RapidMiner Server - R Script not found
maciekUser: "maciek"
New Altair Community Member
Updated by Jocelyn
Dear Community,
I recently installed RM Server 9.2.1 on the Windows computer I connect remotely. I am able to run all processes, except ones with the Execute R operator. The RapidMiner Studio is installed on that machine and references the same Rscript.exe. Studio - works. Server - not.
Error I get is:
Rscript not found
Failed to detect Rscript at the given path.
Process[1] (Process) subprocess 'Main Process' ==> +- Execute R[1] (Execute R)
<html>Please adjust the Rscript path in the Preferences.<br>(Tools -> Preferences -> R Scripting)</html>
My configuration entry:
rapidminer.r_scripting.path
points to:
C:\Program Files\R\R-3.5.3\bin\x64\Rscript.exe
(also tried to install R in other destinations and also to reference the 32-bit Rscript.exe)
I copied the extension  rmx_r_scripting-9.1.0.jar from my computer to the server in the rapidminer-server-home/resources/extensions directory.
Please, let me know if there is any solution for me. I also attach the error log hoping anybody can help.
Regards
Maciek
2019-04-02 00:44:15.238 INFO 4656 --- [main] c.r.execution.jobcontainer.Application : Starting Application on G-Tower with PID 4656 (D:\MARCIN\rapidminer-server\rapidminer-server-9.2.1\job-agent\lib\container\rapidminer-jobcontainer-0.6.3.jar started by G-TOWER$ in D:\MARCIN\rapidminer-server\rapidminer-server-9.2.1\bin) 2019-04-02 00:44:15.241 INFO 4656 --- [main] c.r.execution.jobcontainer.Application : No active profile set, falling back to default profiles: default 2019-04-02 00:44:15.400 INFO 4656 --- [main] s.c.a.AnnotationConfigApplicationContext : Refreshing org.springframework.context.annotation.AnnotationConfigApplicationContext@7eac9008: startup date [Tue Apr 02 00:44:15 CEST 2019]; root of context hierarchy 2019-04-02 00:44:16.284 INFO 4656 --- [main] o.s.s.c.ThreadPoolTaskScheduler : Initializing ExecutorService 'taskScheduler' 2019-04-02 00:44:16.895 INFO 4656 --- [main] o.s.j.e.a.AnnotationMBeanExporter : Registering beans for JMX exposure on startup 2019-04-02 00:44:16.901 INFO 4656 --- [main] o.s.c.support.DefaultLifecycleProcessor : Starting beans in phase 0 2019-04-02 00:44:16.943 INFO 4656 --- [taskScheduler-2] c.r.e.j.service.RemoteRepositoryService : Trying to update JWT token from auth properties. 2019-04-02 00:44:16.944 INFO 4656 --- [taskScheduler-2] c.r.e.j.service.RemoteRepositoryService : Updated JWT token from auth properties file. 2019-04-02 00:44:16.943 INFO 4656 --- [taskScheduler-1] c.r.e.j.service.OutOfMemoryWatchdog : Current memory usage is 544MB / 4064MB 2019-04-02 00:44:16.949 INFO 4656 --- [main] c.r.e.core.RapidMinerInitializer : Changing 'user.home' system property to 'D:\Marcin\rapidminer-server\rapidminer-server-home\job-agent-home\data\jobs\21b3e330-6cf4-4eee-9d71-54cc0604de0b' 2019-04-02 00:44:16.949 INFO 4656 --- [main] c.r.e.core.RapidMinerInitializer : Generating new in-memory cipher key 2019-04-02 00:44:17.063 INFO 4656 --- [main] c.r.e.core.RapidMinerInitializer : Setting pre-defined RapidMiner properties from 'D:\Marcin\rapidminer-server\rapidminer-server-home\job-agent-home\data\jobs\21b3e330-6cf4-4eee-9d71-54cc0604de0b\rapidminer.properties' 2019-04-02 00:44:17.216 INFO 4656 --- [main] c.r.e.core.RapidMinerInitializer : Initializing the RapidMiner Core 2019-04-02 00:44:17.216 INFO 4656 --- [main] c.r.e.core.RapidMinerInitializer : Setting execution mode to 'JOB_CONTAINER' 2019-04-02 00:44:17.228 INFO 4656 --- [main] c.r.e.core.RapidMinerInitializer : Loading bundled extension from 'D:\MARCIN\rapidminer-server\rapidminer-server-9.2.1\job-agent\bin\..