i am running an composite optimization and I have defined a mass response.
I can get the resulting response value from the .out-file, but I am not sure If this is the value just for the optimized laminate or the overall weight (including the other components that are not defined to be optimized). Also I am not sure if the target value for the mass response (the value i defined as optimization constraint) is the overall or laminate weight constraint??
Thank you!
