<?xml version="1.0" encoding="UTF-8"?><process version="9.1.000"><br> <context><br> <input/><br> <output/><br> <macros/><br> </context><br> <operator activated="true" class="process" compatibility="6.0.002" expanded="true" name="Root" origin="GENERATED_TUTORIAL"><br> <parameter key="logverbosity" value="init"/><br> <parameter key="random_seed" value="2000"/><br> <parameter key="send_mail" value="never"/><br> <parameter key="notification_email" value=""/><br> <parameter key="process_duration_for_mail" value="30"/><br> <parameter key="encoding" value="SYSTEM"/><br> <process expanded="true"><br> <operator activated="true" class="retrieve" compatibility="9.1.000" expanded="true" height="68" name="Retrieve Titanic Training" width="90" x="112" y="34"><br> <parameter key="repository_entry" value="//Samples/data/Titanic Training"/><br> </operator><br> <operator activated="true" class="optimize_selection_evolutionary" compatibility="9.1.000" expanded="true" height="103" name="Optimize Selection (Evolutionary)" origin="GENERATED_TUTORIAL" width="90" x="380" y="34"><br> <parameter key="use_exact_number_of_attributes" value="false"/><br> <parameter key="restrict_maximum" value="false"/><br> <parameter key="min_number_of_attributes" value="1"/><br> <parameter key="max_number_of_attributes" value="1"/><br> <parameter key="exact_number_of_attributes" value="1"/><br> <parameter key="initialize_with_input_weights" value="false"/><br> <parameter key="population_size" value="5"/><br> <parameter key="maximum_number_of_generations" value="30"/><br> <parameter key="use_early_stopping" value="false"/><br> <parameter key="generations_without_improval" value="2"/><br> <parameter key="normalize_weights" value="true"/><br> <parameter key="use_local_random_seed" value="false"/><br> <parameter key="local_random_seed" value="1992"/><br> <parameter key="user_result_individual_selection" value="false"/><br> <parameter key="show_population_plotter" value="false"/><br> <parameter key="plot_generations" value="10"/><br> <parameter key="constraint_draw_range" value="false"/><br> <parameter key="draw_dominated_points" value="true"/><br> <parameter key="maximal_fitness" value="Infinity"/><br> <parameter key="selection_scheme" value="tournament"/><br> <parameter key="tournament_size" value="0.25"/><br> <parameter key="start_temperature" value="1.0"/><br> <parameter key="dynamic_selection_pressure" value="true"/><br> <parameter key="keep_best_individual" value="true"/><br> <parameter key="save_intermediate_weights" value="false"/><br> <parameter key="intermediate_weights_generations" value="10"/><br> <parameter key="p_initialize" value="0.5"/><br> <parameter key="p_mutation" value="-1.0"/><br> <parameter key="p_crossover" value="0.5"/><br> <parameter key="crossover_type" value="uniform"/><br> <process expanded="true"><br> <operator activated="true" class="split_validation" compatibility="9.1.000" expanded="true" height="124" name="Validation" origin="GENERATED_TUTORIAL" width="90" x="313" y="30"><br> <parameter key="create_complete_model" value="false"/><br> <parameter key="split" value="relative"/><br> <parameter key="split_ratio" value="0.7"/><br> <parameter key="training_set_size" value="100"/><br> <parameter key="test_set_size" value="-1"/><br> <parameter key="sampling_type" value="automatic"/><br> <parameter key="use_local_random_seed" value="false"/><br> <parameter key="local_random_seed" value="1992"/><br> <process expanded="true"><br> <operator activated="true" class="naive_bayes" compatibility="9.1.000" expanded="true" height="82" name="Naive Bayes" width="90" x="179" y="34"><br> <parameter key="laplace_correction" value="true"/><br> </operator><br> <connect from_port="training" to_op="Naive Bayes" to_port="training set"/><br> <connect from_op="Naive Bayes" from_port="model" to_port="model"/><br> <portSpacing port="source_training" spacing="0"/><br> <portSpacing port="sink_model" spacing="0"/><br> <portSpacing port="sink_through 1" spacing="0"/><br> </process><br> <process expanded="true"><br> <operator activated="true" class="apply_model" compatibility="7.1.001" expanded="true" height="82" name="Apply Model" origin="GENERATED_TUTORIAL" width="90" x="45" y="30"><br> <list key="application_parameters"/><br> <parameter key="create_view" value="false"/><br> </operator><br> <operator activated="true" class="weka:performance_consistency" compatibility="7.3.000" expanded="true" height="82" name="Performance (2)" width="90" x="246" y="34"/><br> <connect from_port="model" to_op="Apply Model" to_port="model"/><br> <connect from_port="test set" to_op="Apply Model" to_port="unlabelled data"/><br> <connect from_op="Apply Model" from_port="labelled data" to_op="Performance (2)" to_port="example set"/><br> <connect from_op="Performance (2)" from_port="performance" to_port="averagable 1"/><br> <portSpacing port="source_model" spacing="0"/><br> <portSpacing port="source_test set" spacing="0"/><br> <portSpacing port="source_through 1" spacing="0"/><br> <portSpacing port="sink_averagable 1" spacing="0"/><br> <portSpacing port="sink_averagable 2" spacing="0"/><br> </process><br> </operator><br> <connect from_port="example set" to_op="Validation" to_port="training"/><br> <connect from_op="Validation" from_port="averagable 1" to_port="performance"/><br> <portSpacing port="source_example set" spacing="0"/><br> <portSpacing port="source_through 1" spacing="0"/><br> <portSpacing port="sink_performance" spacing="36"/><br> </process><br> </operator><br> <connect from_op="Retrieve Titanic Training" from_port="output" to_op="Optimize Selection (Evolutionary)" to_port="example set in"/><br> <connect from_op="Optimize Selection (Evolutionary)" from_port="example set out" to_port="result 1"/><br> <connect from_op="Optimize Selection (Evolutionary)" from_port="performance" to_port="result 2"/><br> <portSpacing port="source_input 1" spacing="0"/><br> <portSpacing port="sink_result 1" spacing="0"/><br> <portSpacing port="sink_result 2" spacing="18"/><br> <portSpacing port="sink_result 3" spacing="0"/><br> </process><br> </operator><br></process><br><br>
