Dear all,
I run a process in which I create a small example set in each iteration of a loop, and merge them all in the end using the Append operator
However, somewhere in the process something goes wrong and apparently some iteration ends up creating an example set with a different number of attributes, so the append operator crashes,
Now, I want to debug this and I stored the entire collection. However I have ~70 k objects in the collection and I cannot look through them by eye. I was wandering whether there was an operator that returns the number of attributes in an example set, such that I can compute it for all objects in the collection and hopefully quickly spot where the problem is?
I didn't manage to find anything useful myself, so any input from you is valuable!
Cheers,
Snežana