\lib\container\plugins' 2019-04-02 00:44:17.228 INFO 4656 --- [main] c.r.e.core.RapidMinerInitializer : Loading custom extensions from 'D:\Marcin\rapidminer-server\rapidminer-server-home\job-agent-home\resources\extensions' 2019-04-02 00:44:17.329 INFO 4656 --- [main] com.rapidminer : Set locale to en. 2019-04-02 00:44:17.357 INFO 4656 --- [main] PlatformUtilities : rapidminer.home is 'D:\MARCIN\rapidminer-server\rapidminer-server-9.2.1\job-agent\bin\..\lib\container'. 2019-04-02 00:44:17.365 INFO 4656 --- [main] com.rapidminer : Initializing license manager. 2019-04-02 00:44:17.409 INFO 4656 --- [main] com.rapidminer : Cannot access file system in execution mode JOB_CONTAINER. Not loading repositories. 2019-04-02 00:44:17.819 INFO 4656 --- [main] com.rapidminer : Register plugin: Advanced File Connectors 2019-04-02 00:44:17.820 INFO 4656 --- [main] com.rapidminer : Register plugin: Blending 2019-04-02 00:44:17.820 INFO 4656 --- [main] com.rapidminer : Register plugin: Browser 2019-04-02 00:44:17.820 INFO 4656 --- [main] com.rapidminer : Register plugin: Cloud Connectivity 2019-04-02 00:44:17.820 INFO 4656 --- [main] com.rapidminer : Register plugin: Concurrency 2019-04-02 00:44:17.820 INFO 4656 --- [main] com.rapidminer : Register plugin: H2O 2019-04-02 00:44:17.820 INFO 4656 --- [main] com.rapidminer : Register plugin: HTML5 Charts 2019-04-02 00:44:17.820 INFO 4656 --- [main] com.rapidminer : Register plugin: JDBC Connectors 2019-04-02 00:44:17.820 INFO 4656 --- [main] com.rapidminer : Register plugin: Legacy Result Access 2019-04-02 00:44:17.820 INFO 4656 --- [main] com.rapidminer : Register plugin: Model Simulator 2019-04-02 00:44:17.820 INFO 4656 --- [main] com.rapidminer : Register plugin: PMML 2019-04-02 00:44:17.820 INFO 4656 --- [main] com.rapidminer : Register plugin: Process Scheduling 2019-04-02 00:44:17.820 INFO 4656 --- [main] com.rapidminer : Register plugin: Productivity 2019-04-02 00:44:17.820 INFO 4656 --- [main] com.rapidminer : Register plugin: Professional 2019-04-02 00:44:17.820 INFO 4656 --- [main] com.rapidminer : Register plugin: Remote Repository 2019-04-02 00:44:17.820 INFO 4656 --- [main] com.rapidminer : Register plugin: Social Media 2019-04-02 00:44:17.820 INFO 4656 --- [main] com.rapidminer : Register plugin: Time Series 2019-04-02 00:44:17.820 INFO 4656 --- [main] com.rapidminer : Register plugin: Utility 2019-04-02 00:44:17.829 WARN 4656 --- [main] com.rapidminer : Duplicate extension definition for extension Statistics Extension in D:\Marcin\rapidminer-server\rapidminer-server-home\job-agent-home\resources\extensions\rmx_stat-2.2.543.jar and D:\Marcin\rapidminer-server\rapidminer-server-home\job-agent-home\resources\extensions\rmx_stat-2.1.692.jar. Keeping extension with version 2.2.543. 2019-04-02 00:44:17.846 WARN 4656 --- [main] com.rapidminer : Duplicate extension definition for extension Text Processing in D:\Marcin\rapidminer-server\rapidminer-server-home\job-agent-home\resources\extensions\rmx_text-8.1.0.jar and D:\Marcin\rapidminer-server\rapidminer-server-home\job-agent-home\resources\extensions\rmx_text-7.4.1.jar. Keeping extension with version 8.1.0. 