<?xml version="1.0" encoding="UTF-8"?><process version="9.2.000"> <context> <input/> <output/> <macros/> </context> <operator activated="true" class="process" compatibility="9.2.000" expanded="true" name="Process"> <parameter key="logverbosity" value="init"/> <parameter key="random_seed" value="2001"/> <parameter key="send_mail" value="never"/> <parameter key="notification_email" value=""/> <parameter key="process_duration_for_mail" value="30"/> <parameter key="encoding" value="SYSTEM"/> <process expanded="true"> <operator activated="true" breakpoints="after" class="read_excel" compatibility="9.2.000" expanded="true" height="68" name="Read Excel" width="90" x="179" y="85"> <parameter key="excel_file" value="C:\Users\Lionel\Documents\Formations_DataScience\Rapidminer\Tests_Rapidminer\Impute_column_missing_values\Sample_Data_2_Impute.xlsx"/> <parameter key="sheet_selection" value="sheet number"/> <parameter key="sheet_number" value="1"/> <parameter key="imported_cell_range" value="A1"/> <parameter key="encoding" value="SYSTEM"/> <parameter key="first_row_as_names" value="true"/> <list key="annotations"/> <parameter key="date_format" value=""/> <parameter key="time_zone" value="SYSTEM"/> <parameter key="locale" value="English (United States)"/> <parameter key="read_all_values_as_polynominal" value="false"/> <list key="data_set_meta_data_information"> <parameter key="0" value="ID.true.integer.attribute"/> <parameter key="1" value="2017-01.true.integer.attribute"/> <parameter key="2" value="2017-02.true.integer.attribute"/> <parameter key="3" value="2017-03.true.integer.attribute"/> <parameter key="4" value="2017-04.true.integer.attribute"/> <parameter key="5" value="2017-05.true.integer.attribute"/> <parameter key="6" value="2017-06.true.integer.attribute"/> <parameter key="7" value="2017-07.true.integer.attribute"/> <parameter key="8" value="2017-08.true.integer.attribute"/> <parameter key="9" value="2017-09.true.integer.attribute"/> <parameter key="10" value="2017-10.true.integer.attribute"/> <parameter key="11" value="2017-11.true.integer.attribute"/> <parameter key="12" value="2017-12.true.integer.attribute"/> <parameter key="13" value="2018-01.true.integer.attribute"/> <parameter key="14" value="2018-02.true.integer.attribute"/> <parameter key="15" value="2018-03.true.integer.attribute"/> <parameter key="16" value="2018-04.true.integer.attribute"/> <parameter key="17" value="2018-05.true.integer.attribute"/> <parameter key="18" value="2018-06.true.integer.attribute"/> <parameter key="19" value="2018-07.true.integer.attribute"/> <parameter key="20" value="2018-08.true.integer.attribute"/> <parameter key="21" value="2018-09.true.integer.attribute"/> <parameter key="22" value="2018-10.true.integer.attribute"/> <parameter key="23" value="2018-11.true.integer.attribute"/> <parameter key="24" value="2018-12.true.integer.attribute"/> </list> <parameter key="read_not_matching_values_as_missings" value="false"/> <parameter key="datamanagement" value="double_array"/> <parameter key="data_management" value="auto"/> </operator> <operator activated="true" class="transpose" compatibility="9.2.000" expanded="true" height="82" name="Transpose" width="90" x="313" y="85"/> <operator activated="true" class="select_attributes" compatibility="9.2.000" expanded="true" height="82" name="Select Attributes" width="90" x="447" y="187"> <parameter key="attribute_filter_type" value="single"/> <parameter key="attribute" value="ID"/> <parameter key="attributes" value=""/> <parameter key="use_except_expression" value="false"/> <parameter key="value_type" value="attribute_value"/> <parameter key="use_value_type_exception" value="false"/> <parameter key="except_value_type" value="time"/> <parameter key="block_type" value="attribute_block"/> <parameter key="use_block_type_exception" value="false"/> <parameter key="except_block_type" value="value_matrix_row_start"/> <parameter key="invert_selection" value="false"/> <parameter key="include_special_attributes" value="false"/> </operator> <operator activated="true" class="generate_id" compatibility="9.2.000" expanded="true" height="82" name="Generate ID" width="90" x="648" y="238"> <parameter key="create_nominal_ids" value="false"/> <parameter key="offset" value="0"/> </operator> <operator activated="true" class="filter_example_range" compatibility="9.2.000" expanded="true" height="82" name="Filter Example Range" width="90" x="447" y="85"> <parameter key="first_example" value="1"/> <parameter key="last_example" value="1"/> <parameter key="invert_filter" value="true"/> </operator> <operator activated="true" class="replace_missing_values" compatibility="9.2.000" expanded="true" height="103" name="Replace Missing Values" width="90" x="581" y="85"> <parameter key="return_preprocessing_model" value="false"/> <parameter key="create_view" value="false"/> <parameter key="attribute_filter_type" value="all"/> <parameter key="attribute" value=""/> <parameter key="attributes" value=""/> <parameter key="use_except_expression" value="false"/> <parameter key="value_type" value="attribute_value"/> <parameter key="use_value_type_exception" value="false"/> <parameter key="except_value_type" value="time"/> <parameter key="block_type" value="attribute_block"/> <parameter key="use_block_type_exception" value="false"/> <parameter