<?xml version="1.0" encoding="UTF-8"?><process version="9.2.000-RC"> <context> <input/> <output/> <macros/> </context> <operator activated="true" class="process" compatibility="9.2.000-RC" expanded="true" name="Process" origin="GENERATED_TEMPLATE"> <parameter key="logverbosity" value="init"/> <parameter key="random_seed" value="2001"/> <parameter key="send_mail" value="never"/> <parameter key="notification_email" value=""/> <parameter key="process_duration_for_mail" value="30"/> <parameter key="encoding" value="SYSTEM"/> <process expanded="true"> <operator activated="true" class="retrieve" compatibility="9.2.000-RC" expanded="true" height="68" name="Load Transactions" origin="GENERATED_TEMPLATE" width="90" x="45" y="187"> <parameter key="repository_entry" value="//Samples/Templates/Market Basket Analysis/Transactions"/> </operator> <operator activated="true" class="aggregate" compatibility="6.0.006" expanded="true" height="82" name="Aggregate" origin="GENERATED_TEMPLATE" width="90" x="179" y="136"> <parameter key="use_default_aggregation" value="false"/> <parameter key="attribute_filter_type" value="all"/> <parameter key="attribute" value=""/> <parameter key="attributes" value=""/> <parameter key="use_except_expression" value="false"/> <parameter key="value_type" value="attribute_value"/> <parameter key="use_value_type_exception" value="false"/> <parameter key="except_value_type" value="time"/> <parameter key="block_type" value="attribute_block"/> <parameter key="use_block_type_exception" value="false"/> <parameter key="except_block_type" value="value_matrix_row_start"/> <parameter key="invert_selection" value="false"/> <parameter key="include_special_attributes" value="false"/> <parameter key="default_aggregation_function" value="average"/> <list key="aggregation_attributes"> <parameter key="product 1" value="concatenation"/> </list> <parameter key="group_by_attributes" value="Invoice"/> <parameter key="count_all_combinations" value="false"/> <parameter key="only_distinct" value="false"/> <parameter key="ignore_missings" value="true"/> </operator> <operator activated="true" class="rename" compatibility="9.2.000-RC" expanded="true" height="82" name="Rename" origin="GENERATED_TEMPLATE" width="90" x="313" y="136"> <parameter key="old_name" value="concat(product 1)"/> <parameter key="new_name" value="Products"/> <list key="rename_additional_attributes"/> </operator> <operator activated="true" class="set_role" compatibility="9.2.000-RC" expanded="true" height="82" name="Set Role" origin="GENERATED_TEMPLATE" width="90" x="447" y="136"> <parameter key="attribute_name" value="Invoice"/> <parameter key="target_role" value="id"/> <list key="set_additional_roles"/> </operator> <operator activated="true" class="concurrency:fp_growth" compatibility="9.2.000-RC" expanded="true" height="82" name="FP-Growth" origin="GENERATED_TEMPLATE" width="90" x="581" y="136"> <parameter key="input_format" value="item list in a column"/> <parameter key="item_separators" value="|"/> <parameter key="use_quotes" value="false"/> <parameter key="quotes_character" value="""/> <parameter key="escape_character" value="\"/> <parameter key="trim_item_names" value="true"/> <parameter key="positive_value" value="true"/> <parameter key="min_requirement" value="support"/> <parameter key="min_support" value="0.005"/> <parameter key="min_frequency" value="100"/> <parameter key="min_items_per_itemset" value="1"/> <parameter key="max_items_per_itemset" value="0"/> <parameter key="max_number_of_itemsets" value="1000000"/> <parameter key="find_min_number_of_itemsets" value="false"/> <parameter key="min_number_of_itemsets" value="100"/> <parameter key="max_number_of_retries" value="15"/> <parameter key="requirement_decrease_factor" value="0.9"/> <enumeration key="must_contain_list"/> </operator> <operator activated="true" class="create_association_rules" compatibility="9.2.000-RC" expanded="true" height="82" name="Create Association Rules" origin="GENERATED_TEMPLATE" width="90" x="715" y="187"> <parameter key="criterion" value="confidence"/> <parameter key="min_confidence" value="0.1"/> <parameter