<?xml version="1.0" encoding="UTF-8"?><process version="9.2.000"> <context> <input/> <output/> <macros/> </context> <operator activated="true" class="process" compatibility="9.2.000" expanded="true" name="Process"> <parameter key="logverbosity" value="init"/> <parameter key="random_seed" value="120"/> <parameter key="send_mail" value="never"/> <parameter key="notification_email" value=""/> <parameter key="process_duration_for_mail" value="30"/> <parameter key="encoding" value="SYSTEM"/> <process expanded="true"> <operator activated="true" class="read_csv" compatibility="9.2.000" expanded="true" height="68" name="Read CSV" width="90" x="45" y="34"> <parameter key="csv_file" value="C:\Users\brian\Downloads\sample.csv"/> <parameter key="column_separators" value=","/> <parameter key="trim_lines" value="false"/> <parameter key="use_quotes" value="true"/> <parameter key="quotes_character" value="""/> <parameter key="escape_character" value="\"/> <parameter key="skip_comments" value="true"/> <parameter key="comment_characters" value="#"/> <parameter key="starting_row" value="1"/> <parameter key="parse_numbers" value="true"/> <parameter key="decimal_character" value="."/> <parameter key="grouped_digits" value="false"/> <parameter key="grouping_character" value=","/> <parameter key="infinity_representation" value=""/> <parameter key="date_format" value=""/> <parameter key="first_row_as_names" value="true"/> <list key="annotations"/> <parameter key="time_zone" value="SYSTEM"/> <parameter key="locale" value="English (United States)"/> <parameter key="encoding" value="windows-1252"/> <parameter key="read_all_values_as_polynominal" value="false"/> <list key="data_set_meta_data_information"> <parameter key="0" value="artist.true.polynominal.attribute"/> <parameter key="1" value="genre_1.true.polynominal.attribute"/> <parameter key="2" value="genre_2.true.polynominal.attribute"/> <parameter key="3" value="genre_3.true.polynominal.attribute"/> <parameter key="4" value="genre_4.true.polynominal.attribute"/> <parameter key="5" value="genre_5.true.polynominal.attribute"/> <parameter key="6" value="genre_6.true.polynominal.attribute"/> <parameter key="7" value="genre_7.true.polynominal.attribute"/> <parameter key="8" value="genre_8.true.polynominal.attribute"/> <parameter key="9" value="genre_9.true.polynominal.attribute"/> <parameter key="10" value="genre_10.true.polynominal.attribute"/> <parameter key="11" value="genre_11.true.polynominal.attribute"/> <parameter key="12" value="genre_12.true.polynominal.attribute"/> <parameter key="13" value="genre_13.true.polynominal.attribute"/> <parameter key="14" value="genre_14.true.polynominal.attribute"/> <parameter key="15" value="genre_15.true.polynominal.attribute"/> <parameter key="16" value="genre_16.true.polynominal.attribute"/> <parameter key="17" value="genre_17.true.polynominal.attribute"/> <parameter key="18" value="genre_18.true.polynominal.attribute"/> <parameter key="19" value="genre_19.true.polynominal.attribute"/> <parameter key="20" value="genre_20.true.polynominal.attribute"/> <parameter key="21" value="genre_21.true.polynominal.attribute"/> <parameter key="22" value="genre_22.true.polynominal.attribute"/> <parameter key="23" value="genre_23.true.polynominal.attribute"/> <parameter key="24" value="genre_24.true.polynominal.attribute"/> <parameter key="25" value="genre_25.true.polynominal.attribute"/> <parameter key="26" value="title.true.polynominal.attribute"/> <parameter key="27" value="energy.true.real.attribute"/> <parameter key="28" value="liveness.true.real.attribute"/> <parameter key="29" value="speechiness.true.real.attribute"/> <parameter key="30" value="valence.true.real.attribute"/> <parameter key="31" value="acousticness.true.real.attribute"/> <parameter key="32" value="instrumentalness.true.real.attribute"/> <parameter key="33" value="danceability.true.real.attribute"/> <parameter key="34" value="time_signature.true.real.attribute"/> <parameter key="35" value="key.true.real.attribute"/> <parameter key="36" value="duration_ms.true.real.attribute"/> <parameter key="37" value="loudness.true.real.attribute"/> <parameter key="38" value="tempo.true.real.attribute"/> <parameter key="39" value="mode.true.real.attribute"/> </list> <parameter key="read_not_matching_values_as_missings" value="false"/> <parameter key="datamanagement" value="double_array"/> <parameter key="data_management" value="auto"/> </operator> <operator activated="true" class="de_pivot" compatibility="9.2.000" expanded="true" height="82" name="De-Pivot" width="90" x="179" y="34"> <list key="attribute_name"> <parameter key="genre" value="genre.+"/> </list> <parameter key="index_attribute" value="index"/> <parameter key="create_nominal_index" value="false"/> <parameter key="keep_missings" value="false"/> </operator> <operator activated="true" class="set_role" compatibility="9.2.000" expanded="true" height="82" name="Set Role" width="90" x="313" y="34"> <parameter key="attribute_name" value="genre"/> <parameter key="target_role" value="label"/> <list key="set_additional_roles"/> </operator> <connect from_op="Read CSV" from_port="output" to_op="De-Pivot" to_port="example set input"/> <connect from_op="De-Pivot" from_port="example set output" to_op="Set Role" to_port="example set input"/> <connect from_op="Set Role" from_port="example set output" to_port="result 1"/> <portSpacing port="source_input 1" spacing="0"/> <portSpacing port="sink_result 1" spacing="0"/> <portSpacing port="sink_result 2" spacing="0"/> </process> </operator> </process>