key="except_block_type" value="value_matrix_row_start"/> <parameter key="invert_selection" value="false"/> <parameter key="include_special_attributes" value="false"/> <parameter key="default" value="average"/> <list key="columns"/> </operator> <operator activated="true" class="transpose" compatibility="9.2.000" expanded="true" height="82" name="Transpose (2)" width="90" x="715" y="85"/> <operator activated="true" class="generate_id" compatibility="9.2.000" expanded="true" height="82" name="Generate ID (2)" width="90" x="849" y="85"> <parameter key="create_nominal_ids" value="false"/> <parameter key="offset" value="0"/> </operator> <operator activated="true" class="concurrency:join" compatibility="9.2.000" expanded="true" height="82" name="Join" width="90" x="1050" y="136"> <parameter key="remove_double_attributes" value="true"/> <parameter key="join_type" value="inner"/> <parameter key="use_id_attribute_as_key" value="true"/> <list key="key_attributes"/> <parameter key="keep_both_join_attributes" value="false"/> </operator> <connect from_op="Read Excel" from_port="output" to_op="Transpose" to_port="example set input"/> <connect from_op="Transpose" from_port="example set output" to_op="Filter Example Range" to_port="example set input"/> <connect from_op="Transpose" from_port="original" to_op="Select Attributes" to_port="example set input"/> <connect from_op="Select Attributes" from_port="example set output" to_op="Generate ID" to_port="example set input"/> <connect from_op="Generate ID" from_port="example set output" to_op="Join" to_port="left"/> <connect from_op="Filter Example Range" from_port="example set output" to_op="Replace Missing Values" to_port="example set input"/> <connect from_op="Replace Missing Values" from_port="example set output" to_op="Transpose (2)" to_port="example set input"/> <connect from_op="Transpose (2)" from_port="example set output" to_op="Generate ID (2)" to_port="example set input"/> <connect from_op="Generate ID (2)" from_port="example set output" to_op="Join" to_port="right"/> <connect from_op="Join" from_port="join" to_port="result 1"/> <portSpacing port="source_input 1" spacing="0"/> <portSpacing port="sink_result 1" spacing="0"/> <portSpacing port="sink_result 2" spacing="0"/> </process> </operator> </process>
<?xml version="1.0" encoding="UTF-8"?><process version="9.2.000"> <context> <input/> <output/> <macros/> </context> <operator activated="true" class="process" compatibility="9.2.000" expanded="true" name="Process"> <parameter key="logverbosity" value="init"/> <parameter key="random_seed" value="2001"/> <parameter key="send_mail" value="never"/> <parameter key="notification_email" value=""/> <parameter key="process_duration_for_mail" value="30"/> <parameter key="encoding" value="SYSTEM"/> <process expanded="true"> <operator activated="true" class="read_excel" compatibility="9.2.000" expanded="true" height="68" name="Read Excel" width="90" x="179" y="85"> <parameter key="excel_file" value="C:\Users\Lionel\Documents\Formations_DataScience\Rapidminer\Tests_Rapidminer\Impute_column_missing_values\Sample_Data_2_Impute.xlsx"/> <parameter key="sheet_selection" value="sheet number"/> <parameter key="sheet_number" value="1"/> <parameter key="imported_cell_range" value="A1"/> <parameter key="encoding" value="SYSTEM"/> <parameter key="first_row_as_names" value="true"/> <list key="annotations"/> <parameter key="date_format" value=""/> <parameter key="time_zone" value="SYSTEM"/> <parameter key="locale" value="English (United States)"/> <parameter key="read_all_values_as_polynominal" value="false"/> <list key="data_set_meta_data_information"> <parameter key="0" value="ID.true.integer.attribute"/> <parameter key="1" value="2017-01.true.integer.attribute"/> <parameter key="2" value="2017-02.true.integer.attribute"/> <parameter key="3" value="2017-03.true.integer.attribute"/> <parameter key="4" value="2017-04.true.integer.attribute"/> <parameter key="5" value="2017-05.true.integer.attribute"/> <parameter key="6" value="2017-06.true.integer.attribute"/> <parameter key="7" value="2017-07.true.integer.attribute"/> <parameter key="8" value="2017-08.true.integer.attribute"/> <parameter key="9" value="2017-09.true.integer.attribute"/> <parameter key="10" value="2017-10.true.integer.attribute"/> <parameter key="11" value="2017-11.true.integer.attribute"/> <parameter key="12" value="2017-12.true.integer.attribute"/> <parameter key="13" value="2018-01.true.integer.attribute"/> <parameter key="14" value="2018-02.true.integer.attribute"/> <parameter key="15" value="2018-03.true.integer.attribute"/> <parameter key="16" value="2018-04.true.integer.attribute"/> <parameter key="17" value="2018-05.true.integer.attribute"/> <parameter key="18" value="2018-06.true.integer.attribute"/> <parameter key="19" value="2018-07.true.integer.attribute"/> <parameter key="20" value="2018-08.true.integer.attribute"/> <parameter key="21" value="2018-09.true.integer.attribute"/> <parameter key="22" value="2018-10.true.integer.attribute"/> <parameter key="23" value="2018-11.true.integer.attribute"/> <parameter key="24" value="2018-12.true.integer.attribute"/> </list> <parameter key="read_not_matching_values_as_missings" value="false"/> <parameter key="datamanagement" value="double_array"/> <parameter key="data_management" value="auto"/> </operator> <operator