PM SEVERE: Failed to create HTML5 browser!
Parth_Intwala
I am currently using Windows 10 64 bit OS and version of rapid_miner is 9.2 which was the only version available to download. Now, when I want to visualise the data it prompts an error: "PM SEVERE: Failed to create HTML5 browser!".
P.S. Resolve it as early as possible.
varunm1
Hello
@Parth_Intwala
There are a couple of workarounds for this.
1. Using Legacy charts: You can switch to legacy charts and try them in case it's urgent. You can change to legacy charts in RapidMiner studio by going to Settings--> Preferences --> User Interface. Then select the below options highlighted in Red.
2: In the second case you can try to open HTML 5 in safe mode. This options is also present in Settings --> Preferences --> User Interface. Then at the end of this page select HTML5 Safe Mode and try.
Issue
: To understand the issue, try to open Rapid Miner from the bat file. You can find bat file in C:\Program Files\RapidMiner\RapidMiner Studio folder. You can double click the RapidMiner-Studio (file type Windows Batch File). Once you double click this file, it will show you are a command prompt that is initializing RapidMiner once it completes opening RapidMiner studio. You can use CTRL+F to search for HTML in the command prompt window and see what you are going on there. For me like its working fine, I am getting as shown in below figure. In your case, you can see and post here.
There is a similar question in the below thread.
@mschmitz
can provide some information.
I hope this helps.
azleena
I'm using Mac, how to solve the problem
User40550
.. same problem here (Win10, 64bit), using 'safe mode' ist not a solution:
Mar 26, 2020 2:50:08 PM INFO: HTML5 safe mode enabled. Skipping hardware accelerated browser setup test.
Mar 26, 2020 2:50:24 PM SEVERE: Failed to create HTML5 browser!
Legacy Charts are working.
Best regards,
Ingo
Marco_Boeck
What does your rapidminer-studio.log file found in the C:/Users/xxx/.RapidMiner folder contain?
Marco
User40550
.. ok, it was my fault: "Windows 10 Firewall Control Plus Edition x64" blocked the "BrowserCore Chromium Native Process".
I didn't noticed, that this is a component of RapidMiner.
Best regards,
Ingo
