So I have a Text file that I read, and then continue to do some filtering on. At the end of the process, I would like to create a .txt file with all the text from my Example Set. I use the Write to Text operator, but it only writes the amount of examples in the .txt file it creates. Am I using it wrong?
Code for my process:
<?xml version="1.0" encoding="UTF-8"?><process version="9.2.000">
<context>
<input/>
<output/>
<macros/>
</context>
<operator activated="true" class="process" compatibility="9.2.000" expanded="true" name="Process">
<process expanded="true">
<operator activated="true" class="read_csv" compatibility="9.2.000" expanded="true" height="68" name="Read CSV" width="90" x="45" y="34">
<parameter key="csv_file" value="/Users/MathiasVildbrad/Desktop/new_new_converted.txt"/>
<parameter key="column_separators" value=","/>
<parameter key="trim_lines" value="false"/>
<parameter key="use_quotes" value="true"/>
<parameter key="quotes_character" value="""/>
<parameter key="escape_character" value="\"/>
<parameter key="skip_comments" value="true"/>
<parameter key="comment_characters" value="#"/>
<parameter key="starting_row" value="1"/>
<parameter key="parse_numbers" value="true"/>
<parameter key="decimal_character" value="."/>
<parameter key="grouped_digits" value="false"/>
<parameter key="grouping_character" value=","/>
<parameter key="infinity_representation" value=""/>
<parameter key="date_format" value=""/>
<parameter key="first_row_as_names" value="true"/>
<list key="annotations"/>
<parameter key="time_zone" value="SYSTEM"/>
<parameter key="locale" value="English (United States)"/>
<parameter key="encoding" value="UTF-8"/>
<parameter key="read_all_values_as_polynominal" value="false"/>
<parameter key="0" value="Text.true.polynominal.attribute"/>
</list>
<parameter key="read_not_matching_values_as_missings" value="false"/>
<parameter key="datamanagement" value="double_array"/>
<parameter key="data_management" value="auto"/>
<operator activated="true" class="filter_examples" compatibility="9.2.000" expanded="true" height="103" name="Deleted & Removed" width="90" x="45" y="136">
<parameter key="parameter_expression" value=""/>
<parameter key="condition_class" value="custom_filters"/>
<parameter key="invert_filter" value="true"/>
<list key="filters_list">
<parameter key="filters_entry_key" value="Text.equals.[deleted]"/>
<parameter key="filters_entry_key" value="Text.equals.[removed]"/>
</list>
<parameter key="filters_logic_and" value="false"/>
<parameter key="filters_check_metadata" value="true"/>
<operator activated="true" class="replace" compatibility="9.2.000" expanded="true" height="82" name="Remove links" width="90" x="45" y="289">
<parameter key="attribute_filter_type" value="all"/>
<parameter key="attribute" value=""/>
<parameter key="value_type" value="nominal"/>
<parameter key="except_value_type" value="file_path"/>
<parameter key="block_type" value="single_value"/>
<parameter key="except_block_type" value="single_value"/>
<parameter key="replace_what" value="(https?|http)://[-a-zA-Z0-9+&
@#/%?=~_|!:,.;]*[-a-zA-Z0-9+&
@#/%=~_|]"/>
<operator activated="true" class="replace" compatibility="9.2.000" expanded="true" height="82" name="Replace Special Characthers" width="90" x="45" y="391">
<operator activated="true" class="filter_examples" compatibility="9.2.000" expanded="true" height="103" name="Remove empty" width="90" x="179" y="34">
<parameter key="invert_filter" value="false"/>
<parameter key="filters_entry_key" value="Text.is_not_missing."/>
</list>
<parameter key="filters_logic_and" value="true"/>
<operator activated="true" class="nominal_to_text" compatibility="9.2.000" expanded="true" height="82" name="Nominal to Text" width="90" x="313" y="34">
<operator activated="true" class="write_as_text" compatibility="9.2.000" expanded="true" height="103" name="Write as Text" width="90" x="447" y="34">
<parameter key="result_file" value="/Users/MathiasVildbrad/Desktop/nice.txt"/>
<connect from_op="Read CSV" from_port="output" to_op="Deleted & Removed" to_port="example set input"/>
<connect from_op="Deleted & Removed" from_port="example set output" to_op="Remove links" to_port="example set input"/>
<connect from_op="Remove links" from_port="example set output" to_op="Replace Special Characthers" to_port="example set input"/>
<connect from_op="Replace Special Characthers" from_port="example set output" to_op="Remove empty" to_port="example set input"/>
<connect from_op="Remove empty" from_port="example set output" to_op="Nominal to Text" to_port="example set input"/>
<connect from_op="Nominal to Text" from_port="example set output" to_op="Write as Text" to_port="input 1"/>
<connect from_op="Nominal to Text" from_port="original" to_op="Write as Text" to_port="input 2"/>
<connect from_op="Write as Text" from_port="input 1" to_port="result 1"/>
<connect from_op="Write as Text" from_port="input 2" to_port="result 2"/>
</process>
</process>