activated="true" class="transpose" compatibility="9.2.000" expanded="true" height="82" name="Transpose" width="90" x="313" y="85"/> <operator activated="true" class="filter_example_range" compatibility="9.2.000" expanded="true" height="82" name="Filter Example Range" width="90" x="447" y="85"> <parameter key="first_example" value="1"/> <parameter key="last_example" value="1"/> <parameter key="invert_filter" value="true"/> </operator> <operator activated="true" breakpoints="before" class="impute_missing_values" compatibility="9.2.000" expanded="true" height="68" name="Impute Missing Values (4)" width="90" x="581" y="85"> <parameter key="attribute_filter_type" value="value_type"/> <parameter key="attribute" value=""/> <parameter key="attributes" value=""/> <parameter key="use_except_expression" value="false"/> <parameter key="value_type" value="numeric"/> <parameter key="use_value_type_exception" value="false"/> <parameter key="except_value_type" value="time"/> <parameter key="block_type" value="attribute_block"/> <parameter key="use_block_type_exception" value="false"/> <parameter key="except_block_type" value="value_matrix_row_start"/> <parameter key="invert_selection" value="false"/> <parameter key="include_special_attributes" value="false"/> <parameter key="iterate" value="true"/> <parameter key="learn_on_complete_cases" value="true"/> <parameter key="order" value="chronological"/> <parameter key="sort" value="ascending"/> <parameter key="use_local_random_seed" value="false"/> <parameter key="local_random_seed" value="1992"/> <process expanded="true"> <operator activated="true" breakpoints="before" class="neural_net" compatibility="9.2.000" expanded="true" height="82" name="Neural Net (2)" width="90" x="447" y="34"> <list key="hidden_layers"/> <parameter key="training_cycles" value="200"/> <parameter key="learning_rate" value="0.01"/> <parameter key="momentum" value="0.9"/> <parameter key="decay" value="false"/> <parameter key="shuffle" value="true"/> <parameter key="normalize" value="true"/> <parameter key="error_epsilon" value="1.0E-4"/> <parameter key="use_local_random_seed" value="false"/> <parameter key="local_random_seed" value="1992"/> </operator> <connect from_port="example set source" to_op="Neural Net (2)" to_port="training set"/> <connect from_op="Neural Net (2)" from_port="model" to_port="model sink"/> <portSpacing port="source_example set source" spacing="0"/> <portSpacing port="sink_model sink" spacing="0"/> </process> </operator> <operator activated="true" class="select_attributes" compatibility="9.2.000" expanded="true" height="82" name="Select Attributes" width="90" x="447" y="187"> <parameter key="attribute_filter_type" value="single"/> <parameter key="attribute" value="ID"/> <parameter key="attributes" value=""/> <parameter key="use_except_expression" value="false"/> <parameter key="value_type" value="attribute_value"/> <parameter key="use_value_type_exception" value="false"/> <parameter key="except_value_type" value="time"/> <parameter key="block_type" value="attribute_block"/> <parameter key="use_block_type_exception" value="false"/> <parameter key="except_block_type" value="value_matrix_row_start"/> <parameter key="invert_selection" value="false"/> <parameter key="include_special_attributes" value="false"/> </operator> <operator activated="true" class="generate_id" compatibility="9.2.000" expanded="true" height="82" name="Generate ID" width="90" x="648" y="238"> <parameter key="create_nominal_ids" value="false"/> <parameter key="offset" value="0"/> </operator> <operator activated="false" class="subprocess" compatibility="9.2.000" expanded="true" height="82" name="Subprocess" width="90" x="648" y="442"> <process expanded="true"> <operator activated="false" class="multiply" compatibility="9.2.000" expanded="true" height="68" name="Multiply" width="90" x="45" y="136"/> <operator activated="false" class="materialize_data" compatibility="9.2.000" expanded="true" height="82" name="DT then NN" width="90" x="179" y="34"> <parameter key="datamanagement" value="double_array"/> <parameter key="data_management" value="auto"/> </operator> <operator activated="false" class="materialize_data" compatibility="9.2.000" expanded="true" height="82" name="kNN" width="90" x="246" y="238"> <parameter key="datamanagement" value="double_array"/> <parameter key="data_management" value="auto"/> </operator> <operator activated="false" breakpoints="before" class="impute_missing_values" compatibility="7.3.001" expanded="true" height="68" name="Impute Missing Values (3)" width="90" x="380" y="187"> <parameter key="attribute_filter_type" value="all"/> <parameter key="attribute" value=""/> <parameter key="attributes" value=""/> <parameter key="use_except_expression" value="false"/> <parameter key="value_type" value="numeric"/> <parameter key="use_value_type_exception" value="false"/> <parameter key="except_value_type" value="time"/> <parameter key="block_type" value="attribute_block"/> <parameter key="use_block_type_exception" value="false"/> <parameter key="except_block_type" value="value_matrix_row_start"/> <parameter key="invert_selection" value="false"/> <parameter key="include_special_attributes" value="false"/> <parameter key="iterate" value="true"/> <parameter key="learn_on_complete_cases" value="true"/> <parameter key="order" value="chronological"/> <parameter key="sort" value="ascending"/> <parameter