I would like to know how we can relate near field solutions and reflection coefficients in the simulations of periodic structures. When I simulate the Jerusalem cross FSS model in the example guide, near field results above the structure are always greater than the incident field (which is 1 V/m). Moreover, when the reflection coefficients are requested on the plane positioned above the structure where near field results are calculated, there is no correlation between near field results and reflection coefficient results when they are plotted as a function of frequency. Since the reflection coefficient is basically Er/Ei, how should we interpret near field results and Er?
Thanks.
