when i do optimization of an automobile part , this part having more than 200 iteration in optimization result.
how to reduce or minimize the iteration in optimization result.
Abhijeet,
Can you share the details of your part, so we can suggest you respective changes, if required.
Abhijeet, Can you share the details of your part, so we can suggest you respective changes, if required.
sir for part is brake pedal more than 200 interatioon
Kindly share your model file through drop box & respective link is below in the signature