key="use_local_random_seed" value="false"/> <parameter key="local_random_seed" value="1992"/> <process expanded="true"> <operator activated="true" class="k_nn" compatibility="9.2.000" expanded="true" height="82" name="k-NN" width="90" x="112" y="34"> <parameter key="k" value="1"/> <parameter key="weighted_vote" value="false"/> <parameter key="measure_types" value="MixedMeasures"/> <parameter key="mixed_measure" value="MixedEuclideanDistance"/> <parameter key="nominal_measure" value="NominalDistance"/> <parameter key="numerical_measure" value="EuclideanDistance"/> <parameter key="divergence" value="GeneralizedIDivergence"/> <parameter key="kernel_type" value="radial"/> <parameter key="kernel_gamma" value="1.0"/> <parameter key="kernel_sigma1" value="1.0"/> <parameter key="kernel_sigma2" value="0.0"/> <parameter key="kernel_sigma3" value="2.0"/> <parameter key="kernel_degree" value="3.0"/> <parameter key="kernel_shift" value="1.0"/> <parameter key="kernel_a" value="1.0"/> <parameter key="kernel_b" value="0.0"/> </operator> <connect from_port="example set source" to_op="k-NN" to_port="training set"/> <connect from_op="k-NN" from_port="model" to_port="model sink"/> <portSpacing port="source_example set source" spacing="0"/> <portSpacing port="sink_model sink" spacing="0"/> </process> </operator> <operator activated="false" class="impute_missing_values" compatibility="7.3.001" expanded="true" height="68" name="Impute Missing Values" width="90" x="313" y="34"> <parameter key="attribute_filter_type" value="value_type"/> <parameter key="attribute" value=""/> <parameter key="attributes" value=""/> <parameter key="use_except_expression" value="false"/> <parameter key="value_type" value="nominal"/> <parameter key="use_value_type_exception" value="false"/> <parameter key="except_value_type" value="time"/> <parameter key="block_type" value="attribute_block"/> <parameter key="use_block_type_exception" value="false"/> <parameter key="except_block_type" value="value_matrix_row_start"/> <parameter key="invert_selection" value="false"/> <parameter key="include_special_attributes" value="false"/> <parameter key="iterate" value="true"/> <parameter key="learn_on_complete_cases" value="true"/> <parameter key="order" value="chronological"/> <parameter key="sort" value="ascending"/> <parameter key="use_local_random_seed" value="false"/> <parameter key="local_random_seed" value="1992"/> <process expanded="true"> <operator activated="true" breakpoints="before,after" class="concurrency:parallel_decision_tree" compatibility="9.2.000" expanded="true" height="103" name="Decision Tree" width="90" x="380" y="34"> <parameter key="criterion" value="gain_ratio"/> <parameter key="maximal_depth" value="20"/> <parameter key="apply_pruning" value="true"/> <parameter key="confidence" value="0.25"/> <parameter key="apply_prepruning" value="true"/> <parameter key="minimal_gain" value="0.1"/> <parameter key="minimal_leaf_size" value="2"/> <parameter key="minimal_size_for_split" value="4"/> <parameter key="number_of_prepruning_alternatives" value="3"/> </operator> <connect from_port="example set source" to_op="Decision Tree" to_port="training set"/> <connect from_op="Decision Tree" from_port="model" to_port="model sink"/> <portSpacing port="source_example set source" spacing="0"/> <portSpacing port="sink_model sink" spacing="0"/> </process> </operator> <operator activated="true" class="impute_missing_values" compatibility="7.3.001" expanded="true" height="68" name="Impute Missing Values (2)" width="90" x="447" y="34"> <parameter key="attribute_filter_type" value="value_type"/> <parameter key="attribute" value=""/> <parameter key="attributes" value=""/> <parameter key="use_except_expression" value="false"/> <parameter key="value_type" value="numeric"/> <parameter key="use_value_type_exception" value="false"/> <parameter key="except_value_type" value="time"/> <parameter key="block_type" value="attribute_block"/> <parameter key="use_block_type_exception" value="false"/> <parameter key="except_block_type" value="value_matrix_row_start"/> <parameter key="invert_selection" value="false"/> <parameter key="include_special_attributes" value="false"/> <parameter key="iterate" value="true"/> <parameter key="learn_on_complete_cases" value="true"/> <parameter key="order" value="chronological"/> <parameter key="sort" value="ascending"/> <parameter key="use_local_random_seed" value="false"/> <parameter key="local_random_seed" value="1992"/> <process expanded="true"> <operator activated="true" breakpoints="before" class="neural_net" compatibility="9.2.000" expanded="true" height="82" name="Neural Net" width="90" x="179" y="34"> <list key="hidden_layers"/> <parameter key="training_cycles" value="500"/> <parameter key="learning_rate" value="0.3"/> <parameter key="momentum" value="0.2"/> <parameter key="decay" value="false"/> <parameter key="shuffle" value="true"/> <parameter key="normalize" value="true"/> <parameter key="error_epsilon" value="1.0E-5"/> <parameter key="use_local_random_seed" value="false"/> <parameter key="local_random_seed" value="1992"/> </operator> <connect from_port="example set source" to_op="Neural Net" to_port="training set"/> <connect from_op="Neural Net" from_port="model" to_port="model sink"/> <portSpacing port="source_example set source" spacing="0"/> <portSpacing port="sink_model