How to change the layout of rapidminer?
1701624g
Hi all,
I just update rapidminer to the latest version 9.2, however, after the update, the chart and advanced chart section were changed to just visualisation. Is there a way to change my layout to the one with the advanced chart as I need it for my report.
Thanks,
JT
Telcontar120
Under "Settings" (top menu), under "Preferences" on the "User Interface" tab is an option to enable legacy Advanced Charts. It appears to be off by default but setting it should get you that view back.
Overall though, I believe the old Advanced Chart interface is being deprecated in favor of the new Visualizations interface, which allows you to do almost everything you could do in the old Advanced Charts plus a lot more. It is also a lot easier to work with than the old one, although there is of course a learning curve.
P.S. "Simple Charts" is the legacy plain Charts interface which is also still available but ultimately will also probably be replaced by the new Visualization module. So it is probably good to start to get to know the new module.
Telcontar120
nicholaswongsg
Hey JT, if you've developed something on RapidMiner and would like to run it regularly, it will be better not to update your software immediately. May I know what kind of views are you looking for? In version 9.2, you can select your view type over at the top menu -> View -> Show Panel. You can select the ones you're looking for!
1701624g
@Telcontar120
, thanks I found the advanced chart.
@nicholaswongsg
, thank you too for helping me too
