_by_pca" compatibility="9.2.001" expanded="true" height="82" name="Weight by PCA" width="90" x="313" y="340">
<parameter key="sort_direction" value="ascending"/>
<parameter key="component_number" value="1"/>
<operator activated="true" breakpoints="after" class="select_by_weights" compatibility="9.2.001" expanded="true" height="103" name="Select by Weights (PCA)" width="90" x="514" y="340">
<parameter key="use_absolute_weights" value="true"/>
<operator activated="true" class="store" compatibility="9.2.001" expanded="true" height="68" name="Store (3)" width="90" x="715" y="340">
<operator activated="true" class="store" compatibility="9.2.001" expanded="true" height="68" name="Store (2)" width="90" x="715" y="187">
<connect from_port="in 1" to_op="Multiply (2)" to_port="input"/>
<connect from_op="Multiply (2)" from_port="output 1" to_op="Weight by Chi Squared Statistic" to_port="example set"/>
<connect from_op="Multiply (2)" from_port="output 2" to_op="PCA" to_port="example set input"/>
<connect from_op="Multiply (2)" from_port="output 3" to_op="Weight by PCA" to_port="example set"/>
<connect from_op="Weight by Chi Squared Statistic" from_port="weights" to_op="Select by Weights (ChiSq)" to_port="weights"/>
<connect from_op="Weight by Chi Squared Statistic" from_port="example set" to_op="Select by Weights (ChiSq)" to_port="example set input"/>
<connect from_op="Select by Weights (ChiSq)" from_port="example set output" to_op="Store" to_port="input"/>
<connect from_op="Store" from_port="through" to_port="out 1"/>
<connect from_op="PCA" from_port="example set output" to_op="Store (2)" to_port="input"/>
<connect from_op="Weight by PCA" from_port="weights" to_op="Select by Weights (PCA)" to_port="weights"/>
<connect from_op="Weight by PCA" from_port="example set" to_op="Select by Weights (PCA)" to_port="example set input"/>
<connect from_op="Select by Weights (PCA)" from_port="example set output" to_op="Store (3)" to_port="input"/>
<connect from_op="Store (3)" from_port="through" to_port="out 3"/>
<connect from_op="Store (2)" from_port="through" to_port="out 2"/>
<portSpacing port="source_in 2" spacing="0"/>
<portSpacing port="sink_out 3" spacing="0"/>
<portSpacing port="sink_out 4" spacing="0"/>
</process>
<connect from_op="Retrieve reut2-000" from_port="output" to_op="Select Attributes" to_port="example set input"/>
<connect from_op="Select Attributes" from_port="example set output" to_op="Generate ID" to_port="example set input"/>
<connect from_op="Generate ID" from_port="example set output" to_op="Filter Examples" to_port="example set input"/>
<connect from_op="Filter Examples" from_port="example set output" to_op="Set Role" to_port="example set input"/>
<connect from_op="Set Role" from_port="example set output" to_op="Remove Correlated Attributes" to_port="example set input"/>
<connect from_op="Remove Correlated Attributes" from_port="example set output" to_op="Feature Engineering" to_port="in 1"/>
<connect from_op="Feature Engineering" from_port="out 1" to_port="result 1"/>
<connect from_op="Feature Engineering" from_port="out 2" to_port="result 2"/>
<connect from_op="Feature Engineering" from_port="out 3" to_port="result 3"/>
<description align="left" color="yellow" colored="false" height="278" resized="true" width="815" x="39" y="325">REDUKTION DER DIMENSIONALIT&#196;T<br/><br/>Hier geht hier darum, die Reduktion der Dimensionalit&#228;t anzustreben. Zwei m&#246;gliche Arten:<br>-- auf Basis PCA (braucht kein Zielvariable)<br>-- auf Basis ChiSquared (Zielvariable vorausus<br>Gibt es eine Zielvariable, so ist es m&#246;glich nur diejenigen Felder zu behalten, die hohes Potenzial f&#252;r ein Model haben.<br><br>Schritte:<br>a. Input Daten TF-IDF<br>b. Non-TFIDF Felder rausfiltern: exchanges, org, people, usw.<br>c. Filter nur Datens&#228;tze mit vollst&#228;ndigen Werte &#252;r Zielvariable<br>d. Entferne korrelierte TFIDF Felder<br>e. Verwende beiden Methoden zur Reduktion der Dimensionalit&#228;t. Daten speichern.<br><br></description>
<description align="left" color="yellow" colored="false" height="58" resized="true" width="301" x="177" y="22">F&#252;r die Reduktion der Dimensionalit&#228;t bleibt eine Zielvariable und die TF-IDF Felder.</description>
</process>
</process>
The Input is a CSV Data which i download from the Newsholding Reuters.
Thanks
