<?xml version="1.0" encoding="UTF-8"?><process version="9.2.000-RC"> <context> <input/> <output/> <macros/> </context> <operator activated="true" class="process" compatibility="9.2.000-RC" expanded="true" name="Process"> <parameter key="logverbosity" value="init"/> <parameter key="random_seed" value="2001"/> <parameter key="send_mail" value="never"/> <parameter key="notification_email" value=""/> <parameter key="process_duration_for_mail" value="30"/> <parameter key="encoding" value="SYSTEM"/> <process expanded="true"> <operator activated="true" breakpoints="after" class="utility:create_exampleset" compatibility="9.2.000-RC" expanded="true" height="68" name="Create ExampleSet" width="90" x="45" y="85"> <parameter key="generator_type" value="comma separated text"/> <parameter key="number_of_examples" value="100"/> <parameter key="use_stepsize" value="false"/> <list key="function_descriptions"/> <parameter key="add_id_attribute" value="false"/> <list key="numeric_series_configuration"/> <list key="date_series_configuration"/> <list key="date_series_configuration (interval)"/> <parameter key="date_format" value="yyyy-MM-dd HH:mm:ss"/> <parameter key="time_zone" value="SYSTEM"/> <parameter key="input_csv_text" value="id,date,status 1,1/1/18,proposal 1,1/8/18,analysis 1,1/20/18 ,accepted 1,1/30/18,closed 2,2/1/18,proposal 2,2/10/18,analysis 2,2/12/18,accepted 2,2/18/18,closed"/> <parameter key="column_separator" value=","/> <parameter key="parse_all_as_nominal" value="false"/> <parameter key="decimal_point_character" value="."/> <parameter key="trim_attribute_names" value="true"/> </operator> <operator activated="true" class="numerical_to_polynominal" compatibility="9.2.000-RC" expanded="true" height="82" name="Numerical to Polynominal" width="90" x="313" y="85"> <parameter key="attribute_filter_type" value="single"/> <parameter key="attribute" value="id"/> <parameter key="attributes" value=""/> <parameter key="use_except_expression" value="false"/> <parameter key="value_type" value="numeric"/> <parameter key="use_value_type_exception" value="false"/> <parameter key="except_value_type" value="real"/> <parameter key="block_type" value="value_series"/> <parameter key="use_block_type_exception" value="false"/> <parameter key="except_block_type" value="value_series_end"/> <parameter key="invert_selection" value="false"/> <parameter key="include_special_attributes" value="false"/> </operator> <operator activated="true" class="nominal_to_date" compatibility="9.2.000-RC" expanded="true" height="82" name="Nominal to Date" width="90" x="447" y="85"> <parameter key="attribute_name" value="date"/> <parameter key="date_type" value="date"/> <parameter key="date_format" value="MM/dd/yy"/> <parameter key="time_zone" value="SYSTEM"/> <parameter key="locale" value="English (United States)"/> <parameter key="keep_old_attribute" value="false"/> </operator> <operator activated="true" class="time_series:lag_series" compatibility="9.2.000-BETA2" expanded="true" height="82" name="Lag" width="90" x="581" y="85"> <list key="attributes"> <parameter key="date" value="1"/> </list> <parameter key="overwrite_attributes" value="false"/> <parameter key="extend_exampleset" value="false"/> </operator> <operator activated="true" class="generate_attributes" compatibility="9.2.000-RC" expanded="true" height="82" name="Generate Attributes" width="90" x="715" y="85"> <list key="function_descriptions"> <parameter key="duration" value="date_diff([date-1],date)/(1000*3600*24)"/> </list> <parameter key="keep_all" value="true"/> </operator> <operator activated="true" class="aggregate" compatibility="9.2.000-RC" expanded="true" height="82" name="Aggregate" width="90" x="849" y="85"> <parameter key="use_default_aggregation" value="false"/> <parameter key="attribute_filter_type" value="all"/> <parameter key="attribute" value=""/> <parameter key="attributes" value=""/> <parameter key="use_except_expression" value="false"/> <parameter key="value_type" value="attribute_value"/> <parameter key="use_value_type_exception" value="false"/> <parameter key="except_value_type" value="time"/> <parameter key="block_type" value="attribute_block"/> <parameter key="use_block_type_exception" value="false"/> <parameter key="except_block_type" value="value_matrix_row_start"/> <parameter key="invert_selection" value="false"/> <parameter key="include_special_attributes" value="false"/> <parameter key="default_aggregation_function" value="average"/> <list key="aggregation_attributes"> <parameter key="duration" value="average"/> </list> <parameter key="group_by_attributes" value="status|id"/> <parameter key="count_all_combinations" value="false"/> <parameter key="only_distinct" value="false"/> <parameter key="ignore_missings" value="true"/> </operator> <connect from_op="Create ExampleSet" from_port="output" to_op="Numerical to Polynominal" to_port="example set input"/> <connect from_op="Numerical to Polynominal" from_port="example set output" to_op="Nominal to Date" to_port="example set input"/> <connect from_op="Nominal to Date" from_port="example set output" to_op="Lag" to_port="example set input"/> <connect from_op="Lag" from_port="example set output" to_op="Generate Attributes" to_port="example set input"/> <connect from_op="Generate Attributes" from_port="example set output" to_op="Aggregate" to_port="example set input"/> <connect from_op="Aggregate" from_port="example set output" to_port="result 1"/> <portSpacing port="source_input 1" spacing="0"/> <portSpacing port="sink_result 1" spacing="0"/> <portSpacing port="sink_result 2" spacing="0"/> </process> </operator> </process>
Hi, I have ended up writing a SQL in the DB. I could do the same in RM, but not sure how to use the below Oracel function in Aggregation operator lead(dd ignore nulls) over (partition by id order by dd) - dd as dt_diff. Does RM support "Partion by" ?
