Cannot launch RM Studio: Invalid layout of java.lang.Thread at name
I recently updated RM Studio to the latest version and now it won't launch. In preparation, I downloaded and installed the latest Java Runtime Environment (1.8.0_201-b09). There must be some incompatibility between the java versions because RM came with its own JRE. Here is the text of the error log:
# A fatal error has been detected by the Java Runtime Environment:
# Internal Error (javaClasses.cpp:127), pid=2032, tid=3296
# fatal error: Invalid layout of preloaded class
# JRE version: (8.0_51-b16) (build )
# Java VM: Java HotSpot(TM) 64-Bit Server VM (25.51-b03 mixed mode windows-amd64 compressed oops)
# Failed to write core dump. Minidumps are not enabled by default on client versions of Windows
# If you would like to submit a bug report, please visit:
--------------- T H R E A D ---------------
Current thread (0x0000000002a8e000): JavaThread "Unknown thread" [_thread_in_vm, id=3296, stack(0x0000000002830000,0x0000000002930000)]
Stack: [0x0000000002830000,0x0000000002930000]
Native frames: (J=compiled Java code, j=interpreted, Vv=VM code, C=native code)
V [jvm.dll+0x32b4ca]
V [jvm.dll+0x2797e3]
V [jvm.dll+0x27a479]
V [jvm.dll+0x2716e6]
V [jvm.dll+0x67fc3]
V [jvm.dll+0x685db]
V [jvm.dll+0x6d3be]
V [jvm.dll+0x6d599]
V [jvm.dll+0x20f0c5]
V [jvm.dll+0x240d2a]
V [jvm.dll+0x15b9a1]
C [java.exe+0x238a]
C [java.exe+0xcf67]
C [java.exe+0xcffb]
C [KERNEL32.DLL+0x181f4]
C [ntdll.dll+0x6a251]
--------------- P R O C E S S ---------------
Java Threads: ( => current thread )
Other Threads:
=>0x0000000002a8e000 (exited) JavaThread "Unknown thread" [_thread_in_vm, id=3296, stack(0x0000000002830000,0x0000000002930000)]
VM state:not at safepoint (normal execution)
VM Mutex/Monitor currently owned by a thread: None
Heap:
PSYoungGen total 74752K, used 1290K [0x000000076cb00000, 0x0000000771e00000, 0x00000007c0000000)
eden space 64512K, 2% used [0x000000076cb00000,0x000000076cc42900,0x0000000770a00000)
from space 10240K, 0% used [0x0000000771400000,0x0000000771400000,0x0000000771e00000)
to space 10240K, 0% used [0x0000000770a00000,0x0000000770a00000,0x0000000771400000)
ParOldGen total 171008K, used 0K [0x00000006c6000000, 0x00000006d0700000, 0x000000076cb00000)
object space 171008K, 0% used [0x00000006c6000000,0x00000006c6000000,0x00000006d0700000)
Metaspace used 775K, capacity 4480K, committed 4480K, reserved 1056768K
class space used 75K, capacity 384K, committed 384K, reserved 1048576K
Card table byte_map: [0x0000000011e50000,0x0000000012630000] byte_map_base: 0x000000000e820000
Marking Bits: (ParMarkBitMap*) 0x00000000685e4040
Begin Bits: [0x0000000013370000, 0x00000000171f0000)
End Bits: [0x00000000171f0000, 0x000000001b070000)
Polling page: 0x00000000007f0000
CodeCache: size=245760Kb used=328Kb max_used=328Kb free=245431Kb
bounds [0x0000000002a90000, 0x0000000002d00000, 0x0000000011a90000]
total_blobs=58 nmethods=0 adapters=38
compilation: enabled
Compilation events (0 events):
No events
GC Heap History (0 events):
No events
Deoptimization events (0 events):
No events
Internal exceptions (0 events):
No events
Events (10 events):
Event: 0.023 loading class java/lang/Short
Event: 0.023 loading class java/lang/Short done
Event: 0.023 loading class java/lang/Integer
Event: 0.024 loading class java/lang/Integer done
Event: 0.024 loading class java/lang/Long
Event: 0.024 loading class java/lang/Long done
Event: 0.024 loading class java/lang/NullPointerException
Event: 0.024 loading class java/lang/NullPointerException done
Event: 0.024 loading class java/lang/ArithmeticException
Event: 0.024 loading class java/lang/ArithmeticException done
Dynamic libraries:
0x00007ff6c5b00000 - 0x00007ff6c5b37000 C:\Program Files\RapidMiner\RapidMiner Studio\jre\bin\java.exe
0x00007ffdd1aa0000 - 0x00007ffdd1c8d000 C:\WINDOWS\SYSTEM32\ntdll.dll
0x00007ffdd0080000 - 0x00007ffdd0133000 C:\WINDOWS\System32\KERNEL32.DLL
0x00007ffdcdcc0000 - 0x00007ffdcdf53000 C:\WINDOWS\System32\KERNELBASE.dll
0x00007ffdd19c0000 - 0x00007ffdd1a63000 C:\WINDOWS\System32\ADVAPI32.dll
0x00007ffdcfeb0000 - 0x00007ffdcff4e000 C:\WINDOWS\System32\msvcrt.dll