2019-04-02 00:44:17.864 WARN 4656 --- [main] com.rapidminer : Duplicate extension definition for extension Jackhammer Extension in D:\Marcin\rapidminer-server\rapidminer-server-home\job-agent-home\resources\extensions\rmx_toolkit-2.2.572.jar and D:\Marcin\rapidminer-server\rapidminer-server-home\job-agent-home\resources\extensions\rmx_toolkit-2.2.430.jar. Keeping extension with version 2.2.572. 2019-04-02 00:44:17.943 WARN 4656 --- [main] com.rapidminer : Duplicate extension definition for extension Web Mining in D:\Marcin\rapidminer-server\rapidminer-server-home\job-agent-home\resources\extensions\rmx_web-9.0.0.jar and D:\Marcin\rapidminer-server\rapidminer-server-home\job-agent-home\resources\extensions\rmx_web-7.3.0.jar. Keeping extension with version 9.0.0. 2019-04-02 00:44:17.944 INFO 4656 --- [main] com.rapidminer : Register plugin: Advanced Reporting Extension 2019-04-02 00:44:17.944 INFO 4656 --- [main] com.rapidminer : Register plugin: recommenders 2019-04-02 00:44:17.944 INFO 4656 --- [main] com.rapidminer : Register plugin: Keras 2019-04-02 00:44:17.944 INFO 4656 --- [main] com.rapidminer : Register plugin: Reporting 2019-04-02 00:44:17.944 INFO 4656 --- [main] com.rapidminer : Register plugin: R Scripting 2019-04-02 00:44:17.944 INFO 4656 --- [main] com.rapidminer : Register plugin: Value Series 2019-04-02 00:44:17.944 INFO 4656 --- [main] com.rapidminer : Register plugin: Statistics Extension 2019-04-02 00:44:17.944 INFO 4656 --- [main] com.rapidminer : Register plugin: Text Processing 2019-04-02 00:44:17.945 INFO 4656 --- [main] com.rapidminer : Register plugin: Jackhammer Extension 2019-04-02 00:44:17.945 INFO 4656 --- [main] com.rapidminer : Register plugin: Web Mining 2019-04-02 00:44:18.685 INFO 4656 --- [main] com.owc.license.LicenseManager : rmx_toolkit: Using Server-FallBack for License Key... 2019-04-02 00:44:18.685 WARN 4656 --- [main] com.owc.license.LicenseManager : rmx_toolkit: No License Key found! 2019-04-02 00:44:18.685 INFO 4656 --- [main] com.owc.license.LicenseManager : rmx_toolkit: Using Server-FallBack for Licensee... 2019-04-02 00:44:18.685 WARN 4656 --- [main] com.owc.license.LicenseManager : rmx_toolkit: No Licensee Email found! 2019-04-02 00:44:18.737 INFO 4656 --- [main] com.rapidminer : Registered configurator Remote File Connection. 2019-04-02 00:44:19.057 INFO 4656 --- [main] com.rapidminer : Registered configurator Twitter Connection. 2019-04-02 00:44:19.068 INFO 4656 --- [main] com.owc.license.LicenseManager : rmx_statistics: Using Server-FallBack for License Key... 2019-04-02 00:44:19.068 WARN 4656 --- [main] com.owc.license.LicenseManager : rmx_statistics: No License Key found! 2019-04-02 00:44:19.068 INFO 4656 --- [main] com.owc.license.LicenseManager : rmx_statistics: Using Server-FallBack for Licensee... 2019-04-02 00:44:19.068 WARN 4656 --- [main] com.owc.license.LicenseManager : rmx_statistics: No Licensee Email found! 2019-04-02 00:44:20.095 INFO 4656 --- [main] com.rapidminer : Registered configurator Salesforce Connection. 2019-04-02 00:44:20.095 INFO 4656 --- [main] com.rapidminer : Registered configurator Amazon S3 Connection. 2019-04-02 00:44:20.095 INFO 4656 --- [main] com.rapidminer : Registered configurator Azure Blob Storage Connection. 2019-04-02 00:44:20.095 INFO 4656 --- [main] com.rapidminer : Registered configurator Azure Data Lake Storage Gen1 Connection. 2019-04-02 00:44:20.096 INFO 4656 --- [main] com.rapidminer : Registered configurator Google Cloud Storage Connection. 