sink" spacing="0"/> </process> </operator> <connect from_port="in 1" to_op="Impute Missing Values (2)" to_port="example set in"/> <connect from_op="Impute Missing Values (2)" from_port="example set out" to_port="out 1"/> <portSpacing port="source_in 1" spacing="0"/> <portSpacing port="source_in 2" spacing="0"/> <portSpacing port="sink_out 1" spacing="0"/> <portSpacing port="sink_out 2" spacing="0"/> <description align="center" color="yellow" colored="false" height="105" resized="false" width="180" x="601" y="506">Type your comment</description> </process> </operator> <operator activated="false" class="replace_missing_values" compatibility="9.2.000" expanded="true" height="103" name="Replace Missing Values" width="90" x="313" y="442"> <parameter key="return_preprocessing_model" value="false"/> <parameter key="create_view" value="false"/> <parameter key="attribute_filter_type" value="all"/> <parameter key="attribute" value=""/> <parameter key="attributes" value=""/> <parameter key="use_except_expression" value="false"/> <parameter key="value_type" value="attribute_value"/> <parameter key="use_value_type_exception" value="false"/> <parameter key="except_value_type" value="time"/> <parameter key="block_type" value="attribute_block"/> <parameter key="use_block_type_exception" value="false"/> <parameter key="except_block_type" value="value_matrix_row_start"/> <parameter key="invert_selection" value="false"/> <parameter key="include_special_attributes" value="false"/> <parameter key="default" value="average"/> <list key="columns"/> </operator> <operator activated="true" class="transpose" compatibility="9.2.000" expanded="true" height="82" name="Transpose (2)" width="90" x="715" y="85"/> <operator activated="true" class="generate_id" compatibility="9.2.000" expanded="true" height="82" name="Generate ID (2)" width="90" x="849" y="85"> <parameter key="create_nominal_ids" value="false"/> <parameter key="offset" value="0"/> </operator> <operator activated="true" class="concurrency:join" compatibility="9.2.000" expanded="true" height="82" name="Join" width="90" x="1050" y="136"> <parameter key="remove_double_attributes" value="true"/> <parameter key="join_type" value="inner"/> <parameter key="use_id_attribute_as_key" value="true"/> <list key="key_attributes"/> <parameter key="keep_both_join_attributes" value="false"/> </operator> <connect from_op="Read Excel" from_port="output" to_op="Transpose" to_port="example set input"/> <connect from_op="Transpose" from_port="example set output" to_op="Filter Example Range" to_port="example set input"/> <connect from_op="Transpose" from_port="original" to_op="Select Attributes" to_port="example set input"/> <connect from_op="Filter Example Range" from_port="example set output" to_op="Impute Missing Values (4)" to_port="example set in"/> <connect from_op="Impute Missing Values (4)" from_port="example set out" to_op="Transpose (2)" to_port="example set input"/> <connect from_op="Select Attributes" from_port="example set output" to_op="Generate ID" to_port="example set input"/> <connect from_op="Generate ID" from_port="example set output" to_op="Join" to_port="left"/> <connect from_op="Transpose (2)" from_port="example set output" to_op="Generate ID (2)" to_port="example set input"/> <connect from_op="Generate ID (2)" from_port="example set output" to_op="Join" to_port="right"/> <connect from_op="Join" from_port="join" to_port="result 1"/> <portSpacing port="source_input 1" spacing="0"/> <portSpacing port="sink_result 1" spacing="0"/> <portSpacing port="sink_result 2" spacing="0"/> </process> </operator> </process>
<?xml version="1.0" encoding="UTF-8"?><process version="9.2.000"> <context> <input/> <output/> <macros/> </context> <operator activated="true" class="process" compatibility="9.2.000" expanded="true" name="Process"> <parameter key="logverbosity" value="init"/> <parameter key="random_seed" value="2001"/> <parameter key="send_mail" value="never"/> <parameter key="notification_email" value=""/> <parameter key="process_duration_for_mail" value="30"/> <parameter key="encoding" value="SYSTEM"/> <process expanded="true"> <operator activated="true" class="read_excel" compatibility="9.2.000" expanded="true" height="68" name="Read Excel" width="90" x="179" y="85"> <parameter key="excel_file" value="/Users/genzerconsulting/Desktop/Sample_Data_2_Impute.xlsx"/> <parameter key="sheet_selection" value="sheet number"/> <parameter key="sheet_number" value="1"/> <parameter key="imported_cell_range" value="A1"/> <parameter key="encoding" value="SYSTEM"/> <parameter key="first_row_as_names" value="true"/> <list key="annotations"/> <parameter key="date_format" value=""/> <parameter key="time_zone" value="SYSTEM"/> <parameter key="locale" value="English (United States)"/> <parameter key="read_all_values_as_polynominal" value="false"/> <list key="data_set_meta_data_information"> <parameter key="0" value="ID.true.integer.attribute"/> <parameter key="1" value="2017-01.true.integer.attribute"/> <parameter key="2" value="2017-02.true.integer.attribute"/> <parameter key="3" value="2017-03.true.integer.attribute"/> <parameter key="4" value="2017-04.true.integer.attribute"/> <parameter key="5" value="2017-05.true.integer.attribute"/> <parameter key="6" value="2017-06.true.integer.attribute"/> <parameter key="7" value="2017-07.true.integer.attribute"/> <parameter