key="min_criterion_value" value="0.8"/> <parameter key="gain_theta" value="2.0"/> <parameter key="laplace_k" value="1.0"/> </operator> <operator activated="true" class="converters:rules_2_example_set" compatibility="0.4.001" expanded="true" height="82" name="Association Rules to ExampleSet" width="90" x="916" y="187"/> <operator activated="true" class="multiply" compatibility="9.2.000-RC" expanded="true" height="82" name="Multiply" width="90" x="1117" y="187"/> <operator activated="true" class="select_attributes" compatibility="9.2.000-RC" expanded="true" height="82" name="Select Attributes" width="90" x="1251" y="187"> <parameter key="attribute_filter_type" value="subset"/> <parameter key="attribute" value="Premises"/> <parameter key="attributes" value="Conclusion|Premises"/> <parameter key="use_except_expression" value="false"/> <parameter key="value_type" value="attribute_value"/> <parameter key="use_value_type_exception" value="false"/> <parameter key="except_value_type" value="time"/> <parameter key="block_type" value="attribute_block"/> <parameter key="use_block_type_exception" value="false"/> <parameter key="except_block_type" value="value_matrix_row_start"/> <parameter key="invert_selection" value="false"/> <parameter key="include_special_attributes" value="false"/> </operator> <operator activated="true" class="multiply" compatibility="9.2.000-RC" expanded="true" height="124" name="Multiply (2)" width="90" x="1385" y="85"/> <operator activated="true" class="generate_attributes" compatibility="9.2.000-RC" expanded="true" height="82" name="Generate Attributes" width="90" x="1519" y="34"> <list key="function_descriptions"> <parameter key="Conclusion" value="Premises"/> </list> <parameter key="keep_all" value="false"/> </operator> <operator activated="true" class="generate_id" compatibility="9.2.000-RC" expanded="true" height="82" name="Generate ID" width="90" x="1653" y="85"> <parameter key="create_nominal_ids" value="false"/> <parameter key="offset" value="0"/> </operator> <operator activated="true" class="generate_attributes" compatibility="9.2.000-RC" expanded="true" height="82" name="Generate Attributes (2)" width="90" x="1519" y="136"> <list key="function_descriptions"> <parameter key="Premises" value="Conclusion"/> </list> <parameter key="keep_all" value="false"/> </operator> <operator activated="true" class="generate_id" compatibility="9.2.000-RC" expanded="true" height="82" name="Generate ID (2)" width="90" x="1653" y="187"> <parameter key="create_nominal_ids" value="false"/> <parameter key="offset" value="0"/> </operator> <operator activated="true" class="concurrency:join" compatibility="9.2.000-RC" expanded="true" height="82" name="Join" width="90" x="1787" y="136"> <parameter key="remove_double_attributes" value="true"/> <parameter key="join_type" value="inner"/> <parameter key="use_id_attribute_as_key" value="true"/> <list key="key_attributes"/> <parameter key="keep_both_join_attributes" value="false"/> </operator> <operator activated="true" class="generate_id" compatibility="9.2.000-RC" expanded="true" height="82" name="Generate ID (3)" width="90" x="1519" y="238"> <parameter key="create_nominal_ids" value="false"/> <parameter key="offset" value="0"/> </operator> <operator activated="true" class="cross_distances" compatibility="9.2.000-RC" expanded="true" height="103" name="Cross Distances" width="90" x="1921" y="136"> <parameter key="measure_types" value="NominalMeasures"/> <parameter key="mixed_measure" value="MixedEuclideanDistance"/> <parameter key="nominal_measure" value="SimpleMatchingSimilarity"/> <parameter key="numerical_measure" value="EuclideanDistance"/> <parameter key="divergence" value="GeneralizedIDivergence"/> <parameter key="kernel_type" value="radial"/> <parameter key="kernel_gamma" value="1.0"/> <parameter key="kernel_sigma1" value="1.0"/> <parameter key="kernel_sigma2" value="0.0"/> <parameter key="kernel_sigma3" value="2.0"/> <parameter key="kernel_degree" value="3.0"/> <parameter key="kernel_shift" value="1.0"/> <parameter key="kernel_a" value="1.0"/> <parameter key="kernel_b" value="0.0"/> <parameter key="only_top_k" value="false"/> <parameter