2019-04-02 00:44:20.096 INFO 4656 --- [main] com.rapidminer : Registered configurator Dropbox Connection. 2019-04-02 00:44:20.910 WARN 4656 --- [main] com.rapidminer : Missing database driver class name for ODBC Bridge (e.g. Access) 2019-04-02 00:44:20.911 WARN 4656 --- [main] com.rapidminer : Missing database driver class name for Ingres 2019-04-02 00:44:21.491 INFO 4656 --- [main] com.rapidminer : Registered 'Time Series' as sample folder. 2019-04-02 00:44:21.665 INFO 4656 --- [main] com.rapidminer : Extension Reporting was loaded in 4ms. 2019-04-02 00:44:21.665 INFO 4656 --- [main] com.rapidminer : Extension PMML was loaded in 4ms. 2019-04-02 00:44:21.665 INFO 4656 --- [main] com.rapidminer : Extension Value Series was loaded in 6ms. 2019-04-02 00:44:21.665 INFO 4656 --- [main] com.rapidminer : Extension Keras was loaded in 8ms. 2019-04-02 00:44:21.665 INFO 4656 --- [main] com.rapidminer : Extension Advanced Reporting Extension was loaded in 18ms. 2019-04-02 00:44:21.665 INFO 4656 --- [main] com.rapidminer : Extension Statistics Extension was loaded in 25ms. 2019-04-02 00:44:21.665 INFO 4656 --- [main] com.rapidminer : Extension recommenders was loaded in 35ms. 2019-04-02 00:44:21.665 INFO 4656 --- [main] com.rapidminer : Extension Text Processing was loaded in 39ms. 2019-04-02 00:44:21.666 INFO 4656 --- [main] com.rapidminer : Extension Process Scheduling was loaded in 88ms. 2019-04-02 00:44:21.666 INFO 4656 --- [main] com.rapidminer : Extension Social Media was loaded in 93ms. 2019-04-02 00:44:21.666 INFO 4656 --- [main] com.rapidminer : Extension Professional was loaded in 93ms. 2019-04-02 00:44:21.666 INFO 4656 --- [main] com.rapidminer : Extension Blending was loaded in 100ms. 2019-04-02 00:44:21.666 INFO 4656 --- [main] com.rapidminer : Extension Advanced File Connectors was loaded in 103ms. 2019-04-02 00:44:21.666 INFO 4656 --- [main] com.rapidminer : Extension Productivity was loaded in 105ms. 2019-04-02 00:44:21.666 INFO 4656 --- [main] com.rapidminer : Extension Jackhammer Extension was loaded in 105ms. 2019-04-02 00:44:21.666 INFO 4656 --- [main] com.rapidminer : Extension Concurrency was loaded in 109ms. 2019-04-02 00:44:21.666 INFO 4656 --- [main] com.rapidminer : Extension Remote Repository was loaded in 109ms. 2019-04-02 00:44:21.666 INFO 4656 --- [main] com.rapidminer : Extension Legacy Result Access was loaded in 109ms. 2019-04-02 00:44:21.666 INFO 4656 --- [main] com.rapidminer : Extension Utility was loaded in 122ms. 2019-04-02 00:44:21.666 INFO 4656 --- [main] com.rapidminer : Extension Browser was loaded in 123ms. 2019-04-02 00:44:21.666 INFO 4656 --- [main] com.rapidminer : Extension R Scripting was loaded in 137ms. 2019-04-02 00:44:21.666 INFO 4656 --- [main] com.rapidminer : Extension HTML5 Charts was loaded in 142ms. 2019-04-02 00:44:21.667 INFO 4656 --- [main] com.rapidminer : Extension Model Simulator was loaded in 148ms. 2019-04-02 00:44:21.667 INFO 4656 --- [main] com.rapidminer : Extension Time Series was loaded in 167ms. 2019-04-02 00:44:21.667 INFO 4656 --- [main] com.rapidminer : Extension JDBC Connectors was loaded in 205ms. 2019-04-02 00:44:21.667 INFO 4656 --- [main] com.rapidminer : Extension Cloud Connectivity was loaded in 445ms. 2019-04-02 00:44:21.667 INFO 4656 --- [main] com.rapidminer : Extension H2O was loaded in 479ms. 2019-04-02 00:44:21.667 INFO 4656 --- [main] com.rapidminer : Extension Web Mining was loaded in 594ms. 2019-04-02 00:44:21.947 INFO 4656 --- [taskScheduler-2] c.r.e.j.service.OutOfMemoryWatchdog : Current memory usage is 1696MB / 4064MB 2019-04-02 00:44:26.967 INFO 4656 --- [taskScheduler-1] c.r.e.j.service.OutOfMemoryWatchdog : Current memory usage is 3328MB / 4064MB 2019-04-02 00:44:28.136 INFO 4656 --- [main] com.rapidminer : Cannot access file system in execution mode JOB_CONTAINER. Not loading repositories. 