Hi everyone.
Old & (very) rusty Rapidminer fan needs a hint!
* I have a single webpage containing information I want to export into a CSV file.
* At the end of the process, I'm expecting 3 columns (name, address, URL).
* With my current flow, I get a single column containing all the names in the first rows, then all the addresses, then all the URLs...
Here's the flow (Rapidminer 5.3, but it's the same result with 9.2)
Thank you!
<?xml version="1.0" encoding="UTF-8" standalone="no"?><br><process version="5.3.015"><br> <context><br> <input/><br> <output/><br> <macros/><br> </context><br> <operator activated="true" class="process" compatibility="5.3.015" expanded="true" name="Process"><br> <process expanded="true"><br> <operator activated="true" class="text:read_document" compatibility="5.3.002" expanded="true" height="60" name="Read Document" width="90" x="45" y="30"><br> <parameter key="file" value="E:\Rapidminer\Expert.htm"/><br> <parameter key="extract_text_only" value="false"/><br> <parameter key="use_file_extension_as_type" value="false"/><br> <parameter key="encoding" value="UTF-8"/><br> </operator><br> <operator activated="true" class="text:process_documents" compatibility="5.3.002" expanded="true" height="94" name="Process Documents" width="90" x="180" y="30"><br> <parameter key="create_word_vector" value="false"/><br> <parameter key="add_meta_information" value="false"/><br> <parameter key="keep_text" value="true"/><br> <process expanded="true"><br> <operator activated="true" class="text:cut_document" compatibility="5.3.002" expanded="true" height="60" name="Cut Document (3)" width="90" x="45" y="30"><br> <list key="string_machting_queries"><br> <parameter key="url" value="<a href="."><span"/><br> <parameter key="title" value="<span class="title">.</span>"/><br> <parameter key="address" value="<span class="address">.</span>"/><br> </list><br> <list key="regular_expression_queries"/><br> <list key="regular_region_queries"/><br> <list key="xpath_queries"><br> <parameter key="link" value="//h:a[@class="PinImage ImgLink"]/@href"/><br> </list><br> <list key="namespaces"/><br> <list key="index_queries"/><br> <process expanded="true"><br> <connect from_port="segment" to_port="document 1"/><br> <portSpacing port="source_segment" spacing="0"/><br> <portSpacing port="sink_document 1" spacing="0"/><br> <portSpacing port="sink_document 2" spacing="0"/><br> </process><br> </operator><br> <connect from_port="document" to_op="Cut Document (3)" to_port="document"/><br> <connect from_op="Cut Document (3)" from_port="documents" to_port="document 1"/><br> <portSpacing port="source_document" spacing="0"/><br> <portSpacing port="sink_document 1" spacing="0"/><br> <portSpacing port="sink_document 2" spacing="0"/><br> </process><br> </operator><br> <operator activated="true" class="select_attributes" compatibility="5.3.015" expanded="true" height="76" name="Select Attributes" width="90" x="315" y="30"><br> <parameter key="attribute_filter_type" value="subset"/><br> <parameter key="attributes" value="|address|url|title"/><br> </operator><br> <operator activated="true" class="write_excel" compatibility="5.3.015" expanded="true" height="76" name="Write Excel" width="90" x="450" y="30"><br> <parameter key="excel_file" value="E:\Rapidminer\expert.xls"/><br> </operator><br> <connect from_op="Read Document" from_port="output" to_op="Process Documents" to_port="documents 1"/><br> <connect from_op="Process Documents" from_port="example set" to_op="Select Attributes" to_port="example set input"/><br> <connect from_op="Select Attributes" from_port="example set output" to_op="Write Excel" to_port="input"/><br> <connect from_op="Write Excel" from_port="through" to_port="result 1"/><br> <portSpacing port="source_input 1" spacing="0"/><br> <portSpacing port="sink_result 1" spacing="0"/><br> <portSpacing port="sink_result 2" spacing="0"/><br> </process><br> </operator><br></process>