key="8" value="2017-08.true.integer.attribute"/> <parameter key="9" value="2017-09.true.integer.attribute"/> <parameter key="10" value="2017-10.true.integer.attribute"/> <parameter key="11" value="2017-11.true.integer.attribute"/> <parameter key="12" value="2017-12.true.integer.attribute"/> <parameter key="13" value="2018-01.true.integer.attribute"/> <parameter key="14" value="2018-02.true.integer.attribute"/> <parameter key="15" value="2018-03.true.integer.attribute"/> <parameter key="16" value="2018-04.true.integer.attribute"/> <parameter key="17" value="2018-05.true.integer.attribute"/> <parameter key="18" value="2018-06.true.integer.attribute"/> <parameter key="19" value="2018-07.true.integer.attribute"/> <parameter key="20" value="2018-08.true.integer.attribute"/> <parameter key="21" value="2018-09.true.integer.attribute"/> <parameter key="22" value="2018-10.true.integer.attribute"/> <parameter key="23" value="2018-11.true.integer.attribute"/> <parameter key="24" value="2018-12.true.integer.attribute"/> </list> <parameter key="read_not_matching_values_as_missings" value="false"/> <parameter key="datamanagement" value="double_array"/> <parameter key="data_management" value="auto"/> </operator> <operator activated="true" class="transpose" compatibility="9.2.000" expanded="true" height="82" name="Transpose" width="90" x="313" y="85"/> <operator activated="true" breakpoints="after" class="filter_example_range" compatibility="9.2.000" expanded="true" height="82" name="Filter Example Range" width="90" x="447" y="85"> <parameter key="first_example" value="1"/> <parameter key="last_example" value="1"/> <parameter key="invert_filter" value="true"/> </operator> <operator activated="true" class="select_attributes" compatibility="9.2.000" expanded="true" height="82" name="Select Attributes" width="90" x="447" y="187"> <parameter key="attribute_filter_type" value="single"/> <parameter key="attribute" value="ID"/> <parameter key="attributes" value=""/> <parameter key="use_except_expression" value="false"/> <parameter key="value_type" value="attribute_value"/> <parameter key="use_value_type_exception" value="false"/> <parameter key="except_value_type" value="time"/> <parameter key="block_type" value="attribute_block"/> <parameter key="use_block_type_exception" value="false"/> <parameter key="except_block_type" value="value_matrix_row_start"/> <parameter key="invert_selection" value="false"/> <parameter key="include_special_attributes" value="false"/> </operator> <operator activated="true" class="generate_id" compatibility="9.2.000" expanded="true" height="82" name="Generate ID" width="90" x="648" y="238"> <parameter key="create_nominal_ids" value="false"/> <parameter key="offset" value="0"/> </operator> <operator activated="false" class="subprocess" compatibility="9.2.000" expanded="true" height="82" name="Subprocess" width="90" x="648" y="442"> <process expanded="true"> <operator activated="false" class="multiply" compatibility="9.2.000" expanded="true" height="68" name="Multiply" width="90" x="45" y="136"/> <operator activated="false" class="materialize_data" compatibility="9.2.000" expanded="true" height="82" name="DT then NN" width="90" x="179" y="34"> <parameter key="datamanagement" value="double_array"/> <parameter key="data_management" value="auto"/> </operator> <operator activated="false" class="materialize_data" compatibility="9.2.000" expanded="true" height="82" name="kNN" width="90" x="246" y="238"> <parameter key="datamanagement" value="double_array"/> <parameter key="data_management" value="auto"/> </operator> <operator activated="false" breakpoints="before" class="impute_missing_values" compatibility="7.3.001" expanded="true" height="68" name="Impute Missing Values (3)" width="90" x="380" y="187"> <parameter key="attribute_filter_type" value="all"/> <parameter key="attribute" value=""/> <parameter key="attributes" value=""/> <parameter key="use_except_expression" value="false"/> <parameter key="value_type" value="numeric"/> <parameter key="use_value_type_exception" value="false"/> <parameter key="except_value_type" value="time"/> <parameter key="block_type" value="attribute_block"/> <parameter key="use_block_type_exception" value="false"/> <parameter key="except_block_type" value="value_matrix_row_start"/> <parameter key="invert_selection" value="false"/> <parameter key="include_special_attributes" value="false"/> <parameter key="iterate" value="true"/> <parameter key="learn_on_complete_cases" value="true"/> <parameter key="order" value="chronological"/> <parameter key="sort" value="ascending"/> <parameter key="use_local_random_seed" value="false"/> <parameter key="local_random_seed" value="1992"/> <process expanded="true"> <operator activated="true" class="k_nn" compatibility="9.2.000" expanded="true" height="82" name="k-NN" width="90" x="112" y="34"> <parameter key="k" value="1"/> <parameter key="weighted_vote" value="false"/> <parameter key="measure_types" value="MixedMeasures"/> <parameter key="mixed_measure" value="MixedEuclideanDistance"/> <parameter key="nominal_measure" value="NominalDistance"/> <parameter key="numerical_measure" value="EuclideanDistance"/> <parameter key="divergence" value="GeneralizedIDivergence"/> <parameter key="kernel_type" value="radial"/> <parameter key="kernel_gamma" value="1.0"/> <parameter