2019-04-02 00:44:28.140 INFO 4656 --- [main] com.rapidminer : Load configuration for Remote File Connection. 2019-04-02 00:44:28.140 INFO 4656 --- [main] com.rapidminer : No configuration file found for Remote File Connection 2019-04-02 00:44:28.141 INFO 4656 --- [main] com.rapidminer : Loaded configurations for 0 objects of type Remote File Connection. 2019-04-02 00:44:28.141 INFO 4656 --- [main] com.rapidminer : Load configuration for Amazon S3 Connection. 2019-04-02 00:44:28.142 INFO 4656 --- [main] com.rapidminer : No configuration file found for Amazon S3 Connection 2019-04-02 00:44:28.142 INFO 4656 --- [main] com.rapidminer : Loaded configurations for 0 objects of type Amazon S3 Connection. 2019-04-02 00:44:28.142 INFO 4656 --- [main] com.rapidminer : Load configuration for Azure Blob Storage Connection. 2019-04-02 00:44:28.142 INFO 4656 --- [main] com.rapidminer : No configuration file found for Azure Blob Storage Connection 2019-04-02 00:44:28.142 INFO 4656 --- [main] com.rapidminer : Loaded configurations for 0 objects of type Azure Blob Storage Connection. 2019-04-02 00:44:28.142 INFO 4656 --- [main] com.rapidminer : Load configuration for Azure Data Lake Storage Gen1 Connection. 2019-04-02 00:44:28.142 INFO 4656 --- [main] com.rapidminer : No configuration file found for Azure Data Lake Storage Gen1 Connection 2019-04-02 00:44:28.143 INFO 4656 --- [main] com.rapidminer : Loaded configurations for 0 objects of type Azure Data Lake Storage Gen1 Connection. 2019-04-02 00:44:28.143 INFO 4656 --- [main] com.rapidminer : Load configuration for Dropbox Connection. 2019-04-02 00:44:28.143 INFO 4656 --- [main] com.rapidminer : No configuration file found for Dropbox Connection 2019-04-02 00:44:28.143 INFO 4656 --- [main] com.rapidminer : Loaded configurations for 0 objects of type Dropbox Connection. 2019-04-02 00:44:28.143 INFO 4656 --- [main] com.rapidminer : Load configuration for Salesforce Connection. 2019-04-02 00:44:28.144 INFO 4656 --- [main] com.rapidminer : No configuration file found for Salesforce Connection 2019-04-02 00:44:28.144 INFO 4656 --- [main] com.rapidminer : Loaded configurations for 0 objects of type Salesforce Connection. 2019-04-02 00:44:28.144 INFO 4656 --- [main] com.rapidminer : Load configuration for Google Cloud Storage Connection. 2019-04-02 00:44:28.144 INFO 4656 --- [main] com.rapidminer : No configuration file found for Google Cloud Storage Connection 2019-04-02 00:44:28.144 INFO 4656 --- [main] com.rapidminer : Loaded configurations for 0 objects of type Google Cloud Storage Connection. 2019-04-02 00:44:28.144 INFO 4656 --- [main] com.rapidminer : Load configuration for Twitter Connection. 2019-04-02 00:44:28.144 INFO 4656 --- [main] com.rapidminer : No configuration file found for Twitter Connection 2019-04-02 00:44:28.144 INFO 4656 --- [main] com.rapidminer : Loaded configurations for 0 objects of type Twitter Connection. 