key="k" value="10"/> <parameter key="search_for" value="nearest"/> <parameter key="compute_similarities" value="true"/> </operator> <operator activated="true" class="generate_id" compatibility="9.2.000-RC" expanded="true" height="82" name="Generate ID (4)" width="90" x="1385" y="238"> <parameter key="create_nominal_ids" value="false"/> <parameter key="offset" value="0"/> </operator> <operator activated="true" class="concurrency:join" compatibility="9.2.000-RC" expanded="true" height="82" name="Join (2)" width="90" x="2055" y="187"> <parameter key="remove_double_attributes" value="true"/> <parameter key="join_type" value="inner"/> <parameter key="use_id_attribute_as_key" value="false"/> <list key="key_attributes"> <parameter key="request" value="id"/> </list> <parameter key="keep_both_join_attributes" value="false"/> </operator> <operator activated="true" class="filter_examples" compatibility="9.2.000-RC" expanded="true" height="103" name="Filter Examples" width="90" x="2189" y="187"> <parameter key="parameter_expression" value=""/> <parameter key="condition_class" value="custom_filters"/> <parameter key="invert_filter" value="false"/> <list key="filters_list"> <parameter key="filters_entry_key" value="distance.ne.1"/> </list> <parameter key="filters_logic_and" value="true"/> <parameter key="filters_check_metadata" value="true"/> </operator> <operator activated="true" class="remove_duplicates" compatibility="9.2.000-RC" expanded="true" height="103" name="Remove Duplicates" width="90" x="2323" y="187"> <parameter key="attribute_filter_type" value="single"/> <parameter key="attribute" value="Premises"/> <parameter key="attributes" value=""/> <parameter key="use_except_expression" value="false"/> <parameter key="value_type" value="attribute_value"/> <parameter key="use_value_type_exception" value="false"/> <parameter key="except_value_type" value="time"/> <parameter key="block_type" value="attribute_block"/> <parameter key="use_block_type_exception" value="false"/> <parameter key="except_block_type" value="value_matrix_row_start"/> <parameter key="invert_selection" value="false"/> <parameter key="include_special_attributes" value="false"/> <parameter key="treat_missing_values_as_duplicates" value="false"/> </operator> <operator activated="true" class="select_attributes" compatibility="9.2.000-RC" expanded="true" height="82" name="Select Attributes (2)" width="90" x="2524" y="187"> <parameter key="attribute_filter_type" value="subset"/> <parameter key="attribute" value=""/> <parameter key="attributes" value="request|distance|document"/> <parameter key="use_except_expression" value="false"/> <parameter key="value_type" value="attribute_value"/> <parameter key="use_value_type_exception" value="false"/> <parameter key="except_value_type" value="time"/> <parameter key="block_type" value="attribute_block"/> <parameter key="use_block_type_exception" value="false"/> <parameter key="except_block_type" value="value_matrix_row_start"/> <parameter key="invert_selection" value="true"/> <parameter key="include_special_attributes" value="false"/> </operator> <connect from_op="Load Transactions" from_port="output" to_op="Aggregate" to_port="example set input"/> <connect from_op="Aggregate" from_port="example set output" to_op="Rename" to_port="example set input"/> <connect from_op="Rename" from_port="example set output" to_op="Set Role" to_port="example set input"/> <connect from_op="Set Role" from_port="example set output" to_op="FP-Growth" to_port="example set"/> <connect from_op="FP-Growth" from_port="frequent sets" to_op="Create Association Rules" to_port="item sets"/> <connect from_op="Create Association Rules" from_port="rules" to_op="Association Rules to ExampleSet" to_port="rules input"/> <connect from_op="Association Rules to ExampleSet" from_port="example set" to_op="Multiply" to_port="input"/> <connect from_op="Multiply" from_port="output 1" to_op="Select Attributes" to_port="example set input"/> <connect from_op="Select Attributes" from_port="example set output" to_op="Multiply (2)" to_port="input"/> <connect from_op="Select Attributes" from_port="original" to_op="Generate