0x00007ffdd0310000 - 0x00007ffdd03ae000 C:\WINDOWS\System32\sechost.dll
0x00007ffdcecd0000 - 0x00007ffdcedf2000 C:\WINDOWS\System32\RPCRT4.dll
0x00007ffdcf9e0000 - 0x00007ffdcfb77000 C:\WINDOWS\System32\USER32.dll
0x00007ffdceb30000 - 0x00007ffdceb50000 C:\WINDOWS\System32\win32u.dll
0x00007ffdd0230000 - 0x00007ffdd0259000 C:\WINDOWS\System32\GDI32.dll
0x00007ffdce240000 - 0x00007ffdce3da000 C:\WINDOWS\System32\gdi32full.dll
0x00007ffdcdc20000 - 0x00007ffdcdcc0000 C:\WINDOWS\System32\msvcp_win.dll
0x00007ffdce140000 - 0x00007ffdce23c000 C:\WINDOWS\System32\ucrtbase.dll
0x00007ffdb3ed0000 - 0x00007ffdb4149000 C:\WINDOWS\WinSxS\amd64_microsoft.windows.common-controls_6595b64144ccf1df_6.0.17763.316_none_05b53be2071f46b6\COMCTL32.dll
0x00007ffdcf0d0000 - 0x00007ffdcf3fd000 C:\WINDOWS\System32\combase.dll
0x00007ffdcec20000 - 0x00007ffdcec9e000 C:\WINDOWS\System32\bcryptPrimitives.dll
0x00007ffdcf4c0000 - 0x00007ffdcf4ee000 C:\WINDOWS\System32\IMM32.DLL
0x0000000068670000 - 0x0000000068742000 C:\Program Files\RapidMiner\RapidMiner Studio\jre\bin\msvcr100.dll
0x0000000067de0000 - 0x0000000068663000 C:\Program Files\RapidMiner\RapidMiner Studio\jre\bin\server\jvm.dll
0x00007ffdd1900000 - 0x00007ffdd1908000 C:\WINDOWS\System32\PSAPI.DLL
0x00007ffdbcac0000 - 0x00007ffdbcac9000 C:\WINDOWS\SYSTEM32\WSOCK32.dll
0x00007ffdc72b0000 - 0x00007ffdc72ba000 C:\WINDOWS\SYSTEM32\VERSION.dll
0x00007ffdc27f0000 - 0x00007ffdc2814000 C:\WINDOWS\SYSTEM32\WINMM.dll
0x00007ffdcf4f0000 - 0x00007ffdcf55d000 C:\WINDOWS\System32\WS2_32.dll
0x00007ffdc25b0000 - 0x00007ffdc25dd000 C:\WINDOWS\SYSTEM32\winmmbase.dll
0x00007ffdcdbd0000 - 0x00007ffdcdc1a000 C:\WINDOWS\System32\cfgmgr32.dll
0x0000000067dd0000 - 0x0000000067ddf000 C:\Program Files\RapidMiner\RapidMiner Studio\jre\bin\verify.dll
0x0000000067da0000 - 0x0000000067dc9000 C:\Program Files\RapidMiner\RapidMiner Studio\jre\bin\java.dll
0x0000000067d80000 - 0x0000000067d96000 C:\Program Files\RapidMiner\RapidMiner Studio\jre\bin\zip.dll
0x00007ffdc5da0000 - 0x00007ffdc5f8d000 C:\WINDOWS\SYSTEM32\dbghelp.dll
VM Arguments:
java_command: Invalid layout of java.lang.Thread at name
java_class_path (initial): .
Launcher Type: SUN_STANDARD
Environment Variables:
PATH=C:\Program Files (x86)\Common Files\Oracle\Java\javapath;C:\ProgramData\Oracle\Java\javapath;C:\Program Files (x86)\Intel\iCLS Client\;C:\Program Files\Intel\iCLS Client\;C:\WINDOWS\system32;C:\WINDOWS;C:\WINDOWS\System32\Wbem;C:\WINDOWS\System32\WindowsPowerShell\v1.0\;C:\Program Files\Intel\Intel(R) Management Engine Components\DAL;C:\Program Files (x86)\Intel\Intel(R) Management Engine Components\DAL;C:\Program Files\Intel\Intel(R) Management Engine Components\IPT;C:\Program Files (x86)\Intel\Intel(R) Management Engine Components\IPT;C:\Program Files\PuTTY\;C:\WINDOWS\System32\OpenSSH\;C:\Program Files\Intel\WiFi\bin\;C:\Program Files\Common Files\Intel\WirelessCommon\;C:\Users\W540\Anaconda;C:\Users\W540\Anaconda\Scripts;C:\Program Files\Intel\WiFi\bin\;C:\Program Files\Common Files\Intel\WirelessCommon\;C:\Users\W540\Downloads;C:\Program Files\Redis;%USERPROFILE%\AppData\Local\Microsoft\WindowsApps;
USERNAME=W540
OS=Windows_NT
PROCESSOR_IDENTIFIER=Intel64 Family 6 Model 60 Stepping 3, GenuineIntel
--------------- S Y S T E M ---------------
OS: Windows 10.0 , 64 bit Build 17763 (10.0.17763.292)
CPU:total 8 (4 cores per cpu, 2 threads per core) family 6 model 60 stepping 3, cmov, cx8, fxsr, mmx, sse, sse2, sse3, ssse3, sse4.1, sse4.2, popcnt, avx, avx2, aes, clmul, erms, lzcnt, ht, tsc, tscinvbit, bmi1, bmi2
Memory: 4k page, physical 16381548k(12266300k free), swap 32765548k(27898984k free)
vm_info: Java HotSpot(TM) 64-Bit Server VM (25.51-b03) for windows-amd64 JRE (1.8.0_51-b16), built on Jun 8 2015 18:03:07 by "java_re" with MS VC++ 10.0 (VS2010)
time: Mon Feb 18 12:46:17 2019
elapsed time: 0 seconds (0d 0h 0m 0s)
1 - 1 of
11
hughesfleming68
New Altair Community Member
Updated by hughesfleming68
I am not sure that it is the jvm. I am using 1.8.0_202 without problems with Rapidminer. The simplest solution maybe to uninstall both and just reinstall Rapidminer.