2019-04-02 00:44:28.145 INFO 4656 --- [main] c.r.e.core.RapidMinerInitializer : License framework initialized. Current active license edition is 'non-commercial'. The license expires on '2020-01-24'. 2019-04-02 00:44:28.145 INFO 4656 --- [main] c.r.execution.jobcontainer.EngineRunner : Starting execution of process with job ID '21b3e330-6cf4-4eee-9d71-54cc0604de0b' for user 'admin'. 2019-04-02 00:44:28.146 INFO 4656 --- [main] c.r.e.j.service.RepositoryService : Executed process is stored in '/home/admin/Rankings/processes/Test'. 2019-04-02 00:44:28.147 INFO 4656 --- [main] c.r.e.j.service.RemoteRepositoryService : Trying to update JWT token from auth properties. 2019-04-02 00:44:28.147 INFO 4656 --- [main] c.r.e.j.service.RemoteRepositoryService : Skipped updating the JWT token as old one equals the new one. 2019-04-02 00:44:28.147 INFO 4656 --- [main] c.r.e.j.service.RemoteRepositoryService : Initializing the connection to RapidMiner Server. Using protocol 'http', host '127.0.0.1', and port '8080' 2019-04-02 00:44:28.174 INFO 4656 --- [main] com.rapidminer : Loading 0 configurations of type Remote File Connection from RapidMiner Server _LOCAL 2019-04-02 00:44:28.180 INFO 4656 --- [main] com.rapidminer : Loading 0 configurations of type Amazon S3 Connection from RapidMiner Server _LOCAL 2019-04-02 00:44:28.185 INFO 4656 --- [main] com.rapidminer : Loading 0 configurations of type Azure Blob Storage Connection from RapidMiner Server _LOCAL 2019-04-02 00:44:28.190 INFO 4656 --- [main] com.rapidminer : Loading 0 configurations of type Azure Data Lake Storage Gen1 Connection from RapidMiner Server _LOCAL 2019-04-02 00:44:28.195 INFO 4656 --- [main] com.rapidminer : Loading 0 configurations of type Dropbox Connection from RapidMiner Server _LOCAL 2019-04-02 00:44:28.201 INFO 4656 --- [main] com.rapidminer : Loading 0 configurations of type Salesforce Connection from RapidMiner Server _LOCAL 2019-04-02 00:44:28.205 INFO 4656 --- [main] com.rapidminer : Loading 0 configurations of type Google Cloud Storage Connection from RapidMiner Server _LOCAL 2019-04-02 00:44:28.211 INFO 4656 --- [main] com.rapidminer : Loading 0 configurations of type Twitter Connection from RapidMiner Server _LOCAL 2019-04-02 00:44:28.273 INFO 4656 --- [main] com.rapidminer : Loading 0 configurations of type Remote File Connection from RapidMiner Server _LOCAL 2019-04-02 00:44:28.279 INFO 4656 --- [main] com.rapidminer : Loading 0 configurations of type Amazon S3 Connection from RapidMiner Server _LOCAL 2019-04-02 00:44:28.287 INFO 4656 --- [main] com.rapidminer : Loading 0 configurations of type Azure Blob Storage Connection from RapidMiner Server _LOCAL 2019-04-02 00:44:28.292 INFO 4656 --- [main] com.rapidminer : Loading 0 configurations of type Azure Data Lake Storage Gen1 Connection from RapidMiner Server _LOCAL 2019-04-02 00:44:28.297 INFO 4656 --- [main] com.rapidminer : Loading 0 configurations of type Dropbox Connection from RapidMiner Server _LOCAL 2019-04-02 00:44:28.302 INFO 4656 --- [main] com.rapidminer : Loading 0 configurations of type Salesforce Connection from RapidMiner Server _LOCAL 2019-04-02 00:44:28.307 INFO 4656 --- [main] com.rapidminer : Loading 0 configurations of type Google Cloud Storage Connection from RapidMiner Server _LOCAL 2019-04-02 00:44:28.312 INFO 4656 --- [main] com.rapidminer : Loading 0 configurations of type Twitter Connection from RapidMiner Server _LOCAL 2019-04-02 00:44:28.313 