key="kernel_sigma1" value="1.0"/> <parameter key="kernel_sigma2" value="0.0"/> <parameter key="kernel_sigma3" value="2.0"/> <parameter key="kernel_degree" value="3.0"/> <parameter key="kernel_shift" value="1.0"/> <parameter key="kernel_a" value="1.0"/> <parameter key="kernel_b" value="0.0"/> </operator> <connect from_port="example set source" to_op="k-NN" to_port="training set"/> <connect from_op="k-NN" from_port="model" to_port="model sink"/> <portSpacing port="source_example set source" spacing="0"/> <portSpacing port="sink_model sink" spacing="0"/> </process> </operator> <operator activated="false" class="impute_missing_values" compatibility="7.3.001" expanded="true" height="68" name="Impute Missing Values" width="90" x="313" y="34"> <parameter key="attribute_filter_type" value="value_type"/> <parameter key="attribute" value=""/> <parameter key="attributes" value=""/> <parameter key="use_except_expression" value="false"/> <parameter key="value_type" value="nominal"/> <parameter key="use_value_type_exception" value="false"/> <parameter key="except_value_type" value="time"/> <parameter key="block_type" value="attribute_block"/> <parameter key="use_block_type_exception" value="false"/> <parameter key="except_block_type" value="value_matrix_row_start"/> <parameter key="invert_selection" value="false"/> <parameter key="include_special_attributes" value="false"/> <parameter key="iterate" value="true"/> <parameter key="learn_on_complete_cases" value="true"/> <parameter key="order" value="chronological"/> <parameter key="sort" value="ascending"/> <parameter key="use_local_random_seed" value="false"/> <parameter key="local_random_seed" value="1992"/> <process expanded="true"> <operator activated="true" breakpoints="before,after" class="concurrency:parallel_decision_tree" compatibility="9.2.000" expanded="true" height="103" name="Decision Tree" width="90" x="380" y="34"> <parameter key="criterion" value="gain_ratio"/> <parameter key="maximal_depth" value="20"/> <parameter key="apply_pruning" value="true"/> <parameter key="confidence" value="0.25"/> <parameter key="apply_prepruning" value="true"/> <parameter key="minimal_gain" value="0.1"/> <parameter key="minimal_leaf_size" value="2"/> <parameter key="minimal_size_for_split" value="4"/> <parameter key="number_of_prepruning_alternatives" value="3"/> </operator> <connect from_port="example set source" to_op="Decision Tree" to_port="training set"/> <connect from_op="Decision Tree" from_port="model" to_port="model sink"/> <portSpacing port="source_example set source" spacing="0"/> <portSpacing port="sink_model sink" spacing="0"/> </process> </operator> <operator activated="true" class="impute_missing_values" compatibility="7.3.001" expanded="true" height="68" name="Impute Missing Values (2)" width="90" x="447" y="34"> <parameter key="attribute_filter_type" value="value_type"/> <parameter key="attribute" value=""/> <parameter key="attributes" value=""/> <parameter key="use_except_expression" value="false"/> <parameter key="value_type" value="numeric"/> <parameter key="use_value_type_exception" value="false"/> <parameter key="except_value_type" value="time"/> <parameter key="block_type" value="attribute_block"/> <parameter key="use_block_type_exception" value="false"/> <parameter key="except_block_type" value="value_matrix_row_start"/> <parameter key="invert_selection" value="false"/> <parameter key="include_special_attributes" value="false"/> <parameter key="iterate" value="true"/> <parameter key="learn_on_complete_cases" value="true"/> <parameter key="order" value="chronological"/> <parameter key="sort" value="ascending"/> <parameter key="use_local_random_seed" value="false"/> <parameter key="local_random_seed" value="1992"/> <process expanded="true"> <operator activated="true" breakpoints="before" class="neural_net" compatibility="9.2.000" expanded="true" height="82" name="Neural Net" width="90" x="179" y="34"> <list key="hidden_layers"/> <parameter key="training_cycles" value="500"/> <parameter key="learning_rate" value="0.3"/> <parameter key="momentum" value="0.2"/> <parameter key="decay" value="false"/> <parameter key="shuffle" value="true"/> <parameter key="normalize" value="true"/> <parameter key="error_epsilon" value="1.0E-5"/> <parameter key="use_local_random_seed" value="false"/> <parameter key="local_random_seed" value="1992"/> </operator> <connect from_port="example set source" to_op="Neural Net" to_port="training set"/> <connect from_op="Neural Net" from_port="model" to_port="model sink"/> <portSpacing port="source_example set source" spacing="0"/> <portSpacing port="sink_model sink" spacing="0"/> </process> </operator> <connect from_port="in 1" to_op="Impute Missing Values (2)" to_port="example set in"/> <connect from_op="Impute Missing Values (2)" from_port="example set out" to_port="out 1"/> <portSpacing port="source_in 1" spacing="0"/> <portSpacing port="source_in 2" spacing="0"/> <portSpacing port="sink_out 1" spacing="0"/> <portSpacing port="sink_out 2" spacing="0"/> <description align="center" color="yellow" colored="false" height="105" resized="false" width="180" x="601" y="506">Type your comment</description> </process> </operator> <operator activated="false" class="replace_missing_values" compatibility="9.2.000" expanded="true" height="103" name="Replace Missing Values" width="90" x="313" y="442"> <parameter key="return_preprocessing_model" value="false"/> <parameter key="create_view" value="false"/> <parameter key="attribute_filter_type" value="all"/> <parameter key="attribute" value=""/> <parameter key="attributes" value=""/> <parameter key="use_except_expression" value="false"/> <parameter key="value_type" value="attribute_value"/> <parameter key="use_value_type_exception" value="false"/> <parameter key="except_value_type" value="time"/> <parameter key="block_type" value="attribute_block"/> <parameter key="use_block_type_exception" value="false"/> <parameter key="except_block_type" value="value_matrix_row_start"/> <parameter key="invert_selection" value="false"/> <parameter key="include_special_attributes" value="false"/> <parameter key="default" value="average"/> <list key="columns"/> </operator> <operator activated="true" class="impute_missing_values" compatibility="9.2.000" expanded="true" height="68" name="Impute Missing Values (4)" width="90" x="581" y="85"> <parameter key="attribute_filter_type" value="all"/> <parameter key="attribute" value=""/> <parameter key="attributes" value=""/> <parameter key="use_except_expression" value="false"/> <parameter key="value_type" value="real"/> <parameter key="use_value_type_exception" value="false"/> <parameter key="except_value_type" value="time"/> <parameter key="block_type" value="attribute_block"/> <parameter key="use_block_type_exception" value="false"/> <parameter key="except_block_type" value="value_matrix_row_start"/> <parameter key="invert_selection" value="false"/> <parameter key="include_special_attributes" value="false"/> <parameter key="iterate" value="true"/> <parameter key="learn_on_complete_cases" value="false"/> <parameter key="order" value="chronological"/> <parameter key="sort" value="ascending"/> <parameter key="use_local_random_seed" value="false"/> <parameter key="local_random_seed" value="1992"/> <process expanded="true"> <operator activated="true" class="k_nn" compatibility="9.2.000" expanded="true" height="82" name="k-NN (2)" width="90" x="380" y="34"> <parameter key="k" value="5"/> <parameter key="weighted_vote" value="true"/> <parameter key="measure_types" value="MixedMeasures"/> <parameter key="mixed_measure" value="MixedEuclideanDistance"/> <parameter key="nominal_measure" value="NominalDistance"/> <parameter key="numerical_measure" value="EuclideanDistance"/> <parameter key="divergence" value="GeneralizedIDivergence"/> <parameter key="kernel_type" value="radial"/> <parameter key="kernel_gamma" value="1.0"/> <parameter key="kernel_sigma1" value="1.0"/> <parameter key="kernel_sigma2" value="0.0"/> <parameter key="kernel_sigma3" value="2.0"/> <parameter key="kernel_degree" value="3.0"/> <parameter key="kernel_shift" value="1.0"/> <parameter key="kernel_a" value="1.0"/> <parameter key="kernel_b" value="0.0"/> </operator> <connect from_port="example set source" to_op="k-NN (2)" to_port="training set"/> <connect from_op="k-NN (2)" from_port="model" to_port="model sink"/> <portSpacing port="source_example set source" spacing="0"/> <portSpacing port="sink_model sink" spacing="0"/> </process> </operator> <operator activated="true" class="transpose" compatibility="9.2.000" expanded="true" height="82" name="Transpose (2)" width="90" x="715" y="85"/> <operator activated="true" class="generate_id" compatibility="9.2.000" expanded="true" height="82" name="Generate ID (2)" width="90" x="849" y="85"> <parameter key="create_nominal_ids" value="false"/> <parameter key="offset" value="0"/> </operator> <operator activated="true" class="concurrency:join" compatibility="9.2.000" expanded="true" height="82" name="Join" width="90" x="1050" y="136"> <parameter key="remove_double_attributes" value="true"/> <parameter key="join_type" value="inner"/> <parameter key="use_id_attribute_as_key" value="true"/> <list key="key_attributes"/> <parameter key="keep_both_join_attributes" value="false"/> </operator> <connect from_op="Read Excel" from_port="output" to_op="Transpose" to_port="example set input"/> <connect from_op="Transpose" from_port="example set output" to_op="Filter Example Range" to_port="example set input"/> <connect from_op="Transpose" from_port="original" to_op="Select Attributes" to_port="example set input"/> <connect from_op="Filter Example Range" from_port="example set output" to_op="Impute Missing Values (4)" to_port="example set in"/> <connect from_op="Select Attributes" from_port="example set output" to_op="Generate ID" to_port="example set input"/> <connect from_op="Generate ID" from_port="example set output" to_op="Join" to_port="left"/> <connect from_op="Impute Missing Values (4)" from_port="example set out" to_op="Transpose (2)" to_port="example set input"/> <connect from_op="Transpose (2)" from_port="example set output" to_op="Generate ID (2)" to_port="example set input"/> <connect from_op="Generate ID (2)" from_port="example set output" to_op="Join" to_port="right"/> <connect from_op="Join" from_port="join" to_port="result 1"/> <portSpacing port="source_input 1" spacing="0"/> <portSpacing port="sink_result 1" spacing="0"/> <portSpacing port="sink_result 2" spacing="0"/> </process> </operator> </process>
Lastly, if i try to build a ensemble here, is there any way i can evaluate a imputation performance of various learners ??
As Always Thank you for your valuable advice and time.
