Python Code
Gokz123
Can i import data through python code in rapidminer rather than imoorting it directly through import data button in rapidminer. if so can anyone pls provide the code ?
Python
hughesfleming68
You should be able to do it without problems but data import in Rapidminer is one of it's strong points. What kind of file are you trying to import? With a csv file there are two ways. You can use import csv or with pandas. You will have to convert to a data frame to get the data back into Rapidminer which also means learning about data frames! There are lots of examples on the net for all these functions. I would only consider doing this if you are trying to import data in a format that is not supported by Rapidminer directly. It is much easier.
Gokz123
its csv file sir.sir am doing predicting student performance using data mining.can u pls send the code.
rfuentealba
Hi Gokz123,
Install the Python Scripting Extension. When you add a new
Execute Python
operator, you will have some boilerplate code that lets you open a CSV. However, as
@hughesfleming68
said, you can do that easily with the
Read CSV
operator from RapidMiner.
I found a few cases where I had to import CSV data on streaming from an obscure protocol (not HTTP), and I think you may have this use case, so here is a picture of how the code should look like. But bear in mind that very few of us found this use case valid, hence I insist: use the
Read CSV
operator.
All the best,
Rodrigo.
sgenzer
hi
@Gokz123
just curious - why would you import data with Python rather than with RapidMiner? What are the advantages here?
Scott