INFO 4656 --- [main] c.r.e.j.service.RemoteRepositoryService : RapidMiner Server repository at 'http://127.0.0.1:8080' is reachable. Refreshing repository content now. 2019-04-02 00:44:28.506 INFO 4656 --- [main] com.rapidminer : Loading 0 configurations of type Remote File Connection from RapidMiner Server _LOCAL 2019-04-02 00:44:28.512 INFO 4656 --- [main] com.rapidminer : Loading 0 configurations of type Amazon S3 Connection from RapidMiner Server _LOCAL 2019-04-02 00:44:28.518 INFO 4656 --- [main] com.rapidminer : Loading 0 configurations of type Azure Blob Storage Connection from RapidMiner Server _LOCAL 2019-04-02 00:44:28.524 INFO 4656 --- [main] com.rapidminer : Loading 0 configurations of type Azure Data Lake Storage Gen1 Connection from RapidMiner Server _LOCAL 2019-04-02 00:44:28.530 INFO 4656 --- [main] com.rapidminer : Loading 0 configurations of type Dropbox Connection from RapidMiner Server _LOCAL 2019-04-02 00:44:28.536 INFO 4656 --- [main] com.rapidminer : Loading 0 configurations of type Salesforce Connection from RapidMiner Server _LOCAL 2019-04-02 00:44:28.542 INFO 4656 --- [main] com.rapidminer : Loading 0 configurations of type Google Cloud Storage Connection from RapidMiner Server _LOCAL 2019-04-02 00:44:28.547 INFO 4656 --- [main] com.rapidminer : Loading 0 configurations of type Twitter Connection from RapidMiner Server _LOCAL 2019-04-02 00:44:28.622 INFO 4656 --- [main] c.r.e.r.r.remote.ProcessServiceFacade : Setting up ProcessService v1.0 2019-04-02 00:44:28.727 INFO 4656 --- [main] c.r.e.r.r.remote.ProcessServiceFacade : Setting up ProcessService v1.3 2019-04-02 00:44:28.806 INFO 4656 --- [main] c.r.e.j.execution.SimpleExecutor : Initialize process context 2019-04-02 00:44:28.811 INFO 4656 --- [main] com.rapidminer.Process : No filename given for result file, using stdout for logging results! 2019-04-02 00:44:28.817 INFO 4656 --- [main] c.r.e.j.e.ExecutionProcessListener : Execution of process started 2019-04-02 00:44:28.817 INFO 4656 --- [main] com.rapidminer.Process : Process //_LOCAL/home/admin/Rankings/processes/Test starts 2019-04-02 00:44:28.818 INFO 4656 --- [main] c.r.e.j.e.ExecutionProcessListener : Started operator 'Process (Process)' 2019-04-02 00:44:28.820 INFO 4656 --- [main] c.r.e.j.e.ExecutionProcessListener : Started operator 'Execute R (Execute R)' 2019-04-02 00:44:28.821 INFO 4656 --- [main] c.r.e.j.e.ExecutionProcessListener : Execution of process stopped 2019-04-02 00:44:28.824 ERROR 4656 --- [main] c.r.e.j.service.ErrorReporterService : User Error during execution com.rapidminer.operator.UserError: Failed to detect Rscript at the given path. at com.rapidminer.extension.rscripting.operator.scripting.r.RScriptingOperator.doWork(RScriptingOperator.java:74) at com.rapidminer.operator.Operator.execute(Operator.java:1026) at com.rapidminer.operator.execution.SimpleUnitExecutor.execute(SimpleUnitExecutor.java:77) at com.rapidminer.operator.ExecutionUnit$2.run(ExecutionUnit.java:812) at com.rapidminer.operator.ExecutionUnit$2.run(ExecutionUnit.java:807) at java.security.AccessController.doPrivileged(Native Method) at com.rapidminer.operator.ExecutionUnit.execute(ExecutionUnit.java:807) at com.rapidminer.operator.OperatorChain.doWork(OperatorChain.java:423) at com.rapidminer.operator.Operator.execute(Operator.java:1026) at com.rapidminer.Process.executeRoot(Process.java:1386) at com.rapidminer.Process.execute(Process.java:1327) at