ID (4)" to_port="example set input"/> <connect from_op="Multiply (2)" from_port="output 1" to_op="Generate Attributes" to_port="example set input"/> <connect from_op="Multiply (2)" from_port="output 2" to_op="Generate Attributes (2)" to_port="example set input"/> <connect from_op="Multiply (2)" from_port="output 3" to_op="Generate ID (3)" to_port="example set input"/> <connect from_op="Generate Attributes" from_port="example set output" to_op="Generate ID" to_port="example set input"/> <connect from_op="Generate ID" from_port="example set output" to_op="Join" to_port="left"/> <connect from_op="Generate Attributes (2)" from_port="example set output" to_op="Generate ID (2)" to_port="example set input"/> <connect from_op="Generate ID (2)" from_port="example set output" to_op="Join" to_port="right"/> <connect from_op="Join" from_port="join" to_op="Cross Distances" to_port="request set"/> <connect from_op="Generate ID (3)" from_port="example set output" to_op="Cross Distances" to_port="reference set"/> <connect from_op="Cross Distances" from_port="result set" to_op="Join (2)" to_port="left"/> <connect from_op="Generate ID (4)" from_port="example set output" to_op="Join (2)" to_port="right"/> <connect from_op="Join (2)" from_port="join" to_op="Filter Examples" to_port="example set input"/> <connect from_op="Filter Examples" from_port="example set output" to_op="Remove Duplicates" to_port="example set input"/> <connect from_op="Remove Duplicates" from_port="example set output" to_op="Select Attributes (2)" to_port="example set input"/> <connect from_op="Select Attributes (2)" from_port="example set output" to_port="result 1"/> <portSpacing port="source_input 1" spacing="0"/> <portSpacing port="sink_result 1" spacing="0"/> <portSpacing port="sink_result 2" spacing="0"/> <description align="left" color="yellow" colored="false" height="70" resized="false" width="850" x="20" y="25">MARKET BASKET ANALYSIS<br>Model associations between products by determining sets of items frequently purchased together and building association rules to derive recommendations.</description> <description align="left" color="blue" colored="true" height="185" resized="true" width="550" x="20" y="105">Step 1:<br/>Load transaction data containing a transaction id, a product id and a quantifier. The data denotes how many times a certain product has been purchased as part of a transactions.</description> <description align="left" color="purple" colored="true" height="341" resized="true" width="549" x="20" y="300"><br> <br> <br> <br> <br> <br> <br> <br> <br> Step 2:<br>Edit, transform &amp; load (ETL) - Aggregate transaction data via concatenation so that the products in a transaction are in one entry, separated by the pipe symbol.<br></description> <description align="left" color="green" colored="true" height="310" resized="true" width="290" x="580" y="105">Step 3:<br/>Using FP-Growth, determine frequent item sets. A frequent item sets denotes that the items (products) in the set have been purchased together frequently, i.e. in a certain ratio of transactions. This ratio is given by the support of the item set.</description> <description align="left" color="green" colored="true" height="215" resized="true" width="286" x="579" y="425"><br> <br> <br> <br> <br> <br> Step 4:<br/>Create association rules which can be used for product recommendations depending on the confidences of the rules.<br></description> <description align="left" color="yellow" colored="false" height="35" resized="true" width="849" x="20" y="655">Outputs: association rules, frequent item set<br></description> </process> </operator> </process>
Open your process in RapidMiner and open the XML panel..
Copy the XML code from there and paste it somewhere else, for example into a forum post here on the community portal. By the way, if you post your XML here, please use the code environment which you get by clicking on the </> icon in the toolbar of the post.
In order to import such an XML description of your process, e.g. to use a process someone else has posted here in the forum, please follow the following steps:
