<?xml version="1.0" encoding="UTF-8"?><process version="9.2.001"> <context> <input/> <output/> <macros/> </context> <operator activated="true" class="process" compatibility="9.2.001" expanded="true" name="Process"> <parameter key="logverbosity" value="init"/> <parameter key="random_seed" value="2001"/> <parameter key="send_mail" value="never"/> <parameter key="notification_email" value=""/> <parameter key="process_duration_for_mail" value="30"/> <parameter key="encoding" value="SYSTEM"/> <process expanded="true"> <operator activated="true" class="retrieve" compatibility="9.2.001" expanded="true" height="68" name="Retrieve Titanic Training" width="90" x="45" y="136"> <parameter key="repository_entry" value="//Samples/data/Titanic Training"/> </operator> <operator activated="true" class="operator_toolbox:smote" compatibility="1.8.000" expanded="true" height="82" name="SMOTE Upsampling" width="90" x="313" y="136"> <parameter key="number_of_neighbours" value="5"/> <parameter key="normalize" value="true"/> <parameter key="equalize_classes" value="true"/> <parameter key="upsampling_size" value="1000"/> <parameter key="auto_detect_minority_class" value="true"/> <parameter key="round_integers" value="true"/> <parameter key="nominal_change_rate" value="0.5"/> <parameter key="use_local_random_seed" value="false"/> <parameter key="local_random_seed" value="1992"/> </operator> <connect from_op="Retrieve Titanic Training" from_port="output" to_op="SMOTE Upsampling" to_port="exa"/> <connect from_op="SMOTE Upsampling" from_port="ups" to_port="result 1"/> <portSpacing port="source_input 1" spacing="0"/> <portSpacing port="sink_result 1" spacing="0"/> <portSpacing port="sink_result 2" spacing="0"/> </process> </operator> </process>