com.rapidminer.Process.run(Process.java:1300) at com.rapidminer.Process.run(Process.java:1186) at com.rapidminer.Process.run(Process.java:1139) at com.rapidminer.Process.run(Process.java:1134) at com.rapidminer.Process.run(Process.java:1124) at com.rapidminer.execution.jobcontainer.execution.SimpleExecutor.executeProcess(SimpleExecutor.java:90) at com.rapidminer.execution.jobcontainer.EngineRunner.onApplicationEvent(EngineRunner.java:76) at com.rapidminer.execution.jobcontainer.EngineRunner.onApplicationEvent(EngineRunner.java:30) at org.springframework.context.event.SimpleApplicationEventMulticaster.doInvokeListener(SimpleApplicationEventMulticaster.java:172) at org.springframework.context.event.SimpleApplicationEventMulticaster.invokeListener(SimpleApplicationEventMulticaster.java:165) at org.springframework.context.event.SimpleApplicationEventMulticaster.multicastEvent(SimpleApplicationEventMulticaster.java:139) at org.springframework.context.support.AbstractApplicationContext.publishEvent(AbstractApplicationContext.java:393) at org.springframework.context.support.AbstractApplicationContext.publishEvent(AbstractApplicationContext.java:347) at org.springframework.boot.context.event.EventPublishingRunListener.finished(EventPublishingRunListener.java:101) at org.springframework.boot.SpringApplicationRunListeners.callFinishedListener(SpringApplicationRunListeners.java:79) at org.springframework.boot.SpringApplicationRunListeners.finished(SpringApplicationRunListeners.java:72) at org.springframework.boot.SpringApplication.run(SpringApplication.java:305) at org.springframework.boot.builder.SpringApplicationBuilder.run(SpringApplicationBuilder.java:134) at com.rapidminer.execution.jobcontainer.Application.main(Application.java:47) 2019-04-02 00:44:28.826 INFO 4656 --- [main] c.r.execution.jobcontainer.EngineRunner : Execution finished with exit code 'USER_ERROR' 2019-04-02 00:44:28.826 INFO 4656 --- [main] c.r.e.j.service.ShutdownService : Job Container exits with exit code 'USER_ERROR' 2019-04-02 00:44:29.080 INFO 4656 --- [Thread-2] s.c.a.AnnotationConfigApplicationContext : Closing org.springframework.context.annotation.AnnotationConfigApplicationContext@7eac9008: startup date [Tue Apr 02 00:44:15 CEST 2019]; root of context hierarchy 2019-04-02 00:44:29.083 INFO 4656 --- [Thread-2] o.s.c.support.DefaultLifecycleProcessor : Stopping beans in phase 0 2019-04-02 00:44:29.084 INFO 4656 --- [Thread-2] o.s.j.e.a.AnnotationMBeanExporter : Unregistering JMX-exposed beans on shutdown 2019-04-02 00:44:29.084 INFO 4656 --- [Thread-2] o.s.s.c.ThreadPoolTaskScheduler : Shutting down ExecutorService 'taskScheduler'
1 - 1 of 11
    User: "Pavithra_Rao"
    Accepted Answer
    maciej_pankiewi ,
    1. Have you made sure to add the path to job-agent >> rapidminer.properties file as well?(..\<job-agent-home>\rapidminer-jobagent\home\config\rapidminer\rapidminer.properties)Just like adding rapidminer.r_scripting.path to Server Web UI >> Administration >>Settings, please make sure to add it to job-agent rapidminer.properties file. This job-agent is the one attached to the queue that you are trying to run the Execute R script process on.
    2. Since it's a windows machine make sure the path has double \\ as shown below; in both the entry locations rapidminer.r_scripting.path = C:\\Program Files\\R\\R-3.5.1\\bin\\Rscript.exe
    Hope this helps.
    Cheers,
    Pavithra
