<?xml version="1.0" encoding="UTF-8"?><process version="9.2.001"><br> <context><br> <input/><br> <output/><br> <macros/><br> </context><br> <operator activated="true" class="process" compatibility="9.2.001" expanded="true" name="Process"><br> <parameter key="logverbosity" value="init"/><br> <parameter key="random_seed" value="2001"/><br> <parameter key="send_mail" value="never"/><br> <parameter key="notification_email" value=""/><br> <parameter key="process_duration_for_mail" value="30"/><br> <parameter key="encoding" value="UTF-8"/><br> <process expanded="true"><br> <operator activated="true" class="retrieve" compatibility="9.2.001" expanded="true" height="68" name="Retrieve Titanic Training" width="90" x="45" y="34"><br> <parameter key="repository_entry" value="//Samples/data/Titanic Training"/><br> </operator><br> <operator activated="true" class="sample" compatibility="9.2.001" expanded="true" height="82" name="Sample" width="90" x="179" y="34"><br> <parameter key="sample" value="absolute"/><br> <parameter key="balance_data" value="true"/><br> <parameter key="sample_size" value="100"/><br> <parameter key="sample_ratio" value="0.1"/><br> <parameter key="sample_probability" value="0.1"/><br> <list key="sample_size_per_class"><br> <parameter key="Yes" value="200"/><br> <parameter key="No" value="200"/><br> </list><br> <list key="sample_ratio_per_class"/><br> <list key="sample_probability_per_class"/><br> <parameter key="use_local_random_seed" value="false"/><br> <parameter key="local_random_seed" value="1992"/><br> </operator><br> <connect from_op="Retrieve Titanic Training" from_port="output" to_op="Sample" to_port="example set input"/><br> <connect from_op="Sample" from_port="example set output" to_port="result 1"/><br> <portSpacing port="source_input 1" spacing="0"/><br> <portSpacing port="sink_result 1" spacing="0"/><br> <portSpacing port="sink_result 2" spacing="0"/><br> </process><br> </operator><br></process>
